Old April 20th, 2015, 07:14 AM   #121
JasonJ
Motorcycle(s): 1980 Yamaha XS850G Midnight Special, 32k Miles; 2000 EX250F, <5000 Orig Miles
But they aren't significantly stiffer though, are they?
Anyone have a reason or side by side picture describing why we would want to install the newgen clutch and brake levers? What's better about them?
JasonJ is offline   Reply With Quote
Old April 23rd, 2015, 12:13 PM   #122
fuel664
Motorcycle(s): ninja 250, v65 magna
does anyone know if carbs can be swapped? probably need to be re jetted but not sure about intake boots being same diameter or throttle, and choke cables being in the right spots. doesnt matter on air box side as i can get new pod filters to fit new carb but cant find any info of diameter for engine side of carbs
fuel664 is offline   Reply With Quote
Old April 23rd, 2015, 12:22 PM   #123
fuel664
i suppose with parts getting harder to find for 88-07 250s if you cracked your perch in a crash then you could buy perch and adjustable levers from a 08-12 250. i think they look A LOT better than stock 88-07 levers. i havnt seen a lot of pretty aftermarket levers for old ninjas, all i have seen are black or chrome
Old April 23rd, 2015, 12:59 PM   #124
cookiebug79
n00b with the b00bs
cookiebug79's Avatar
Motorcycle(s): 2007 EX250, 2008 EX250, 2001 ZR-7S, 2010 ZX-6R
Physically the carbs can be swapped, but all of the hoses have to change. The petcock from the fuel tank is in a different location and the idle adjustment screw has a different attachment. But I've run my 2007 carbs on my 2008. It didn't idle very well, but it was just to get it running for a day so I didn't screw around with setting the idle to get it working properly.
cookiebug79 is offline   Reply With Quote
Old April 23rd, 2015, 01:00 PM   #125
cookiebug79
n00b with the b00bs
By hoses I meant all fuel lines. The boots to the engine and the air filter are the same size.
Old June 13th, 2015, 09:56 PM   #126
gpx
Motorcycle(s): GPX 250, HYOSUNG GT650R
My 1992 gpx 250 with complete 2008 ninja 250r front end
gpx is offline   Reply With Quote
Old August 13th, 2015, 04:29 PM   #127
NGagne
NGagne's Avatar
Motorcycle(s): 2 Ninja 250r, Tl1000s and ZX7r
Originally Posted by gpx View Post
Attachment 36889
Nice.
NGagne is offline   Reply With Quote
Old January 12th, 2021, 03:58 AM   #128
gearhead
Motorcycle(s): 99 ninja 250, 81 yzf250
Camshaft swap
So I've got a 99 that I ordered a complete head for (broken cam rockers) and got sent an 08-12 head. I know the heads don't swap over because they don't quite line up, but the camshafts look pretty similar besides the lobes, I'm curious if anyone has put the newer cams in the pregen and what the effect is, or if no one has before if it could be done
gearhead is offline   Reply With Quote
Old January 12th, 2021, 07:49 AM   #129
Cams completely different. One's designed for rocker-arms and other is for buckets.
Pre-gen has more aggressive cams and makes more power anyway.
Last futzed with by DannoXYZ; January 12th, 2021 at 08:59 AM.
Old January 14th, 2021, 12:47 AM   #130
GAU-8
Socially inept. Yet FUN!
GAU-8's Avatar
Motorcycle(s): Current machines- 1992 SECA II 600, 2006 Ninja 250, 2008 Ninja 250
This! I wish my 08, was as "hornet in a shaken bottle" as my 06 was!
GAU-8 is offline   Reply With Quote
Pre-Gen Parts for sale wardie Motorcycle-related 1 November 20th, 2013 05:05 AM
FS: Pre-gen random parts Singh2jz Motorcycle-related 32 May 21st, 2013 12:07 PM
are any pre gen parts compatible with the new gen Jordan91 2008 - 2012 Ninja 250R Farkles 1 April 22nd, 2012 09:15 PM
need some pre gen parts dbking321 Items Wanted 0 March 14th, 2012 09:45 AM
Pre Gen (88-07) misc parts expat Motorcycle-related 9 January 26th, 2012 12:15 PM
