Old August 18th, 2016, 09:45 PM   #121
daverdfw
Motorcycle(s): 2009 Ninja 250
Originally Posted by cuong-nutz View Post
Nope. I haven't been on a track in a few years now.
Ah bummer
daverdfw is offline   Reply With Quote
Old August 19th, 2016, 03:00 PM   #122
daverdfw
got some of the green plastigage .001 to .003 measurement.
Old August 19th, 2016, 03:32 PM   #123
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
That's some useful stuff
Old August 19th, 2016, 04:45 PM   #124
bruce71198
bruce71198's Avatar
Clean the sealer off the case halves and put a piece of plastigage across the cranke and torque it down. Make sure not to spin the crank. Make a note of where the factory applied the RTV sealer so you know where to put the new stuff .
Old August 19th, 2016, 05:00 PM   #125
daverdfw
Should I do the balancer shaft too?
Old August 19th, 2016, 05:08 PM   #126
Sorry to see all this deep surgery.
You may need this:
https://www.ninjette.org/forums/showthread.php?t=111031
Originally Posted by RacinNinja View Post
..........I'm not a 100% expert on this so a second or third opinion would be good. @Motofool
Sorry, I am late.
Old August 19th, 2016, 05:15 PM   #127
daverdfw
You may need this:
Sorry, I am late.
I have a few different torque wrenches
Old August 19th, 2016, 05:57 PM   #128
daverdfw
so when I was taking the cylinder head bolts off it took a little bit of muscle, I am reading through the FSM about re-assembly and it says to only use 18 ft-lb to re install. Does that seem correct?
Old August 19th, 2016, 06:26 PM   #129
bruce71198
bruce71198's Avatar
It's either that or 24ft. Lbs. I'll check tomorrow morning, all my infos at the shop. Check the balance shaft clearance too,
Old August 19th, 2016, 07:13 PM   #130
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Yes do the balancer also. The whole oil system is like a sealed system. If there is a gap in the balancer clearance then the pressure will be lower somplace else.
Worlds fastest 250 ninja
Old August 19th, 2016, 08:43 PM   #131
daverdfw
Makes sense. I have just been going into the garage and looking at everything disassembled. It seems to make sense. And reading the FSM about when reinstalling the crank and cams and lining everything up so it's in time. Seems pretty straight forward. I will post up some pics tomorrow after I get the case and clean it and then test the bearing clearances.
Old August 19th, 2016, 08:54 PM   #132
bruce71198
bruce71198's Avatar
18ft lbs on the 250 head bolts. 24ft lbs on the 300. I new I got that somewhere. The 300 uses a different cylinder design that's probably why the different spec. The bolts are the same and I have used the higher spec even on the 250.
Old August 19th, 2016, 08:55 PM   #133
daverdfw
ok cool, one of the bolt heads looked a little rounded, but I tested it in the old case and was able to torque it just fine. I have 2 on order just in case, last thing I wanna do is strip that bolt.
Old August 19th, 2016, 09:19 PM   #134
daverdfw
in the manual it says to lube up certain places with a moly grease, any kind you guys suggest? I see a pricy loctite one, and then just like old school grease.
Old August 19th, 2016, 11:00 PM   #135
bruce71198
bruce71198's Avatar
Get some engine assembly lube, with molybdenum in it, from the parts store.
Usually comes in a squeeze tube and not real expensive. You'll use this on the bearings as well on final assembly.
Old August 20th, 2016, 08:42 AM   #136
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Smear it on the bearings (THINLY!) and add a drop or two of engine oil. It's the shiz!
Goin' fast on slow bikes!
Old August 20th, 2016, 08:54 AM   #137
Racer x
Racer x's Avatar
I like to mix up a batch in a small cup or can lid and use a brush or finger tk smear it around.
Old August 20th, 2016, 09:03 AM   #138
daverdfw
Got the case. It has blue markings in it
Old August 20th, 2016, 09:22 AM   #139
daverdfw
so the case color marks are different, but the bearing colors are the same,, the crank ones had yellow paint, the balancer has blue.
looks like this came from a bike with a top end issue, lots of copper shards in the bottom of the case. Looks like I will spend a lot of time with brake parts cleaner and compressed air cleaning this thing thoroughly.
Old August 20th, 2016, 09:26 AM   #140
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Copper is usually indicative of a bearing issue in the bottom end. My guess would be a big end rod bearing spun. There isn't really any copper in the top end. The top end cam bearing surface is the aluminum head itself.
