Old March 22nd, 2009, 11:51 AM   #1
komohana
komohana's Avatar
Motorcycle(s): 05 GSX-R 600 2003 EX250: Woodcraft Bars, Levers, Mirrors, Shim'd Mixture, Synthetic, '08 Rear Shock
Exclamation New Rearsets for Selected Pre-Gens:
alrighty, at the time i initially researched this, i couldn't find anything but the Woodcraft rearsets (that you can get with, or without shift and brake levers) pictured here
i happened to run across these that i haven't seen before on ebay:
here's some details:
Brand NEW!!! Racer Designed, Black Anodized Finish, CNC Machined, Billet Aluminum Rear Sets,
Fit All model years Kawasaki 250 from the 90's to the 2007 model , Racer Tough, Inexpensive and easy to repair and replace parts. Perfect for Racing, Track Bikes, or street with a rear brake light pressure switch available separately.
Fully adjustable up an down, forward and back, by 1.75 inches Each Direction!!! Probably the Widest Adjustment Range, and I Believe, the best product, on the Market!!!
Easy to assemble and mount!!! Highly Durable, Racer Tough!!! Designed and built, by racers, to work for racers!!!
Available now for immediate shipping
Completely modular, so you can order all the replacement pieces separately, for inexpensive repairs if damaged in crash. Each piece is CNC machined separately so you can order and have replacement parts shipped immediately, fast and inexpensively, to keep you up and on the track!!!
A must for Track Days and Racing, not to mention, Super on the Street!!!
These parts are all expensive at the OEM dealer level, and tough as nails to find in usable, good, condition at wreckers. Bid with confidence, this part is good!!!
here's the posted item on ebay
by the picture it appears to have shift/brake levers with the kit as well.
hope you're able to find something you like!
aloha
Remember when sex was safe
and motorcycles were dangerous?
komohana is offline   Reply With Quote
Old March 22nd, 2009, 01:42 PM   #2
Verus Cidere
Verus Cidere's Avatar
Motorcycle(s): '91 Honda CBR600 F2
Thanks! I've been trying to decide what rearset to get, 'cause that's what I'm getting after I get my exhaust (from Area P).
Just to elaborate a bit more, the woodcraft website states that the rearset you have shown above will fit all years (1988 - 2009). So does that mean that any rearset that fits the 09 will also fit the 07? I'm hoping so because I want to get this one:
Edit -- DOH! The link I posted here didn't work. 2 posts down has a new one!
Verus Cidere is offline   Reply With Quote
Old March 22nd, 2009, 01:46 PM   #3
Strider
Back on the Black!
Strider's Avatar
Motorcycle(s): 2006 Kawasaki Ninja EX250 (Black)
Can you check that link Verus Cidere ... I got :
This page may have moved or is no longer available
Strider is offline   Reply With Quote
Old March 22nd, 2009, 02:26 PM   #4
Verus Cidere
That's wierd.... Lemme try again.
http://cgi.ebay.com/ebaymotors/Kawas...1%7C240%3A1318
Edit -- I tried this one and it works. Lemme know if there are more problems. (Oh, and if it'll work or not, provided you know )
Old March 22nd, 2009, 02:35 PM   #5
where does it say it will work on the pregens?
Old March 22nd, 2009, 02:43 PM   #6
Verus Cidere
This one doesn't, but the woodcraft one does. I was going off of that and the assumption that, if the bolt holes for the woodcraft are lined up for both models, the others would be too. If on rearset fits on the 07 and the 08, shouldn't others that fit the 08 fit the 07? Correct me if I'm wrong. This is why I asked. Don't wanna get something that doesn't fit!
Old March 22nd, 2009, 02:46 PM   #7
good point. I don't know the answer, so I'll let someone who has more direct knowledge answer that one.
Old March 22nd, 2009, 02:59 PM   #8
Verus Cidere
I've been considering going to my local Kawi dealer and measuring the spaces and angles between the bolts on one of the '09s they have there, then comparing it to mine. Think they'd get mad?
