Old August 5th, 2013, 11:34 PM   #1
cokatominnesota
Question Fork Seal Size Clarification
Okay I have been googling the freak out of this one, can't find any official information.
On the pre gen wiki they recommend the K&L fork seal, but dont give a part number or dimensions. So I have been looking around and there a couple other brands that come up: pyramid (I already have personal trust issues with anything associated with pyramids) all balls, kn, and some others. Some of these other brands have some bad reviews, I had recently installed some "leak proof" and already got a leak, my mechanic said I should try something different this time. I like the price of the K&L's and that they are recommended by the wiki, but for some reason the K&L brand is not linked up with ex250f. Or any ninja from what I can tell, so anyways...
I'm 99% sure that the size I need is 36-48-11, but I'm looking for some solid proof, or some kind source. Those are just the numbers I found on a couple different threads from a couple different forums.
The other size that comes up is 36-48-10.5 it doesn't come up very often but it does. And I'm pretty sure it's not for the ex250f.
What do I really need? Why are these numbers so illusive? Looking to order asap, so if someone could get me some official numbers that would be great.
Also If someone can give me a source or something so I message whoever runs the pre-gen wiki to add that on there or something because this is ridiculous. I shouldn't have to go to a official K&L dealer, to figure this out, or call one, I already would have if If I had started researching earlier but o well
Thanks
Colton
PEACE!
cokatominnesota is offline   Reply With Quote
Old August 6th, 2013, 07:36 AM   #2
Originally Posted by cokatominnesota View Post
..........Also If someone can give me a source or something so I message whoever runs the pre-gen wiki to add that on there or something because this is ridiculous. I shouldn't have to go to a official K&L dealer, to figure this out, or call one, I already would have if If I had started researching earlier but o well
Like any other hydraulic seal, these numbers are the diameters (ID and OD) and the width, in mm.
This seal is Kawasaki part 92049-1226
The dimensions are 36 x 48 x 11 mm
http://www.ronayers.com/Front-ForkF6F-C57751.aspx
According to this catalog (page 330):
http://www.klsupply.com/Home/2013KLS...QuickView.aspx
This is K&L part 15-2566
According to this table:
http://www.marshalldistributing.com/...ml#/391/zoomed
.......Vesrah part VAR3603
An example:
http://www.ebay.com/itm/NEW-K-L-FORK...-/110310812920
Now, if you have replaced seals and they leak again, don't blame the seal, if installed carefully, they all work alike and there are no bad and good while they are new (although the material the bad ones are made of become hard sooner).
Instead, check and correct the surface and roundness of the tubes:
http://faq.ninja250.org/wiki/Caring_for_your_forks
http://faq.ninja250.org/wiki/How_do_..._fork_seals%3F
Old August 6th, 2013, 05:17 PM   #3
cokatominnesota
thank you moto fool!
Old August 6th, 2013, 06:01 PM   #4
You are welcome, Colton
Leak on right fork seal AmyF 1986 - 2007 Ninja 250R Tech Talk 17 July 11th, 2014 09:29 AM
Fork seal size? Pyramid parts Graugaard 2008 - 2012 Ninja 250R Tech Talk 3 March 6th, 2014 05:41 PM
OEM Brand New Fork Oil Seal, Dust Seal (08-12) capriccio Motorcycle-related 3 June 9th, 2013 05:11 AM
Fork Seal Leaking broken neck 2008 - 2012 Ninja 250R Tech Talk 16 June 2nd, 2013 11:40 AM
Leaking fork seal? EthioKnight 2008 - 2012 Ninja 250R Tech Talk 12 March 6th, 2012 09:20 PM
