Old April 16th, 2013, 07:02 PM   #1
broken neck
Motorcycle(s): 2011 Ninja 250R Special Edition (sold), 2017 CRF250 Rally
Fork Seal Leaking
So they're leaking again.
I'll start from the top.
First, I've bought some race tech gold valve and race tech spring. I have a friend that repair motorcycle as a living, so he did the installation for me.
He put some new fork seal when he put the fork back on the bike. But they started leaking a short time after the rebuild.
He said, sometimes you can get a set of bad seals, so he took the back the bike and change the seal again.
Then, they started leaking again, he was very puzzled, but said nothing, took the bike back again, he even bought a new tool to install the seal (he thought it could have been the problem since he had it for quite sometime).
I rode it a bit after the change and winter came...
I took the bike out since its riding season again...
Someone came to see my bike tonight and he noticed that the seal was leaking. What, again?
So, can you help me figuring out what could be the problem.
Bad installation? My friend is very meticulous...
Bad seal? He uses OEM ones.
Too much oil in the fork? I have to check back with him to know how much he put and if he calculated the height with the spring and the valve inside.
Other idea?
Once I'm here. Since I'm a francophone, I might have some trouble understanding technical stuff that might gets complicated, like figuring out how to calculated the relaxed preload and actual preload. Why do I need to calculate that? Does it have to do with the recommended preload for my weight?
Since we all own Ninja 250R, we should have the same relaxed preload and actual prelaod? If we both use race tech spring. Did someone calculated it already? Once we know that number what do we do with it?
Sorry for all of those questions, but if I could get my fork set right and if i could solve the leaking seals, it would make life a little better.
If I'm all wrong about the preload thing and if you're patient to write something very "newbee proof", I'll be more than happy to read it.
Once again, thanks for your patience and help.
broken neck is offline   Reply With Quote
Old April 16th, 2013, 07:11 PM   #2
Lychee
sail away
Lychee's Avatar
try another mechanic?
Old April 16th, 2013, 08:46 PM   #3
The first DIY on here was by a guy who had a burr or something causing his. Factory defect. You may have one as well.
Also, are the tubes pitted?
Old April 17th, 2013, 04:32 AM   #4
broken neck
I'll him to take a look, but the "original" seals were fine before he installed the race tech components and before putting the last set of seals, he inspected the tube to be sure nothing could damaged them. But I'll ask him to check them again.
Thanks for your input.
As for changing the mechanic, it's an option. I'll let him go through everything again, since we're not fully bilingual, he might a misinterpreted something in the instructions.
Old April 17th, 2013, 05:59 AM   #5
Originally Posted by broken neck View Post
S..........So, can you help me figuring out what could be the problem.
Other idea?
Thomas,
I would say seals and installation are not to be blamed after the second occurrence.
The problem may be in the surface of the forks on which the seals slide.
The way these seals work:
There is a delicate lip of neoprene that needs to keep certain level of pressure over the sliding surface to avoid the internal pressure of the oil to induce a leak.
That pressure comes from an annular spring (not always) and the geometry and flexibility of the lip of the seal, which uses the internal pressure to proportionally create more lip pressure.
They most achieve a balance between flexibility to conform to the surface and rigidity to stand the high internal pressure.
http://www.motoobsession.com/MO_Tech...l-leakage.aspx
Now, if the sliding surface is not smooth (dents, scratches, grooves), some oil will escape under the lip and through the valleys of those imperfections (which at the same time will erode the lip).
Also, if the tube of the fork is not perfectly round, the seal will have a hard time following that geometry (remember, their flexibility is limited by the structural rigidity) and leaks will occur.
Forks that are bent, or that have been bent and straighten up are not perfectly round anymore.
Luckily, that is an easy measurement to do with a caliper.
Old April 17th, 2013, 10:11 AM   #6
broken neck
Thanks Hernan,
Very interesting articles.
I never gave attention to the "out of round thing" or the "over worn components", since the bike is almost new (6 000 km about 3750 miles on it), I bought it new. I've laid it down, never been involved in a crash, so the fork should be still good for sealing.
But, it could happen, I'll talk about it tonight when I'll drop my Ninjette at my friend's loft.
Could we get the tube out of round just be disassembling it?
