#1 |
Ninjette of the North
Join Date: May 2011 Motorcycle(s): Blue 2010 Ninja 250 Posts: 51
Front Wheel Squeak - Solved
(New 250 Owner & First time poster)
Like so many other 250 owners after about 800km I developed the infamous front wheel squeak. I wasn't happy because I just got it back from my first service. Thanks to this site I found some very valuable information. I first checked my speedo and that wasn't the problem. When I checked the factory torque on the front axle, Holy Hana was it tight. It had to be up around 100 ft-lbs. I backed it off, re-torqued to spec and problem solved. Thanks to everyone for all the great posts and info here. |
#2 |
#3 |
I used a ton of axle grease last time I took the wheel off and that did the trick for me.
#4 |
Be careful about using too much grease. Any more than a slight film, and it can make it harder for the clamps in the forks to hold the axle as tight as you'd want if the grease migrates toward the ends of the axle. At higher speeds, it can make for an uneasy feeling in the front end.
#5 | |
#6 | |
#7 |
Still not sure that I understand how it affects things but I will take your advice. I know that the axle isn't really a friction-bearing surface there but that also means it shouldn't really turn there regardless of extra lube. Are you saying that it may cause my axle and axle nut to spin when it shouldn't?
#8 |
It won't spin freely of course, but it can shift small amounts. The axle nut won't spin freely due to the safety clip, even if it loosens. But, even small amounts of movement in axle placement can be quite hairy if they happen at the wrong time.
Fix for front wheel squeak noise/Front wheel removal | cuong-nutz | 2008 - 2012 Ninja 250R Tech Talk | 13 | April 23rd, 2014 12:25 PM |
wheel makes a squeak | Old Lemon | 2008 - 2012 Ninja 250R Tech Talk | 8 | November 22nd, 2013 12:09 PM |
[crash.net - MotoGP] - Capirossi: Front-end problem ‘seems to be solved' | Ninjette Newsbot | Motorcycling News | 0 | May 11th, 2011 04:50 AM |
Whine/squeak from front wheel | GeneJunkie | 2008 - 2012 Ninja 250R Tech Talk | 14 | January 10th, 2011 03:16 PM |
Help. When I accelerate, I get squeak from front | poo poo | 2008 - 2012 Ninja 250R Tech Talk | 4 | November 9th, 2010 03:28 PM |
