Old June 12th, 2013, 04:53 PM   #1
abhijitz
Motorcycle(s): Many Two Wheels ..
2007 Ninja 250 Service Manual
Anyone has a link to a service manual ? I need to check 2 things please ...
Thickness Spec recording of Clutch Metal Plate [Not the Friction Plate]
Orientation of Metal Plate .. which surface faces towards bike and which surface face away from the bike [towards installer, i.e. you]
Thanks !
[ex-AFM #828 | SMUSA #828 |
Sponsors : MotionPro | LeoVince | Insurrection Racing Gloves | QstarZ Laptimers
+ OEM Parts @ 30-40% OFF : Harry @ 1-877-437-1631,17 harry@hondaeasttoledo.com
abhijitz is offline   Reply With Quote
Old June 12th, 2013, 04:59 PM   #2
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Also I can't figure out what this part means. This photo is from the 2008 service manual.
Worlds fastest 250 ninja
Old June 12th, 2013, 05:03 PM   #3
abhijitz
Eric - are you referring to the "A" , "B" , "C" , "D" thickness? If so, i scratched my head on it and couldnt figure out what the manual is wanting us to check. The tabs will fit in either of the tooth spacing. The block sizes are different yes .... but what is the manual referring to being narrow & wider?
Ohh and the A,B,C,D,E,F gear marking table is for another reference. check Page 6-9.
All i did was align the U notch (2 on each friction plate) and install them. From the other 2007 DIY Clutch Install, the 2008+ do not have any "horse-shoe" stamping for orientation.
Old June 12th, 2013, 05:08 PM   #4
Racer x
Racer x's Avatar
I have new steels they measure 2.00mm thick. A stack is about 23.23 mm thick..
Old June 12th, 2013, 05:13 PM   #5
abhijitz
Ok - Are these OEM ? ... can you measure the friction plates as well. [when measuring friction plate, include the block]
It will take me 2 hours to reach home and upload the pictures and current measurement.
Old June 12th, 2013, 05:19 PM   #6
Racer x
Racer x's Avatar
Looks like 3 mm for new Barnett and the OEM
Old June 12th, 2013, 09:51 PM   #7
abhijitz
Found the manual. Looks like there is no mention of orientation of the face plate. Neither there is thickness spec for the plate. I will post my current specs in other thread.
Newgen Service manual, owners manual & tool kit Hero Danny Motorcycle-related 0 September 20th, 2014 07:29 PM
2007 and below ninja 250, NEW OEM rotor, Taillight integration, used: owners manual Runeknight95 Motorcycle-related 4 August 12th, 2013 03:02 PM
Need 08+ Ninja 250 Service Manual abhijitz 2008 - 2012 Ninja 250R Tech Talk 8 November 13th, 2011 10:58 PM
2007 service manual supplement slawson Items Wanted 2 May 7th, 2011 05:00 PM
