Old August 7th, 2020, 06:27 AM   #1
ssrsupermoto
Motorcycle(s): 2004 Ninja 250
Let's talk jet kits
I have a 2004 ninja 250. I have JRE slip on dual exhaust. Currently I have stock jets with dyno jet needles. I have a 2-1 muzzy system on the way, and I want to know is the Dyno jet kit a good kit to use or should I spring for the Factory pro jet kit. I would assume I would have to use the bigger main and pilot jets from my dyno jet kit after I install the 2-1 muzzy system. Also I am running a stock air box with a Uni drop in filter.
ssrsupermoto is offline   Reply With Quote
Old August 7th, 2020, 10:12 AM   #2
Your existing DynoJet kit should be fine.
2-1 exhaust optimises mid-range and loses high-end. Similar to powerband of new-gen. So you’ll most likely want to go with smaller main jets, raise needles 1-2 clip positions and perhaps unscrew pilot 1/4-1/2 turns out. Will need to do dyno-testing and/or wideband datalogs before & after to fine-tune. Most important part of optimal tuning is gathering objective quantitative AFR data.
Old August 7th, 2020, 03:32 PM   #3
Ceeloo Yello
Motorcycle(s): 250
I've always had success ordering from jetsrus.com.
K&n air filter and dynojet jet kits Tbruenger 2008 - 2012 Ninja 250R Tech Talk 4 March 2nd, 2017 02:57 PM
jet kits? bamaland 1986 - 2007 Ninja 250R Tech Talk 4 September 9th, 2010 01:14 PM
Discounted DynoJet Jet Kits - $69.95 g21-30 Motorcycle-related 5 May 26th, 2010 08:52 AM
Jet kits wellcraft 2008 - 2012 Ninja 250R Tech Talk 15 January 27th, 2010 08:22 PM
Jet Kits CrzyFstMnM 2008 - 2012 Ninja 250R Tech Talk 6 March 6th, 2009 09:15 AM
