Old March 7th, 2011, 10:39 AM   #1
headshrink
headshrink's Avatar
Ignition coil wire leads
I have my right (#2) ignition coil off (to get the cylinder cover off - context not important). Out of curiosity, how important is it that the two wires to it aren't switched? I snapped a picture of it before pulling off the leads, but last time I pulled them off I didn't and have always wondered if I had it right, or if it even mattered. The reason I really question it is because I had the RED wire on the GREEN connector (bottom), and the GREEN wire on the BLACK connector (top). I wired it this way last time because the way the wires hung out of the harness seemed like they had been in that position since assembly.... but couldn't be sure. It seems weird to me that GREEN wouldn't go to GREEN. I checked the wiring diagram, and although it specifies which wire is which, there was no indication which terminal is which.
So does it matter?
Old March 7th, 2011, 11:21 AM   #2
HKr1
IC2(SW)
HKr1's Avatar
http://mgaguru.com/mgtech/ignition/ig104.htm
Old March 7th, 2011, 11:56 AM   #3
headshrink
headshrink's Avatar
Originally Posted by HKr1 View Post
I'll have to re-read that when I get home... it is a little over my head (some of it). My understanding of the article was both yes, and no... It will work reversed, but not optimally.... did I read that correctly?
For the record, which wire is officially supposed to connect to which terminal?
Old March 7th, 2011, 12:15 PM   #4
randomwalk101
self wrencher
randomwalk101's Avatar
the article also talks of how to go about checking for the correct polarity.
Old March 7th, 2011, 01:39 PM   #5
DaBlue1
DaBlue1's Avatar
Originally Posted by headshrink View Post
...For the record, which wire is officially supposed to connect to which terminal?
RED wire on the GREEN connector / GREEN wire on the BLACK connector is the way mine is.
Old June 22nd, 2014, 03:33 AM   #6
webfoot
Motorcycle(s): 2012 ninja 250R
@DaBlue1, Is that the same for right and left coil connections? my 2012 but it shouldnt mater, I put red on the green ceramic on both sides, havent tried to start, not sure of damage I may cause. and y the f didnt kawi put a + and - like normal people?
webfoot is offline   Reply With Quote
Old June 22nd, 2014, 03:39 AM   #7
webfoot
what the heck is up w no + or - marks? geez?
Old June 25th, 2014, 05:59 PM   #8
DaBlue1
DaBlue1's Avatar
RED wire on the GREEN connector / GREEN wire on the BLACK connector for the right coil
RED wire on the GREEN connector / BLACK wire on the BLACK connector for the left coil
Ignition coil shorting? The_big_dill General Motorcycling Discussion 1 April 11th, 2015 09:54 PM
coil and plug wire help gantt 2008 - 2012 Ninja 250R Tech Talk 7 March 5th, 2015 07:50 AM
2012 ninja 250R ignition coil question webfoot 2008 - 2012 Ninja 250R Tech Talk 5 June 22nd, 2014 10:18 PM
Accessory wire? or ignition wire? caineroad 2008 - 2012 Ninja 250R Tech Talk 2 September 21st, 2013 09:35 PM
Coil Wire Inquiry Greyfox 2008 - 2012 Ninja 250R Tech Talk 5 January 23rd, 2013 05:01 PM
