July 25th, 2010, 10:01 PM | #1 |
Join Date: May 2009 Motorcycle(s): '09 Kawasaki N-250 + '09 Vulcan 900 Classic Lt Posts: A lot.
Power Outlet Casco 212711C All Weather
Has anyone installed this particular All Weather power outlet. Before attaching to my V-900.. and one of you have already installed this item.... tell me.... which is the "positive" or hotwire the gray or the white one. It impossible to tell due to the waterproof body they have enclosed the wires in at the base of the power outlet.... thanx in advance...
Last futzed with by addy126; July 26th, 2010 at 07:57 AM. |
July 26th, 2010, 05:59 AM | #2 |
Join Date: Jan 2010 Motorcycle(s): 2005 Suzuki S50, 2006 Kawasaki Ninja EX250F, 1990 Honda PC800, 2000 Yamaha TW200 Posts: 848
Most outlets have the center contact +, the outside circular contact is -. I don't know how your wires go but just check continuity between one wire at a time to each contact and see which one goes to which contact and wire it up appropriately.
July 26th, 2010, 08:01 AM | #3 |
*bump* can anyone using this particular outlet tell me the color designation for the wires on this model (my current vom doesn't register anything).... thanx
July 26th, 2010, 09:06 AM | #4 |
Set your vom on resistance and touch the two vom wires together. The meter should go full scale. Now with the "Casco outlet" disconnected, connect one vom lead to one "casco" lead. Connect the other vom lead to the center connection of the "casco". If the vom goes full scale, that "casco" lead is the positive wire, so the "other" casco wire is the negative.
July 26th, 2010, 08:47 PM | #5 |
Update: This power outlet is as follows for anyone installing and do not have the VOM to locate circuit......
Positive = Gray Wire / Negative = White Wire This helps for an easy install with limited or broken Voltage Testing equipment. |
Power Outlet from (front) Accessory Wires | Kokosun | 1986 - 2007 Ninja 250R Farkles | 26 | September 24th, 2013 12:33 AM |
What is this vent outlet? | delscorcho | 2008 - 2012 Ninja 250R Tech Talk | 2 | July 22nd, 2012 05:25 PM |
[motorcyclistonline] - Power to Spare with New Snap-On 12-Outlet Power Strip | Ninjette Newsbot | Motorcycling News | 0 | October 1st, 2010 03:40 PM |
[crash.net - MotoGP] - Casco d'Oro adds to Rossi season. | Ninjette Newsbot | Motorcycling News | 0 | December 11th, 2009 11:00 AM |
[crash.net - MotoGP] - Casco d'Oro adds Rossi season. | Ninjette Newsbot | Motorcycling News | 0 | December 11th, 2009 08:40 AM |
