Old October 15th, 2013, 01:11 PM   #1
james250ninja
james250ninjette.newbie
james250ninja's Avatar
Motorcycle(s): 1986 ninja 250
Smile Swapping parts
does any one know if parts from the 1987 ninja 250 can fit on ninja 250 from 1988-2007
id like to put mirrors from 87 model to my 07 also the speedometer cluster from 87 to a 07 ninja 250
james250ninja is offline   Reply With Quote
Old October 16th, 2013, 05:45 AM   #2
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
I can't really answer this but I do know that even the 88-2007 models differ from year to year in things like gauge lights
Mods: Offset clutch pressure plate
Old October 16th, 2013, 09:58 AM   #3
Lychee
sail away
Lychee's Avatar
I thought all the gauges were all the same in that time frame. The 86-87 bikes are rare. There are a few on this forum with owners that might be nice enough to try a test fit on another local forum member if you ask nicely, coordinate, and provide pics of your girlfriend...
Old October 16th, 2013, 01:13 PM   #4
FvnnyL3tt3r1ng
I have seen @n4mwd (2007?) ninja and they took out turn signal lights from the gauge on his I believe....Whereas my 2001 has them. I'm sure there are some other minor things.
Old October 16th, 2013, 03:22 PM   #5
n4mwd
n4mwd's Avatar
The parts are mostly interchangeable with a few exceptions. That does not mean that they are identical. Some of the pre-94 bikes had a different wiring harness. The post 2000 bikes have integral fuel filters and the older ones did not.
Not sure about the turn signal indicators. Mine only has one indicator light for both left and right. Are you saying the older ones had one for left and right separately?
My Ninja Blog
Old October 18th, 2013, 05:17 PM   #6
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
Originally Posted by n4mwd View Post
The post 2000 bikes have integral fuel filters and the older ones did not...
Sorry for going off-topic, but you're saying that we don't have to cut the fuel line and add a filter?
The Bike | The Truck
Old October 18th, 2013, 05:42 PM   #7
FvnnyL3tt3r1ng
@n4mwd
My 2001 has high beam, neutral, oil, and turn signal indicators (4 total bulbs).
Old October 18th, 2013, 06:01 PM   #8
Lychee
sail away
Lychee's Avatar
The stock inline inside the hose near the carburetor. It is small and tiny and you cannot see if it is clogged. Cutting and adding a clear body filter is suggested but is not required per se.
Old October 18th, 2013, 06:38 PM   #9
n4mwd
n4mwd's Avatar
I have two pregens and put inline filters on both and they both had the factory filter. There is also a filter in the pickup tubes on the petcock. The problem is the factory filters are really just screens and let in larger particles. The see-thru filters filter out smaller particles.
My Ninja Blog
Old October 19th, 2013, 03:39 AM   #10
Singh2jz
Singh2jz's Avatar
Thanks for the response guys. I had already bought a filter, so I just wanted to make sure i wasn't doing anything extra.
Old May 27th, 2014, 03:03 PM   #11
I know the sprocket covers swap. Forks and triples are different but may still swap as a whole similar to the J-bike ('08+) complete swap on a F-bike ('88-'07).
[motorcycle.com] - Gogoro Smartscooter and Battery Swapping Infrastructure Announced Ninjette Newsbot Motorcycling News 0 January 5th, 2015 02:40 PM
swapping brake calipers james250ninja 1986 - 2007 Ninja 250R Tech Talk 4 October 5th, 2013 08:08 PM
Bike swapping for a week kcaja1 General Motorcycling Discussion 11 September 13th, 2012 10:15 PM
Swapping rear shock w/ SV650? Key007 2008 - 2012 Ninja 250R Tech Talk 3 June 24th, 2010 06:37 PM
Swapping only the front sprocket. Obsidian 1986 - 2007 Ninja 250R Tech Talk 21 June 26th, 2009 10:22 AM
