Old February 23rd, 2014, 05:57 PM   #1
iflylow
Motorcycle(s): 2007 250r
Vacuum leak maybe?
My 2006 250 has an extremely hard time getting started when it is cold. When I do get it started I have to run the bike for about 15 min before the bike will idle. At this point the bike is hot and if I shut it off it I have to wait about 10 min before the bike will run again. I have cleaned the carbs twice now and have checked the vacuum lines and the vacuum diaphragm on the side of the carb for any holes. Don't know what else it could be, is there something in the carbs to look for that might be causing this?
iflylow is offline   Reply With Quote
Old February 23rd, 2014, 06:04 PM   #2
Verify that your petcock is allowing the flow of 2 cc of gas per second into the bowls.
You may know that there is a little screen filter inside the supply hose, just by the carb, which needs to be clean.
Twist the throttle half open when trying re-starting while hot and then, report back.
Similar problem:
http://www.ninjette.org/forums/showthread.php?t=151871
Old February 23rd, 2014, 08:31 PM   #3
Have you adjusted the idle mixture screws, idle speed, and synced the carbs?
Old February 24th, 2014, 01:22 PM   #4
iflylow
So i have adjusted the idle mixture screws but have not figured out exactly what to do to sync the carbs. The fuel is flowing fine and the half throttle warm start does not work. When i cleaned the carb i didnt pull the black caps on the top off. Bike is still having the same issues.
Old February 24th, 2014, 01:47 PM   #5
agentbad
agentbad's Avatar
Did you clean the non-removable Choke jet pathway? Did you adjust your idle mix screws 2 1/2 turns out?
Sync:
http://faq.ninja250.org/wiki/How_do_...carburetors%3F
2005 ninja 250 vacuum leak/clog? fuel664 1986 - 2007 Ninja 250R Tech Talk 31 July 29th, 2015 06:53 PM
Vacuum hose cross caused leak Quick1 1986 - 2007 Ninja 250R Tech Talk 9 December 23rd, 2013 03:19 PM
Weak Vacuum ans008 2008 - 2012 Ninja 250R Tech Talk 3 November 20th, 2013 01:17 PM
2007 won't idle. Vacuum leak or something else? cookiebug79 1986 - 2007 Ninja 250R Tech Talk 23 September 30th, 2013 09:28 AM
Rear brake fluid leak (container leak?), any advice appreciated. deaddemon 2008 - 2012 Ninja 250R Tech Talk 5 November 6th, 2011 01:52 PM