Thanks again,
Old April 17th, 2013, 10:38 AM   #7
..........Could we get the tube out of round just be disassembling it?
Thanks again,
No, the tube is really strong and it takes a good fall or crash to deform it; hence, it is not probable in your case, but worth verifying it.
Look for fork's surface blemishes.
You are welcome
Old April 17th, 2013, 10:53 AM   #8
tooblekain
tooblekain's Avatar
Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike)
check for pitting on the chrome tubes and for roundness and make sure they are not bent.
Make sure the lowers/sliders are not bent and have no dirt.
*CVMA #312*SoCal Trackdays*BigHeadz Racing*Motion Pro*Factory Effex*Leatt Brace* Racetech *Bell * Woodcraft CFM*Vortex*Hotbodies*Surface Sun Systems*Braking*LiveWire Energy*Freegun Underwear
tooblekain is offline   Reply With Quote
Old May 16th, 2013, 07:20 AM   #9
broken neck
A little update,
After looking at them more carefully, we think it's the chrome plating that is worn out. When we pass our hands on the upper tube, we can feel very small streaks runing up and down the tubes and allround them.
We'll try to get an estimate to have them rechromed vs. new OEM tube.
We are very surprised finding these wear marks on such a low mileage motocycle...
Thanks for the hints on looking at the finish of the upper tubes...
Old May 16th, 2013, 07:58 AM   #10
cuong-nutz
cuong-nutz's Avatar
Could just pick up an used set instead of just buying new.
HalfFast Racing Team
Old May 16th, 2013, 08:39 AM   #11
......We are very surprised finding these wear marks on such a low mileage motocycle...
http://faq.ninja250.org/wiki/Can_I_g...ors/gaiters%3F
Buds' guts are very corrosive
Old May 16th, 2013, 10:01 AM   #12
broken neck
Well, buying those used could be a head or tail decision, will they last 5 years, 4 months or 3 days?
Having them rechromed might give me the confidence that they will last longer.
Buying new, could give the same confidence, but being desapointed by OEM, It might always in the back of my mind...
Old May 16th, 2013, 10:04 AM   #13
broken neck
Originally Posted by Motofool View Post
I gave a thought about getting "gaiters", but this would bring me back in my early days of mountain biking, when every forks wore those...
Excuse me, but I think my french canadian side don't get the "bud's gut" thing... héhéhéhéhéhéhéhéhéhé...
Old May 16th, 2013, 10:11 AM   #14
Smile
......Excuse me, but I think my french canadian side don't get the "bud's gut" thing... héhéhéhéhéhéhéhéhéhé...
Tripes insectes écrasés
Old May 16th, 2013, 10:34 AM   #15
broken neck
Ohhhhhhh...
You meant "Bugs" instead of "Buds"... Now I understand... I tried to figure out what budweiser guts would mean...
Old May 16th, 2013, 10:37 AM   #16
Sorry, my fault
Old June 2nd, 2013, 11:40 AM   #17
broken neck
Another update on my fork tubes,
Finally, the guy at the chrome shop said that the chrome was to thin to be "rechromed".
I didn't want to put new tube in there, to expensive for the moment.
So I went to a bike shop and the fine sanded the tubes. They came out great...
We put new everything in there, oil seals, dust seals, inner and outer bushings. After two weeks and almost 1 000 km, nothing is coming out of there. Just have to figure out what to do to get my fork work properly with the race tech springs and valves.
Hope this will conclude my leaking fork for a long while...
Leak on right fork seal AmyF 1986 - 2007 Ninja 250R Tech Talk 17 July 11th, 2014 09:29 AM
right fork tube seems to be leaking.. NinjaBoyEddy 2008 - 2012 Ninja 250R Tech Talk 1 November 18th, 2013 04:36 PM
Fork Seal is Stuck eddyble 2008 - 2012 Ninja 250R Tech Talk 7 October 21st, 2013 04:14 AM
OEM Brand New Fork Oil Seal, Dust Seal (08-12) capriccio Motorcycle-related 3 June 9th, 2013 05:11 AM
Leaking fork seal? EthioKnight 2008 - 2012 Ninja 250R Tech Talk 12 March 6th, 2012 09:20 PM