Old August 20th, 2016, 09:27 AM   #141
daverdfw
hmm let me take a closer look at the bearings
Old August 20th, 2016, 09:31 AM   #142
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Probably won't find anything since you didn't get the crank with it but it's good to look at the bearings for damage or wear. Since this person was selling the cases, the crank is probably toast.
If you want a second opinion, post up some pics.
Old August 20th, 2016, 09:34 AM   #143
daverdfw
so the only damage i noticed is this hole next to where the oil screen and cover go on, but it looks like it is empty, nothing goes in it. All of the bearings look ok to me, nothing obvious as far as damage.
Old August 20th, 2016, 09:35 AM   #144
daverdfw
so even with the case colors being off, but the bearing colors are the same and since I am going to swap bearings from my old case, am I ok to proceed?
Old August 20th, 2016, 10:42 AM   #145
Racer x
Racer x's Avatar
Yup. Just clean and measure
Old August 20th, 2016, 10:43 AM   #146
daverdfw
ok, lots and lots of brake cleaner here i come!
Old August 20th, 2016, 11:42 AM   #147
daverdfw
is the one bent hole going to be an issue? I don't think it will be
Old August 20th, 2016, 12:06 PM   #148
Racer x
Racer x's Avatar
I don't think so. Just run a file lightly across the serface to restore the gasket serface.
Old August 20th, 2016, 12:18 PM   #149
Use a sharp and rigid edge and keep it parallel to the matting surfaces.
The surfaces are very soft; be careful not to scratch it.
If the remaining gasket is hard, no fluid is needed to remove the gross of the material.
Old August 20th, 2016, 12:18 PM   #150
daverdfw
I have some razor blades I can use
Old August 20th, 2016, 12:22 PM   #151
I prefer using a new blade of a box cutter; it is more rigid and less sharp.
Avoid smelling too much of brake cleaner; WD-40 is good to remove carbon deposits, like from the head of the pistons.
Old August 20th, 2016, 01:51 PM   #152
daverdfw
Thanks everyone ! I am in the process of cleaning it. I assume in order to heck clearance I can just do a dry fit then take it apart and lube everything up
Old August 20th, 2016, 02:16 PM   #153
Racer x
Racer x's Avatar
That is about it. I just fit it all up dry and only use the big bolts to get the measurements. Being careful not to rotate anything
Old August 20th, 2016, 04:18 PM   #154
daverdfw
Ah ok so I don't have to put all the 10mm bolts back in. Just the 12mm big ones ?
Old August 20th, 2016, 05:37 PM   #155
daverdfw
ok I feel like I have everything clean enough, here are some pics.
Old August 20th, 2016, 06:03 PM   #156
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Take compressed air and clean it more. Get every little fiber and piece of lint off the bearing areas and inside the cases. Blow out every passage to be sure they're clear.
Otherwise, good progress!
Old August 20th, 2016, 06:17 PM   #157
daverdfw
Ok will do. Then Iwill swap the bearings over and leave the rest of the case empty and use some of the moly I got from the store to install the bearings and use plastigage on the crank and balancer
Old August 20th, 2016, 06:19 PM   #158
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Don't use any moly whatsoever until you plastigage.
Assemble it dry. Check. Then lube.
Old August 20th, 2016, 06:21 PM   #159
daverdfw
Ok will do !
So when I install using the molly. Do I use it between the bearing and case or between the bearing and crank journal ?
Old August 20th, 2016, 06:33 PM   #160
Racer x
Racer x's Avatar
Yes tk cleaning and blowing everything g out with compressed air. Clean clean clean is the way of the worrior.
Assemble everything dry with the plastiguage and be careful not to let anything turn at all.
Then put just leave the bearing shells in the case(hopefully) unless the measurements are off. Then you use Molly lube on the crank and the counter bearings.
I use an oil can worn a pump handle thing to squirt oil on the trans and all over the parts . Being careful to avoid any seal serface on the case half.
Bike chain broke while riding. Can't shift. ieoz 2008 - 2012 Ninja 250R Tech Talk 8 August 19th, 2015 08:57 PM
Lowside- bent clutch thrust rod and possibly bent shift fork? Klondike1020 General Motorcycling Discussion 3 April 1st, 2014 02:29 AM
Short shift lever tie-rod? Yakaru 2013 - 2017 Ninja 300 Tech Talk 15 March 16th, 2014 01:14 PM
WTB Tie Rod for Shift Assembly TooNasty Items Wanted 0 May 15th, 2013 01:32 PM
Slipping shift pedal tie-rod headshrink 2008 - 2012 Ninja 250R Tech Talk 9 June 16th, 2009 10:46 AM
