Go Back   ninjette.org > 2013 - 2017 Ninja 300 > 2013 - 2017 Ninja 300 General Discussion
Old June 8th, 2020, 10:15 AM   #1
psykown
Motorcycle(s): 2007 Ninja 250 "sold" 2014 ninja 300 "Gold" 2000 DRZ400S (Sold the POS) K7 GSXR600 (Also POS...see a pattern?
Engine finally gave out, Need ideas
All right so my 300 engine finally gave out at around 65k miles, the cylinder 1 rod bearing left me searching for chunks of gold in the oil pan. At the moment its looking like a new piston, rod, and crank at the very minimum plus the smaller extras (bolts bearings , rings etc) So far its looking like;
~$600+ to repair
~$900 for a used engine
~$1100 for a ninja 400 engine
~unknown $ do something crazy with a random engine just because
I'm leaning towards the 400 engine (comes with wiring harness and ecu) to keep it a little more exciting of a bike, the 300 is tough to ride after getting off my street triple R lol. My understanding is that the 400 is a stroked and bored 300 and that the case is the same, is this correct? Not in any huge rush for this and depending on the route chosen there may be some cheap internals available for yall soon.
psykown is offline   Reply With Quote
Old June 8th, 2020, 11:23 AM   #2
A 400 engine isn't going to just bolt right up I'm pretty sure. I thought there were major chassis and engine design changes that would make it impractical.
A used 300 engine should be a lot less than $900 at this point. We sold a low-mileage Ninja 250 engine (less carbs) in good condition for about $250 a couple years ago.
Normally a used engine is the best option.
Old June 8th, 2020, 11:29 AM   #3
psykown
Yeah everything near me ends up being about 900 all said and done atm, if you've got one for cheaper let me know!
from what i've read so far the chassis is very different correct, but the actual case for the engine seems to be the same.
Old June 8th, 2020, 04:08 PM   #4
No way will 400 engine fit. Rear swingarm bolts to rear of engine. You'll have to hack off most of rear of 300 frame to fit 400 engine. Which may make it nice and squisshy. Probably a lot of forward section of frame too as 400 sits high up in between perimeter frame. So you'll have to tilt 400 engine downwards at front if you don't cut out 300 backbone. It's easier to just build custom frame.
Not just engine, you'll need from 400:
- rear swingarm, shock & linkage
- rear wheel, sprocket and brakes
- tank & fuel-pump
- throttle-bodies, injectors and TPS
- airbox & MAP sensor
- exhaust, muffler, O2-sensor
For effort, you might as well get crashed and totaled 400 for ~$2000.
If you want more power with engine-swap, go with EX500. Much, much easier swap and more power than 400.
Best deal is used 300 engine. See them on craigslist, eBay and junkyards for about $200-400. Add $100-150 shipping. There's one with 12k-miles for $350 on eBay right now. Or $200 needing rebuild. Can swap engine in about 2-hrs
Last futzed with by DannoXYZ; June 14th, 2020 at 08:06 PM.
Old June 8th, 2020, 08:45 PM   #5
BoBO
BoBO's Avatar
Motorcycle(s): SC28 Fireblade
Used low mileage engine is your best choice for practicality. I think 300 motor goes for $400-500 on eBay maybe even cheaper.
94 900RR
04 BMW Z4 2.5 M Package
01 R170 AMG Sport Package
BoBO is offline   Reply With Quote
Old June 9th, 2020, 05:56 AM   #6
VaFish
VaFish's Avatar
MOTM - Jan '16
I just did a quick look on ebay, they are $850-$900 with shipping.
Old June 9th, 2020, 11:48 AM   #7
$200 needs rebuild https://www.ebay.com/itm/124107952071
$350 12k-miles https://www.ebay.com/itm/223794289601
Old June 9th, 2020, 12:46 PM   #8
$450 with shipping.
Win.
EDIT: Not so much - "for parts..." - gotta read the fine print.
Would think you could find something reasonable though, there are plenty out there.
Last futzed with by jkv45; June 12th, 2020 at 08:03 AM.
Old June 9th, 2020, 12:54 PM   #9
BoBO
BoBO's Avatar
Wow, that's a lot for 250. If you're not in a hurry I would wait a bit I'm sure a $500 motor will pop up. Last year I bought a N250 motor as a gift for my buddy. I paid about $550 and it came with a cluster that had 8k on it, delivered to my friends garage on a nice pallet.
$800-$900 is just too much.
94 900RR
Old June 9th, 2020, 02:42 PM   #10
Here's one being parted out. Offer him $300-400 for engine after getting mileage and condition. Might even want to do compression-test before picking it up.
https://orangecounty.craigslist.org/...125779746.html
Old June 11th, 2020, 02:09 PM   #11
VaFish
VaFish's Avatar
MOTM - Jan '16
First one needs a rebuild and second one is "Not Working, for parts has a rod knock" And you still have to pay $100-$200 shipping to get them.
If you want to put in a running motor you are going to need to pay more.
Old June 11th, 2020, 02:58 PM   #12
Ceeloo Yello
Motorcycle(s): 250
Sounds like you would be better off just rebuilding what you got.
Old June 11th, 2020, 07:25 PM   #13
Or get crashed or totalled bike. Check local junkyards or copart.com
Old June 16th, 2020, 10:55 AM   #14
psykown
Thanks a ton for the responses guys! Especially for that pic of the 400 frame that’s what I had been trying to find. Was wondering about a 450/500 swap as well, I think I’ve got enough projects in the garage for now though lol
I think I’ve finally settled on parting her out and giving back to you guys a bit for all the help on here, I’ve had plenty of fun on her and am ready to mix it up a bit. If anyone needs parts I’ll put new post up a little later this afternoon for the part out, frame has registration still so if anyone in SoCal wants a super cheap frame let me know!
Old June 23rd, 2020, 01:36 PM   #15
From this ad: https://sacramento.craigslist.org/mp...46757112.html#
Guy says he has 300 engine for $750 (includes shipping to SoCal). Should ask about:
- engine condition
- mileage
- when last valve-adjustment was
Engine Feels Like It's Missing at Medium Speed. Any Ideas? Kawinoob217 1986 - 2007 Ninja 250R Tech Talk 27 December 1st, 2017 10:26 AM
[motogp.com] - Syahrin: “I never gave up trying” Ninjette Newsbot Motorcycling News 0 September 14th, 2017 04:10 AM
Gave it a bath modded Pictures 2 June 8th, 2013 04:33 PM
Engine holder - need ideas headshrink 2008 - 2012 Ninja 250R Tech Talk 7 August 9th, 2011 06:23 PM
just gave her a wash! ninjette Pictures 14 September 22nd, 2009 08:27 PM
