Old April 27th, 2016, 02:53 PM   #201
sprinter
Motorcycle(s): 2018 Ninja 400 Race Bike (in progress...)
Originally Posted by DanteCoal View Post
@sprinter, a quick question;
How are you liking the Scorpion exhaust? That's the one I've had my eye on, and I haven't had much luck finding reviews on the slip-on or full from any 300 owners. Any feedback you could give would be greatly appreciated! Thanks!
I think it's fine, but I didn't have anything to compare it to as far as making power, so I'm not sure if it's any better or worse than any other brand of full system. Sounds great!
sprinter is offline   Reply With Quote
Old April 27th, 2016, 02:58 PM   #202
sprinter
I finally got the little beast back out to the track again after being down for 9 months with a broken transmission. It stopped shifting into 5th gear at Road America last July, and we finally got around to tearing it apart over the winter to check things out. The dogs on the tranny gears are really weak in these things, and they're poorly cast with rounded edges, so not very conducive to good shifting under high load. I know a lot of peope have had problems with slipping out of gear and otherwise sloppy shifting on Ninja 300 track/race bikes. We got 3rd-6th gears back-cut and hardened, and now after running it on the track for the first time earlier this week, it's 1000% better! Shifts crisp and solid every time now, just like a "normal" sportbike! Ready for the TrackAddix GP races at Motorsports Park Hastings in 2 weeks!
Old April 27th, 2016, 07:21 PM   #203
Good to hear you're back out and at it! That little bike is a beauty!
Old April 27th, 2016, 07:38 PM   #204
mgentz
Board Member
was this a big problem on the 250's?
Old April 28th, 2016, 07:55 PM   #205
sprinter
Not sure if the tranny is the same between 250/300 or not.
Old April 29th, 2016, 06:32 AM   #206
Brother Michigan
Motorcycle(s): 2013 Ninja 300
How much did the transmission modifications cost you?
DISCLAIMER: I generally have no idea what I'm talking about.
Old April 29th, 2016, 11:33 AM   #207
ULW
ULW's Avatar
Motorcycle(s): 2015 Ninja 300 X 2
Where did you have this work done and what was the cost?
Thanks,
Dave
ULW is offline   Reply With Quote
Old April 29th, 2016, 11:37 AM   #208
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Anyone who wants to know more needs to talk to the guy in this thread:
https://www.ninjette.org/forums/showthread.php?t=240374
Goin' fast on slow bikes!
Old April 29th, 2016, 04:19 PM   #209
sprinter
I believe it was about 400 bucks.
Old April 29th, 2016, 04:23 PM   #210
sprinter
Thanks,
Dave
I sent the gears to RC's Performance in North Carolina, here's their web site:
http://www.rcsperformanceonline.com/
It was about $400-$450 if I remember correctly.
Old April 29th, 2016, 05:14 PM   #211
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Bike looks great, glad you got it back up and running.
Old May 18th, 2016, 11:07 AM   #212
sprinter
First race of the season is now in the books, this one was at Motorsports Park Hastings, and I had the worst start of my racing career! (Well, I take that back, the WORST start was stalling on the grid at a CCS MWGT race in 2007 and getting clocked from behind by another bike and then spending 4 months on crutches!) We run an Expert / Amateur split grid for the Lightweight GP races, I started at the back of the Expert grid and was passed by 2 Amateurs before Turn 1! 8-lap sprint race, I clawed my way back up to 4th by the end, but the leaders were GONE! Still have another 1-2 secs to pick up in order to win again, I'm switching to a 415 chain setup before next time, we'll see what that does. I did have it tuned for MR12 and ran that last time, but it made no difference in the real world, so I'm going to stick with regular 100-octane race fuel at $6/gal rather than $27/gal for MR12.
Old May 18th, 2016, 11:21 AM   #213
mgentz
Board Member
sorry to hear.
The MR12 really made no difference?
Old May 18th, 2016, 04:05 PM   #214
genosr1
Motorcycle(s): gsxr 750, sv650, 250 ninja
if your motor has stock compression, run 87 octane you will loose performance with 100 octane in a stock compression motor, the mr12 should have made 2hp more and accelerated quicker than the pump gas, overlay your two dyno runs and compare the acceleration
genosr1 is offline   Reply With Quote
Old May 19th, 2016, 12:52 PM   #215
sprinter
sorry to hear.
3HP on the dyno, no difference in actual top speed/acceleration or lap times on the track.
Old May 19th, 2016, 12:54 PM   #216
sprinter
I have JE high-comp pistons, JE said 94 octane or higher to prevent detonation. The dyno showed 3HP difference, but that didn't translate into the "real world" performance on the track where it really matters. I might run it when I go to race at Road America in July, but other than that I'm just going to run my mix of 100-octane and 92 pump premium.
Old May 20th, 2016, 06:49 AM   #217
The gain may be more noticeable on a HP track like RA.
Old June 12th, 2016, 11:55 PM   #218
omnivore
omnivore's Avatar
Motorcycle(s): CBR Fireblade, KTM 950SM, YZF750 (x2), R6, ZZR250, XR200, KTM 50SX Sr.Pro, Honda Spree
@sprinter
Did you sell the old Ohlins shock yet?
Love the build on your bike
KTM 950 SM,YZF 750 Street, CBR929 EnduranceBike,YZF 750 vintage racer, R6 racebike , SOAR #22
omnivore is offline   Reply With Quote
Old June 13th, 2016, 09:42 AM   #219
Yakaru
The Violet Vixen
Yakaru's Avatar
MOTM - Jun '16
Just curious, what's the difference between the two Ohlins rear shocks?
Old July 9th, 2016, 08:42 AM   #220
sprinter
Originally Posted by omnivore View Post
@sprinter
Yes, long time ago.
Old July 9th, 2016, 08:43 AM   #221
sprinter
Standard Ohlins shock vs. the TTX racing shock. TTX is the latest/greatest Ohlins technology with a separate channel inside the valving for rebound and compression damping. If you YouTube it there are a ton of videos out there explaining how the TTX technology works.
