Old August 25th, 2020, 11:30 AM   #1
ssrsupermoto
Motorcycle(s): 2004 Ninja 250
Front tire cupping issue
My front tire has 6k miles still tons of life but it is cupping. Tire pressure is checked before every ride. Its a Bridgestone Battle axe BT-45. Forks are 12mm above the triple trees. I did install the .95kg sonic springs and added 15wt fork oil using the Motion pro fork oil tool so i know the fluid level is dead on and my fork are not leaking. What can I look for that can cause this.
ssrsupermoto is offline   Reply With Quote
Old August 25th, 2020, 12:56 PM   #2
It's not necessarily unusual to see something like cupping on a front tire with 6,000 miles on it. Can you post a photo of what you're seeing? My BT45 front is getting fairly worn now, and has a sort of sawtooth wear, with a ramp up to each diagonal tread groove.
Old August 25th, 2020, 01:54 PM   #3
ssrsupermoto
That's exactly what mine is doing. Just kind of surprised since my last 4 sets of shinko's never did that, and as soon as I get a decent Bridgestone it does this.
Old August 25th, 2020, 06:30 PM   #4
My OEM BT-45 front-tyre did that too. I suspect it has something to do with the small tread blocks. Replacement Shinko with larger tread-blocks doesn't seem to do it.
Old August 25th, 2020, 08:13 PM   #5
I don't know that it's a problem, just a normal wear pattern. The supermoto guys around here run a front BT45 on both the front and rear of their bikes at the track.
Old August 26th, 2020, 04:31 AM   #6
ssrsupermoto
Anyone else that ran the Shinkos feel like they could corner harder with the Shinkos then the Bridgestones?
Old August 26th, 2020, 05:30 AM   #7
Which Shinko tires did you use?
Old August 26th, 2020, 05:53 AM   #8
ssrsupermoto
I used the Shinko SR740/741
Old August 26th, 2020, 08:25 AM   #9
Thanks. I've heard good things about Shinko tires, but have always used BT45s on the 250. I know guys who do track days on those and have trusted them. I wish there were an easy way to compare real-world traction between the Bridgestones and the Shinkos.
I've read on forums that wet traction is better with BT45s than Shinko 740 and 741. When I got my 250 it had a Kenda Cruiser on the front and it wouldn't do a stoppie. With a BT45 it will.
Old August 26th, 2020, 04:51 PM   #10
I don't push it anywhere near hard enough to notice difference on streets. Both will let me scrape pegs and exhausts, which is faster than I should go on streets.
Old August 26th, 2020, 04:53 PM   #11
I guess I should take my street-bike to track-day at Thunderhill and get some lap-times. But it wouldn't be fair comparison as BT-45 times were on 5-yr old OEM tyres when I started at track. I'm much faster now and Shinkos would be 1-yr old...
I think both tyres have sufficient traction to go way, way too fast on streets. I think you're more likely to run out of good-judgement and skill before reaching limits of these tyres.
Front end squirrel - tire issue? wendyjboss General Motorcycling Discussion 16 May 13th, 2016 06:54 PM
Tire Cupping/Feathering Old Guy on a '08 2008 - 2012 Ninja 250R Tech Talk 3 October 5th, 2012 11:47 PM
Possible Tire Wear Issue? Zyconic17 Ninjettes At Speed 6 March 23rd, 2012 09:07 PM
tire clearance issue randomwalk101 2008 - 2012 Ninja 250R Tech Talk 17 August 12th, 2011 09:19 AM
tire upgrade question: front tire? stryder 2008 - 2012 Ninja 250R Tech Talk 1 April 5th, 2010 07:40 AM
