Old August 3rd, 2020, 06:49 AM   #1
Flair14
Motorcycle(s): 1993 EX250
Something leaking in exhaust
My old ninja has developed a leak (I think coolant) that forms on the exhaust pipe. The leak is on the right exhaust pipe right behind the radiator. The leak is facing towards the engine and it smokes lightly after a short ride.
Since it is smoking, I assume it isn't oil or gas leaking but what do I know.
Any idea what this could be and how do I fix it?
Flair14 is offline   Reply With Quote
Old August 3rd, 2020, 07:44 AM   #2
Hi Len and Welcome to Ninjette!!!
Finding leak is easy:
1. clean off all signs and smears of leak, if you have to take off bodywork leave it off
2. warm up bike and go for short ride
3. come back and leave bike running
4. go look at exhaust pipe and see what's dripping and where. Might help to hold pieces of paper over exhaust to catch leaks and make droplets more visible. Follow drops upwards to find leak.
Fixing leak, may be more difficult.
Old August 3rd, 2020, 06:28 PM   #3
Welcome Len!
Radiator hoses first.
Check your oil, ensure no gas is not getting to the oil.
Check your radiator cap, and routing of the res overflow drain tube.
I hope it's something simple.
Good luck!
Old August 4th, 2020, 02:33 PM   #4
Ceeloo Yello
Motorcycle(s): 250
Don't forget the o-ring on the hard pipe too.
Old August 20th, 2020, 03:22 PM   #5
Flair14
So it looks like the gasket for the valve cover is failing.
I'm trying to order a new gasket but having difficulties locating it online. Is this part number 11009?
While I'm there, I might as well replace the 2 small gaskets around the spark plug holes. Is that part number 11009a?
Old August 20th, 2020, 07:25 PM   #6
Ceeloo Yello
Motorcycle(s): 250
See below
Old August 20th, 2020, 07:29 PM   #7
Ceeloo Yello
Motorcycle(s): 250
Wait actual part #s
11009-1574 Cylinder head gasket (1 required)
11009-1575 Just says gasket (2 required)
Bike sat, cleared carbs, leaking gas from exhaust Proteus 2008 - 2012 Ninja 250R Tech Talk 9 July 26th, 2018 09:57 AM
Gas leaking from muffler clamp that connects to exhaust. james250ninja 1986 - 2007 Ninja 250R Tech Talk 15 February 24th, 2017 12:15 PM
something is leaking... help benferry 1986 - 2007 Ninja 250R Tech Talk 18 September 6th, 2015 11:46 AM
Coolant leaking into oil and oil leaking out of somewhere. Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 31 May 25th, 2013 04:09 PM
Exhaust smoking/leaking gas Daks 1986 - 2007 Ninja 250R Tech Talk 8 December 7th, 2012 01:05 PM
