Old July 12th, 2011, 12:02 AM   #1
Colezombie
Colezombie's Avatar
Woodcraft clipon height question
I am looking into getting the woodcraft clipons, but i am unsure of what height size to get. I have read a DIY on how to install them by kkim, but i had thought they were to be installed above the tripple. In the DIY kkim Installed his underneath and used a 2 1/2" rise.
Would a lower rise clamp create clearance issues?
I was hoping to get the lowest rise offered and install them on top
Of the tripple.
Thanks guys,
Cole
'09 250R
woodcraft clip-ons
2 bros slip-on
Colezombie is offline   Reply With Quote
Old July 12th, 2011, 12:30 AM   #2
leed
leed's Avatar
Motorcycle(s): Time will tell
The Clip-On's that Woodcraft sells specifically for the New Gen 250R are designed to go under the triple tree, but actually end up sitting a little lower than a no-rise clip on mounted above the triple tree.
Having been said, if you purchase a no rise clipon with the correct ID for the fork tubes and mount them above the triple, you should be fine, but there are no guarantees! However, it may be some ease to hear that some clip-ons designed for the 250R (Namely the KTC and a few others) are specifically designed to be mounted above the triple tree.
Old July 12th, 2011, 01:45 AM   #3
Colezombie
Colezombie's Avatar
Gotcha,
Thanks leed, I think ill play it safe and get the same setup as kkim.
'09 250R
woodcraft clip-ons
2 bros slip-on
Are woodcraft clipon bars hollow? ninja2007 Ninjettes At Speed 11 October 1st, 2014 08:36 PM
DIY- Woodcraft Clipon Install kkim 2008 - 2012 Ninja 250R Tech Talk 503 October 9th, 2013 08:46 AM
Clipon Vortex or Woodcraft? JaeL 2008 - 2012 Ninja 250R Tech Talk 16 August 16th, 2009 05:26 PM
woodcraft clipon towers gizmogamez Ninjettes At Speed 5 July 22nd, 2009 02:45 PM
