Old September 6th, 2019, 09:19 AM   #1
Kowalski
Kowalski's Avatar
Motorcycle(s): 2014 Ninja 300
Dragging pegs with risers
Anyone else still dragging their pegs are installing Yoshimura risers on the highest setting?
I have my forks flush with the upper triple tree, a race tech shock that at its max length (328mm I believe) stock rear sets with Yoshimura risers on the highest setting and Rizoma pegs.
My pegs are still dragging. Just wondered if anyone here has had to drop the big bucks on vortex rear sets on top of risers.
Thanks in advance!
File Type: jpg 43641851-03C9-4959-91B7-3629850DB62D.jpg (106.6 KB, 17 views)
File Type: jpg 10A00E83-A160-4067-844C-48EDCD51A8FD.jpg (52.1 KB, 12 views)
File Type: jpg CA03B944-10BE-4C0D-8D28-B201B8757F6F.jpg (62.4 KB, 14 views)
Kowalski is offline   Reply With Quote
Old September 6th, 2019, 02:37 PM   #2
How much do you weigh?
Might need to upgrade fork and shock springs. I'm about 86-kg and use springs about twice as stiff as stock.
My Woodcraft rearsets place my pegs about same as yours, about 3cm up and back compared to stock. I also use shorter-than-stock folding pegs. So it’s actually plastic toe-covers on my boots that rub first just before pegs fold up slightly and touch.
Last futzed with by DannoXYZ; September 7th, 2019 at 12:31 AM.
Old September 12th, 2019, 10:22 AM   #3
tgold
Motorcycle(s): 2006 1050 Speed Triple, 2010 250 Ninja racebike, YZF320RR? Racebike
MOTM - Nov '15
I had guys on my endurance team that were up to 230 lbs and we didn't have an issue with dragging the pegs. Our aftermarket rearsets were nothing unusual as far position goes, so that shouldn't be an issue. My bike was pretty light as far as ninjettes go at around 290 lb. Stock ride height with correct spring rates that took into account the lighter bike weight. I'd say either your spring rates are way light or you need your ass off the seat a lot more in corners. Something ain't right.
tgold is offline   Reply With Quote
Old September 12th, 2019, 12:24 PM   #4
OG Peggrinder
Motorcycle(s): Ninja 400 ABS
I love this
of course.
OG Peggrinder is offline   Reply With Quote
Old September 12th, 2019, 01:13 PM   #5
Kowalski
Kowalski's Avatar
I’m around 150lbs with out gear. Fork springs are .8kg and the shock is a 8.5kg. According to racetechs calculator my rear spring is a little too stiff. I might need to get off the right side a bit more too. I’ll figure this out eventually. Just wondered if anyone else fought this issue.
Old September 12th, 2019, 03:59 PM   #6
Yeah, I had lots of rubbing in beginning, that's when I went to Woodcraft rearsets, then shorter folding pegs. Almost crashed couple times with solid-pegs jacking up back of bike.
As tgold mentioned, take look at how much you're actually leaning bike. Hanging off on inside can reduce bike-lean by 10-degrees or more. Have someone follow you on track and get video.
Last futzed with by DannoXYZ; September 13th, 2019 at 03:33 AM.
Old September 12th, 2019, 07:22 PM   #7
Kowalski
Kowalski's Avatar
Thanks for the input guys. There’s no shortage of things I could do better at the track. Just wondered if anyone else here has had to deal with this issue.
Old September 12th, 2019, 08:54 PM   #8
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Motorcycle(s): '09 250 SE 'Booger'
I was dragging 'em on my 250 with stock pegs and yosh risers. Dragged using woodcraft rearsets as well. Since cutting my woodcraft pegs down a section havent dragged since.
Cutting pegs gets you more clearance than raising the pegs.
Dave Wolfe is offline   Reply With Quote
Adjustable pegs: No need to modify Buell pegs anymore CZroe 2008 - 2012 Ninja 250R Farkles 8 July 2nd, 2014 08:25 PM
Passenger Pegs & Brackets, Rider Pegs 2012 250r GlassAnkles Motorcycle-related 2 March 7th, 2012 11:17 AM
DIY- Using the Passenger Pegs as Front Pegs kkim 2008 - 2012 Ninja 250R Tech Talk 33 December 6th, 2011 12:16 AM
Knee Dragging Raybot Riding Skills 31 October 11th, 2010 09:33 AM
Dragging Toes Broom Ninjettes At Speed 22 October 6th, 2010 03:42 PM
