Old September 27th, 2011, 07:07 PM   #1
ninjaman
Motorcycle(s): 2008 250r
Problem - low oil?
i bought a used 2008 250r
i went to go look at the oil level and it was empty. did this when it was cold for a several hours.
i went to look under the bike and there is a clear hose that is hanging down that seems to be cut somehow. it runs parallel to a black hose.
the clear hose is oily so it looks like thats how the oil got out.
anyway, what could have happened?
have i hurt the bike irreparably riding it twice around the block since i bought it and revving it with no oil?
i did see this when the bike was cold after having been off for several hours. the oil window is completely empty.
how do i fix this going forward?
ninjaman is offline   Reply With Quote
Old September 27th, 2011, 07:11 PM   #2
Skippii
Milkshake Drinker
Skippii's Avatar
All the bikes all have lots of random hoses not connected to anything (carb vents, gas tank vents, etc). The oil level needs to be checked with the bike on level ground, straight up (NOT on the side stand or it will look empty) after running the bike breifly and then turning it off.
"What a sweetheart."- ninja_sleeper to me
Old September 27th, 2011, 07:12 PM   #3
00NissanNinja
I hate driving...
00NissanNinja's Avatar
Motorcycle(s): 13 Triumph Street Triple R, 09 Ninja 250r (Sold 4/20/12)
Did you look at the oil sight glass with the bike stood up as though you were on it? clear hose is just an oil drain for the excess oil blow by into the airbox I believe...
09 ninja 2fiddy SE Driving slow things fast
00NissanNinja is offline   Reply With Quote
Old September 27th, 2011, 07:13 PM   #4
Skippii
Milkshake Drinker
Skippii's Avatar
If you didn't see oil at first, why did you just stand out in the cold and keep staring at it for several hours? It's not going to magically fill itself with oil...
Old September 27th, 2011, 07:17 PM   #5
00NissanNinja
I hate driving...
Old September 27th, 2011, 07:19 PM   #6
Gorilla25
Dakine...
Gorilla25's Avatar
Motorcycle(s): 2009 Ninja 250R (Sold) | 636 (hopefully soon)
Gorilla25 is offline   Reply With Quote
Old September 27th, 2011, 07:20 PM   #7
Make sure you are checking the oil level correctly, as Skippi pointed out. Are you sure that it's truly low?
Old September 27th, 2011, 07:25 PM   #8
ninjaman
Not gonna lie, that's funny. I'm kinda upset so it sounded like I stared at it for hours. Lmao.
But i meant after the bike had been off for hours.
Anyway, I will stand it up straight and then check it. I was trippin and even called the guy who sold it to me like wtf?
I have to chill. The clear hose hanging down directly under the bike is very wrong looking though.
Posted via Mobile Device
Old September 27th, 2011, 07:27 PM   #9
Have you read your owners manual? If not, do so. If you didn't get one with the bike, check out the sticky thread at the top of this tech section; there is a link to download a PDF version.
Old September 27th, 2011, 07:32 PM   #10
Gorilla25
Dakine...
Gorilla25's Avatar
and while you're at it, just go ahead and change the oil and filter. also check the brake fluid, brake pads, chain slack, and air filter. not sure how long ago general maintenance has been done, so you might as well get it done
Old September 27th, 2011, 08:21 PM   #11
OGjackafidy
OGjackafidy's Avatar
Motorcycle(s): Red 2009 Ninja 250r
The tubes are normal there for air intake I believe and the oil will look empty unless its stood up straight. If there is literally no oil in the bike riding it will irreparable damage the bike. The oil puts a thin layer around all metal parts so they never touch each other and if that is gone then everything in your engine will grind together including your transmission and it will be ruined
"The goal in life is to die young at a very old age"
" Four wheels moves the body, two wheels moves the soul'
OGjackafidy is offline   Reply With Quote
Old September 28th, 2011, 05:17 AM   #12
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
There's an "I overheated it" hose
A "Fuel bowls need to breathe so they don't explode" hose
A "tank vent" hose
A "tank overflow" hose
and I think there is one more I'm forgetting.
