Old January 25th, 2020, 10:28 PM   #1
59096
59096's Avatar
Motorcycle(s): GPX250 1989 model and 1990 model
Removed the trail tech Vapor instruments
Removed the Trail Tech Vapor and replaced it with the original analogue instruments on my 1989 GPX 250 naked special. Did a bit of trimming on the facial panel to make it fit the profile of the headlight a bit better. I much prefer watching needles and pointers. Digital just doesn’t turn me on. What do you think?
File Type: jpg 2AF7DB89-4290-44FD-B98B-B95C729DA487.jpg (88.1 KB, 12 views)
File Type: jpg 5C4B07C9-AC8E-40CF-834B-6C68F0E07520.jpg (113.8 KB, 12 views)
File Type: jpg ECD2DB18-E51C-46BD-843D-BE44C5719813.jpg (125.5 KB, 14 views)
Perpetua Culpa Alterna Vagus
59096 is offline   Reply With Quote
Old January 26th, 2020, 06:29 AM   #2
I like it. I did something similar when I put my 250 together. I've had some trouble with the tachometer though, and if I have any more I'll probably get a Danmoto unit to replace everything.
Old January 26th, 2020, 03:14 PM   #3
59096
59096's Avatar
Pretty much the same setup Triple Jim. I have trimmed about 1” off the shroud to get it a bit higher above the headlight rim. My tacho is a bit sticky but always responds to a tap.
Old January 27th, 2020, 02:26 PM   #4
06CandyThunder
06CandyThunder's Avatar
Motorcycle(s): 2006 Ninja 250
Selling the vapor tech��?
06CandyThunder is offline   Reply With Quote
Old January 27th, 2020, 09:00 PM   #5
59096
59096's Avatar
Yes I am interested is selling. I am in Australia. Comes with dash panel surround and plugs directly into the wiring loom of the pre gen. Also comes with special bracket for speedo pickup on rear wheel.
Old January 27th, 2020, 09:10 PM   #6
59096
59096's Avatar
Yes I am interested is selling. I am in Australia. Comes with indication lights and dash panel surround and plugs directly into the wiring loom of the pre gen. Also comes with special bracket for speedo pickup on rear wheel.
File Type: jpg 8C646830-776F-4BB9-951A-63F654693182.jpg (98.3 KB, 2 views)
File Type: jpg 56F2935C-632A-48E2-9350-810D146B10B8.jpg (88.1 KB, 2 views)
Trail Tech Vapor Odometer Cra1g General Motorcycling Discussion 6 September 8th, 2016 07:37 PM
Trail Tech Vapor MAZ 80 General Motorcycling Discussion 2 October 19th, 2015 04:10 AM
Trail Tech Vapor Review Kruse08 1986 - 2007 Ninja 250R Tech Talk 7 August 19th, 2014 02:55 AM
Trail Tech Vapor and mount rugbert 1986 - 2007 Ninja 250R Farkles 12 September 2nd, 2013 11:36 AM
Vapor Trail Tech Question/Help skilletmo 2008 - 2012 Ninja 250R Tech Talk 41 May 12th, 2013 02:40 PM
