Old June 3rd, 2016, 07:36 AM   #1
britx303
Motorcycle(s): TOOOOOO MANY!!
Shock swapping fitment?
Do zx6 shocks,or similar MW bikes shocks fit? Or better way to ask.....what shocks have you fit without issue? I need middle of the road since this bike will be for a loaner/backup racebike.Thanks
britx303 is offline   Reply With Quote
Old June 3rd, 2016, 07:54 AM   #2
Ghostt
Ghostt's Avatar
I run a ZX600 in mine, direct bolt on item, http://faq.ninja250.org/wiki/Installing_a_ZX600_shock
But the most popular swap is on from a NewGen Ninjette, which is another straight swap, bolt on,
http://faq.ninja250.org/wiki/Install...k_on_a_Classic
There's other options, http://faq.ninja250.org/wiki/Rear_suspension_upgrades
violente et ignorantia
ZX-2R BLOG
Old June 3rd, 2016, 05:00 PM   #3
britx303
Thanks. I forgot about that other site with info on it
Old June 5th, 2016, 07:12 AM   #4
spent_too_much
spent_too_much's Avatar
I have used both of the new-gen 250 and 300 shocks - direct bolt in. I don't race, so I am unsure if they will provide the results that you are looking for.
Old June 5th, 2016, 07:49 AM   #5
Ghostt
Ghostt's Avatar
I've recently also installed a pair of BIG BOY LIFT LINKS it raises the back up about an 1 1/4" and helps make the turn in quicker.
Why you ask do they do that? Well they do something similar to the famous FOG BONES for the EX500.
Here's an much better explanation by FOG himself, of how/why they work for the EX500, taken from his market place on said EX-500.com FOGBONES for sale
I have been responding to inquires lately they ask "what FOGBONES do". So I thought this would be a Good place to put an explanation.
The Bones replace a suspension link and raise the rear of the bike about 1 1/2" at the grab handle. Why? These parts change the angle of the Swing Arm to put it more in line with the torque reaction of the tire, this reduces lift under hard drives,also they reduce the fork rake Angle and shorten the trail. these two changes quicken the steering and cause the bike to turn with less counter steering input. Finally braking is much improved by the greater weight shift to the front wheel (which does 90% of the braking). Ground clearance is improved as well allowing increased lean angle. I have added a slight bulge in the center to accommodate the slightly larger springs from the after market.
I developed this product during my long and successful race career (I quit before I was crippled ....too much)
Installation is a simple bolt off/on process that uses only hand tools and a jack or center stand.
I keep 2nd gens in stock and make 1st gens up special to order.
FOG
I'm assuming that the principal is still the same, as the geometry is similar, and I'm happy to report that the BCB BONES do in fact accomplished this.
ZX-2R BLOG
Swapping parts james250ninja 1986 - 2007 Ninja 250R Tech Talk 10 May 27th, 2014 03:03 PM
swapping brake calipers james250ninja 1986 - 2007 Ninja 250R Tech Talk 4 October 5th, 2013 08:08 PM
Bike swapping for a week kcaja1 General Motorcycling Discussion 11 September 13th, 2012 10:15 PM
Swapping rear shock w/ SV650? Key007 2008 - 2012 Ninja 250R Tech Talk 3 June 24th, 2010 06:37 PM
Swapping only the front sprocket. Obsidian 1986 - 2007 Ninja 250R Tech Talk 21 June 26th, 2009 10:22 AM
