Old October 30th, 2012, 11:02 AM   #1
Jim Moore
Jim Moore's Avatar
Motorcycle(s): 2000 Ninjette, 98 CBR600, 98 VFR800, 2000 BMW R1100RS, Kymco Movie 150
I need some float bowl gaskets ...
Anyone got a set they can sell? If not, anyone get a recommendation for a rebuild kit for a 98 Ninja 250?
Thanks,
Jim Moore
Jax, FL
Jim Moore is offline   Reply With Quote
Old October 30th, 2012, 01:06 PM   #2
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
Thanks,
A rebuild kit will run you about $60 but if you use some gasket maker convservatively it'll only cost $5.
Old October 30th, 2012, 01:08 PM   #3
Jim Moore
Jim Moore's Avatar
Thanks for the info. Shockingly, the local dealer has some gaskets in stock. I'm gonna buy a pair tomorrow.
Jim Moore
Jax, FL
Old October 30th, 2012, 08:09 PM   #4
papawhellie
Motorcycle(s): lots
I used the permatex gasoline resistant stuff on mine because I did not want to wait on gaskets. Worked like a champ. No leaks. I have to replace a needle that was bent so I ordered two of these.
http://www.ebay.com/itm/320995496161...84.m1497.l2649
Kit is only a buck or so more than just the needle fromdealer. I did verify with seller that needle was included. I guess I will pop the tops on mine when they get here and replace both needles where they will be the same. Gonna drop a couple of the 3 mm washers in there as well and hope I am running like a scalded dog!
papawhellie is offline   Reply With Quote
Old October 30th, 2012, 08:45 PM   #5
FvnnyL3tt3r1ng
Looks like main jet/needle but no pilot jet/needles?
Old October 30th, 2012, 09:33 PM   #6
papawhellie
Motorcycle(s): lots
Seller did confirm needle was included in this set. I will post pictures when received.
Yes, it is a complete kit. The needle is included.
- psrazors
Old October 31st, 2012, 09:39 PM   #7
thumper64
I ordered a couple kits that look like that. There's an idle screw, float needle, but not the long main needle I think you're thinking of.
Motorcycle noob, feel free to ignore me.
thumper64 is offline   Reply With Quote
Old November 1st, 2012, 03:45 AM   #8
Jim Moore
Jim Moore's Avatar
Hey guys,
Everything is back together with no leaks. When I pulled the floats off it was pretty obvious that the gaskets were shot. Here's a tip. Turn your bowls sideways and look at hte gaskets. If they're so flat the no longer are visible above the top of the groove, you need to replace them.
Jim Moore
Jax, FL
Old November 1st, 2012, 10:37 PM   #9
papawhellie
Motorcycle(s): lots
- psrazors
Recieved the kits NO NEEDLES IN THE KIT WILL BE RETURNING TO SELLER. HE TOLD ME THEY WERE INCLUDED.
Old November 1st, 2012, 10:59 PM   #10
FvnnyL3tt3r1ng
With ebay you should get a refund instantly while you wait though
Float bowl leak (I think) MasterCylinder 1986 - 2007 Ninja 250R Tech Talk 30 December 20th, 2013 10:16 AM
Gaskets The_big_dill 1986 - 2007 Ninja 250R Tech Talk 10 November 6th, 2013 06:27 AM
Float Bowl Screws kaybray 2008 - 2012 Ninja 250R Tech Talk 2 December 16th, 2012 02:51 PM
need float bowl gasket &/or oil screen cuz Items Wanted 2 October 19th, 2011 11:06 AM
WTB: Float Bowl Screw, Gas tank fairing grommet haze5736 Items Wanted 0 July 19th, 2011 07:04 AM