Should be a good five hoses dangling around under the bike.
None of which are clear.
http://www.ninjette.org/forums/signaturepics/sigpic2121_4.gif <Yeah, it's a 250.
LMFAO!
Weaksauce
ninja250 is offline   Reply With Quote
Old September 28th, 2011, 06:22 AM   #13
Apocolypze01
CBR? This is ninjaaaaaa!!
Apocolypze01's Avatar
Motorcycle(s): '97 ZZR250
That clear hose is the battery vent hose. The black hose is the coolant overflow hose. Running the bike without oil can sieze the engine, damage rods and a whole lot of expensive things.
Check the oil with the bike upright - not on it's side stand - on a level ground. To get the bike upright (if it doesnt have a centre stand), get a buddy to sit on it.
If you see the oil in the sight glass is milky, you have a leak somewhere. If you smell a burning smell (with the engine running), the head cover gasket might be gone.
Need more deets man
Apocolypze01 is offline   Reply With Quote
Old September 28th, 2011, 06:30 AM   #14
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
battery vent hose.
My battery has no hoses coming from it.
My bike has no clear hoses.
LMFAO!
Weaksauce
Old September 28th, 2011, 06:42 AM   #15
Apocolypze01
Maybe the vent hose is only for pre 08 models? Im not sure. ninjaman, does your battery have little plugs on top? In a row?
Old September 28th, 2011, 08:15 AM   #16
DaBlue1
DaBlue1's Avatar
As others have mentioned there are several hose on the bike that connect to nothing on the bike. It has been noted that some new gens have a long or short clear hose attached to the airbox. There are no hoses on the sealed maintenance free batteries installed on the new gens. This hose allows oil residue and condensation to drain from the airbox. The oil you see in the clear hose is there from a few things. 1.) If the oil filter is overly saturated with oil it will eventually drain off the filter into the airbox and out the hose. 2.) During operation of the bike, gases from the heated oil from the engine crankcase are drawn up into the airbox. The gases are re-burned by the carb, however the oil residue can be trapped by the filter and the insides of the airbox. 3.) Too much oil in the crankcase can also be pulled up into the airbox also. 4.) Condensation can also accumulate inside the airbox during certain temps.
If the oil light turns off after the bike has started, it is a good indicator that you have a sufficient amount of oil in the bike. If the light flickers or stays on, turn off the engine then properly check the oil level.
Old September 28th, 2011, 09:57 AM   #17
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Ah yes they replaced that with a rubber cap instead of a hose on mine.
LMFAO!
Weaksauce
Old September 29th, 2011, 06:30 AM   #18
ninjaman
all the replies are much appreciated.
after standing the bike up, the oil in the window fills right up and looks golden.
its good and yes the oil light goes off when the bike is started.
the hose hanging down from the bottom seems to be the what dablue1 claims.
i called the guy who sold it to me and apologized too. lol. well i left a message..
anyway, all seems good.
thanks to all
this resource is priceless.
Old September 29th, 2011, 06:33 AM   #19
Apocolypze01
brilliant! glad it worked out for you
Low oil--->Killed engine--->What happened? recognize 1986 - 2007 Ninja 250R Tech Talk 18 February 6th, 2015 12:23 PM
what should i expect... (low/no oil) sixer 2008 - 2012 Ninja 250R Tech Talk 21 March 8th, 2012 07:34 PM
Oil level -- how low is too low? adouglas 2008 - 2012 Ninja 250R Tech Talk 8 October 18th, 2011 06:51 PM
Oil and Temp light on after low side dznuts 2008 - 2012 Ninja 250R Tech Talk 2 May 2nd, 2011 05:57 AM
Low oil pressure during braking Guinss 2008 - 2012 Ninja 250R Tech Talk 11 May 29th, 2010 08:47 AM