Old March 22nd, 2009, 03:04 PM   #9
no... just tell them you're considering buying the 09 to replace your pregen and they'll let you do whatever you want.
Old March 22nd, 2009, 03:38 PM   #10
Verus Cidere
lol this is true. Especially at my dealership! This place loves to pump prices up as high as possible! I usually hate going there at all, but they're almost the only place around that has good gear and such.
Old March 22nd, 2009, 04:58 PM   #11
so, do them a favor and use them for a change.
Old March 22nd, 2009, 10:30 PM   #12
Verus Cidere
Definitely gonna try that. While I'm checking the distances/angles, I'll ask them how much it costs. How much did you guys who got your 08 or 09 ninjette pay for them off the showroom floor? I wanna know how much this place tries to cheat me for this year ninjette. (They had a used 07 ninjette and were asking $3900 for it!!! It was like new condition and only had 1700 miles on it, but that was close to the end of 08!)
Old March 24th, 2009, 10:15 PM   #13
Verus Cidere
They seem to be exactly the same in distance, angle, and bolts used to secure them (except for the top one that dissappears on the 08+). Only thing I need to worry about now is clearance on the older bikes. Fairings and exhaust are still different!
Old March 25th, 2009, 07:37 AM   #14
sometimesido
sometimesido's Avatar
Motorcycle(s): 2006 250R
hm..based on this picture
I don't think it's the same.
Angle of the four main bolts.
Look at your bike.
The right side.
my flickr™
sometimesido is offline   Reply With Quote
Old March 25th, 2009, 07:44 AM   #15
sometimesido
Here's what I'm talking about.
my flickr™
Old March 25th, 2009, 07:50 AM   #16
sometimesido
Hm...then I saw the stock 08 pictures.
Maybe it is the same.
Let us know what you find out.
my flickr™
Old March 25th, 2009, 10:57 AM   #17
Quiks66
Quiks66's Avatar
Motorcycle(s): '07 Ninja 250, '87 FZ600
FWIW my biz patner and are finishing up fitting rearset riser brackets for the 88-07's. The 08+ fitment is different from the 07 and earlier bikes and I haven't found anyone that makes rearsets (or riser plates) for the older model.
Quiks66 is offline   Reply With Quote
Old March 25th, 2009, 11:05 AM   #18
sometimesido
What about the link on the original post?
I'm all for people making more parts for the ~07's.
my flickr™
Old March 25th, 2009, 01:58 PM   #19
Verus Cidere
I agree. I may be wrong on this, but don't those back two bolts just hold the brake resevior (or however you spell that)? I don't know. If it is that different, how can Woodcraft claim that theirs fits both? Confusion!
Also, isn't the angle at the front of the bracket, where they're bolted to the frame have a different angle anyway between the two bikes? (aka the pregens angle is a little more backward at the top bolt) So, in theory, it would still work, the rearset would just be tilted back a little more on a pregen. I'm almost sounding crazy to myself, but when I compare the two it looks the same to me.
Old March 25th, 2009, 02:11 PM   #20
Quiks66
Quiks66's Avatar
You're right about the rear brake master cylinder mounting (looks like a reservoir). I'd be pleasantly surprised to see the 08+ rearsets fit on the old model. The old model rearsets are different between the left and the right sides (spacing and angle) and the distance the shift rod would have to reach I am sure is different too.
What the heck, somebody can go buy a set for the new model and try to make them work on the old gen. Any takers?
Old March 25th, 2009, 02:13 PM   #21
Verus Cidere
I'd do it if I thought I could get rid of it afterwards. I'd probably post it on here at a discount to try and get some of my money back if it doesn't work. Anybody think they'd want a rearset?
Old March 29th, 2009, 03:24 PM   #22
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
Michael - it may or may not help, but I have a stock rearset that is in a few pieces I'd be willing to send to you to try out...
