Old May 28th, 2009, 04:39 AM   #1
tinng321
tinng321's Avatar
Motorcycle(s): 08 black 250r (sold); '09 black zx6r
knocking or rattling noise
I took the bike out for my first ride yesterday and hear this knocking or rattling noise from the left side of the bike. I believe i heard the noise after 3500-4000 rpm. I am not sure on this cuz I wanted to pay attention to the road instead of the rpm. Is this normal?
tinng321 is offline   Reply With Quote
Old May 28th, 2009, 05:12 AM   #2
M-Oorb
M-Oorb's Avatar
Motorcycle(s): 2008 250r (Fastest Color)
Hm any rattling noise isn't normal. Where on the left side is it coming from ie from the engine area or down by the shift linkage... Does it sound mechnical or like a loose bolt?
Posted via Mobile Device
M-Oorb is offline   Reply With Quote
Old May 28th, 2009, 05:29 AM   #3
tinng321
tinng321's Avatar
I think it's coming from the engine. Sound more mechnical than loose bolt.
Old May 28th, 2009, 06:47 AM   #4
Cali619
Giggity Giggity
Cali619's Avatar
Motorcycle(s): 08 ninja 250R aka Hiryu
have you had a chance to rev it in neutral on its kickstand to try and pinpoint the source?
Facebook DY Fender chop, Danmoto CB slip-on w/baffle, Airbox removed, Kleen-air removed, shimmed needles, Mikuni #117.5 Main jets, K&N RU-1822 air filter pods
Cali619 is offline   Reply With Quote
Old May 28th, 2009, 08:01 AM   #5
tinng321
tinng321's Avatar
I'll try that when i get home from work.
Old May 28th, 2009, 11:48 AM   #6
OldGuy
Live Life
OldGuy's Avatar
Motorcycle(s): 2009 Green SE Ninja 250
Before you get too carried away check the oil level just to be sure. On the '08 forward with only the side stand you need to slide a 2x4 under the stand (wide part up) to get the bike more level for checking the level.
- ATGATT -
Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots
OldGuy is offline   Reply With Quote
Old May 28th, 2009, 03:50 PM   #7
tinng321
tinng321's Avatar
Hmmmm... I think I know where the noise is coming from. It looks like the shift linkage is loose. I just tighting it up. Can't test ride cuz it's raining.
I'll check the oil tomorrow b4 I take it out for a test ride.
It seems like everyone is having this same problem. Do bikes have recalls like autos?
Thanks all.
Old May 28th, 2009, 04:03 PM   #8
Banzai
Psychic war veteran
Banzai's Avatar
Thanks all.
Careful, spec on that shift linkage bolt that attaches to the transmission is 104 in/lbs, which is not quite as tight as you think it is. Use blue locktite. If it was the bolt that mounts the shift lever pedal to the frame, that's only 18 ft/lbs, and also should have blue locktite on it. I hope that helps cure your rattling. Stay safe.
And the answer is YES, bikes DO have recalls. Ducati recalled their new StreetFighter the day it debuted for a possible cracking fuel hose fitting that could cause fires.
Most of the problems with these bikes related to hardware should have been caught during set up from the dealer and never happened, again at the 600 mile first service, and then nothing should go wrong fastener wise from there. Other than routine service, T-CLOCS is your friend. (Tires and wheels, Controls, Lights and electrics, Oil and other fluids, Chasis, Stands)
Old May 28th, 2009, 08:09 PM   #9
You mean things work loose on a high revving, vibration filled vehicle like a motorcycle? Who would have guessed it?
Old May 30th, 2009, 07:58 PM   #10
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
one of the new bmw's has 3 recalls between the time the dealer uncrates it and it goes out the door.
Old May 31st, 2009, 05:05 AM   #11
ScorpionNinja
ScorpionNinja's Avatar
hmmm im not sure i know what your hearing, but on my 250R only noise thats weird ,etc was the dreaded FRONT WHEEL BEARING (squeeak, squeeak. . . .) but it was stopped , for now!
I do though, hear a noise which my guess is, its just a "Vibration noise" , of the front fairings or some part of the plastic Body panel. if i remb right, i here it as im slowing down for a red light,etc @ about 25-30 MPH! Its like a Vibration HUM if anything come to think about it! I dont feel its sumin Bad, or bugs me, so i just wondered if anyothers here, have Hear this Humming type vibration noise? Is that normal on a sportbike... any kind suzuki,honda,yamaha,kawi? cuz of the Plastic body panels... with high RPMs your bound too get sumin Vibrating like crazy and HUM*
Old May 31st, 2009, 05:13 AM   #12
tinng321
tinng321's Avatar
it's really hard to tell where the sound is coming from on a bike cuz of the wind and road noise. I hear it louder when i pull in the clutch lever. maybe it's just a humming noise you're talking about. i have no idea. i only hear it when i ride.
Old May 31st, 2009, 09:51 AM   #13
thought the noise was the shifter?
Rattling noise from the engine.. paterick4o8 2008 - 2012 Ninja 250R Tech Talk 15 February 9th, 2021 08:16 PM
2012 NINJA 250 Engine Knocking/rattling? drosvil 2008 - 2012 Ninja 250R Tech Talk 7 July 28th, 2014 12:13 PM
Rattling Noise hieuster 2008 - 2012 Ninja 250R Tech Talk 12 July 3rd, 2013 11:13 PM
Engine knocking noise vinnyirl 2008 - 2012 Ninja 250R Tech Talk 11 March 8th, 2013 12:33 PM
Weird knocking noise... blink 2008 - 2012 Ninja 250R Tech Talk 6 July 3rd, 2012 12:24 PM
