August 3rd, 2011, 03:09 PM | #1 |
Friend's bike wont start... ideas?
Hey, not a Ninjette related question but since you all are my best resource I figured i'd post the question here.
Here's the deal, my friend has a Suzuki Intruder 800cc cruiser and for some reason it wont start. No clicks, no cranking, lights come on when jumping but not when connected to the battery. So I thought it might be the battery. I connected a battery tender to the battery but strangely it doesnt want to charge (light on tender kept flashing red meaning no connection). Disconnect the (+) terminal from his battery to the bike and then the tender would charge. Charged the battery for 3 hours or so and tried to see if it would work. Still nothing. We've checked the fuses also and they look good. To our memory, we came back from an awesome ride, parked it and he forgot to shut the lights off so we assumed it was a dead battery. Any other ideas? We will leave the battery on the tender overnight but what bothers me is that when the battery is connected to the bike, it will NOT charge but it will charge when disconnected. Does that mean there is a short somewhere? Trying to get it running by this saturday for our Mt. Hamilton ride. |
August 3rd, 2011, 03:15 PM | #2 |
ModMy250.com
Tommy's bike? If it fails to hold a charge, the battery likely needs to be replaced.
The www.ModMy250.com guy |
August 3rd, 2011, 03:18 PM | #3 |
Haha yea it can be. I have the battery tender jr that comes with a connection that allows me to leave it on the bike and use it as a jumping/charging port. I'll look into it though to make sure.
August 3rd, 2011, 03:19 PM | #4 |
ModMy250.com
Yeah, I just realized it's ok to leave it connected. However, since disconnecting it allows the battery to charge, it may have a shorted power wire. Did you guys take a look at the wiring? I think when I wrote that bit about not having it connected, I was remembering how you're not supposed to have it charging when you have 2 batteries connected to each other.
August 3rd, 2011, 04:58 PM | #5 | |
August 3rd, 2011, 05:50 PM | #6 |
err... what is it? lead acid batteries once they get past a certain point will not take a charge again? they start evaporating the electrolytes or something??? can you check the levels in the battery or is it sealed? this is my brother's expertise but everytime he tries to tell me about it he does it in a way that makes me zone out and not listen...
August 3rd, 2011, 06:33 PM | #7 | |
August 3rd, 2011, 07:41 PM | #8 |
it sounds like the battery is toast... you might want to just go buy a battery from your local moto shop... usually they'll let you return it if you don't need it (unless its a crappy shop...) but yeah check it in the morning and see if it has a good charge... if it keeps a charge good to go... maybe. if not... new battery time
- - -Bike Wont Start - - - | Triple R | 2008 - 2012 Ninja 250R Tech Talk | 1 | July 31st, 2014 06:54 AM |
Tank under pressure and bike wont start | Shawn250 | 2008 - 2012 Ninja 250R Tech Talk | 4 | May 13th, 2012 01:42 PM |
bike wont start after new flasher relay | onizthegnome | 2008 - 2012 Ninja 250R Tech Talk | 7 | December 12th, 2010 12:32 PM |
Bike wont start, please help? | zev42 | 2008 - 2012 Ninja 250R Tech Talk | 11 | November 9th, 2010 01:02 PM |
uhh, bike wont start. | ajaygraci | 2008 - 2012 Ninja 250R Tech Talk | 37 | June 24th, 2009 06:39 PM |