Old March 29th, 2009, 11:23 PM   #23
Verus Cidere
That might work.... And it would definitely be cheaper than buying a whole new rearset just to find out it doesn't work. But I think my parents might freak if I gave my address out to someone online. No offense or anything. I might try ordering a spare bracket someone has on ebay that they're selling for cheap. It's a little different that way, both because the stuff is actually mailed to my dad, and because there's no contact before unless there are questions. Thanks for the offer though.
1991 Honda CBR600 F2, White/Gray, D&D slip-on exhaust, tail integrator, gel grips, Custom undertail.
Old March 29th, 2009, 11:39 PM   #24
if it means anything, I can vouch for noche...
Old March 30th, 2009, 04:34 PM   #25
Verus Cidere
It would mean something for me, but my parents are amazingly overprotective in many areas. An online person vouching for an online person probably wouldn't make any difference. Again, nothing personal to either of you. Just the parental control I get to deal with for another year or so.
Old May 26th, 2009, 08:16 PM   #26
Flashmonkey
Professional belly dancer
Flashmonkey's Avatar
Motorcycle(s): 1992 GSX-R 750
In the spirit of not creating a new thread for this, I've decided to revive this old thread with this question: will aftermarket rearsets (woodcraft, ebay or otherwise) allow me to stretch my legs a little more?
I just completed a trip to Niagra falls (about 150km's from Toronto), which is about 1.5 hours one way. Butt cramping was a given, but on the trip home, I found that my left leg practically went numb on me. I do a lot of heavy weight lifting (deadlifts, squats, etc), and spent most of my youth involved in martial arts....so my knees aren't exactly up to par. I dont' really want to look for a larger bike at this point. Would these rear sets help at all? Anybody out there with experience on this? I'd like some opinions before I start throwing money around ebay again
Oh I'm 5'11, 220lbs with a 30" inseam btw.
Old May 29th, 2009, 11:32 PM   #27
Verus Cidere
I think what most of these rearsets do is move the pegs up and back a bit. I think there would be better stretch at the hips, but more contraction at the knees. I've learned from reading different posts here and there that it's much better to take rest brakes very often while riding, along with constantly shifting your weight to change the pressures on different parts of your body. I don't think rearsets will help with stretching your legs much at all though. Sorry.
Old May 30th, 2009, 06:35 PM   #28
Flashmonkey
Eh ya I figured as much....but it was worth a shot anyway! Thanks for the response!
Old May 31st, 2009, 01:16 PM   #29
Verus Cidere
No problem!
Old June 1st, 2009, 06:58 AM   #30
Apex
Livin' the Minimoto Life
Apex's Avatar
To rest my backend, I sometimes will go into a full tuck, resting my elbows on my knees. The reduces the weight of my torso sitting on my butt, and also changes my overall position, allowing blood to once again flow to my back end. I end up doing that every 30 minutes or so, and staying there for a good 5 minutes. You may look a little retarded, but the change in position is good. Actually stopping is the best way, but this is just a little alternative.
Old June 2nd, 2009, 02:52 AM   #31
tapdiggy
Humble Observer
tapdiggy's Avatar
Motorcycle(s): 2009 Yamaha XT250
I use the full tuck to git feeling back in my hands. I often ride a stretch of road with a perpetual crosswind, causing semi-involuntary "deathgrip." When my right hand goes numb, I tuck in and slowly circulation comes back.
tapdiggy is offline   Reply With Quote
Old June 2nd, 2009, 12:44 PM   #32
Flashmonkey
On highway trips i'm almost always tucked in. I'm not a fan of having the wind beating up against my chest...and it kills my gas mileage
Post your Pre Gens dbking321 Pictures 228 June 20th, 2022 11:35 AM
Pre-Gens on the Dragon! livewire83 Videos 2 April 19th, 2014 11:16 AM
Exhaust systems for pre-gens psych0hans Motorcycle-related 5 March 8th, 2014 02:16 AM
custom pre gens darrell85 General Motorcycling Discussion 2 September 1st, 2010 11:18 AM
16 teeth front sprocket - fits pre-gens and new-gens Rayme Motorcycle-related 2 August 2nd, 2009 10:18 AM
