Old July 20th, 2013, 12:13 PM   #121
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
The turbo is to low to drain effectively. Originally I was going to use an electric pump. To move the oil. But space is so limited. I would rather not.
So I need to remake the header.
Worlds fastest 250 ninja
Old July 20th, 2013, 02:29 PM   #122
garth285
KAWASAKI GURU
garth285's Avatar
Yeah oil drainage is key to keeping a turbo happy.
I got a lead today on a 1999 ninja 250 but it need a bit of work and has 125k on the odometer!!!! But I may be able to pick it up for 2-300 bucks and then sink some money into it.
I have been lookiong for a place for race fairing, looks like airtech has some.
I'm wondering if I can swap a 08+ head on a 07 down engine. I really hate rocker arms lol....
Old July 20th, 2013, 03:54 PM   #123
Racer x
Racer x's Avatar
No you can't swap heads.
Old July 20th, 2013, 05:43 PM   #124
Racer x
Racer x's Avatar
New turbo location.
Old July 22nd, 2013, 06:10 PM   #125
Racer x
Racer x's Avatar
I got the new header half done. I still need to add the flange then mount the turbo and run all the oil lines. Then I can add the O2 sensor bungs. I can't add the sensor bungs untill I figure out the rest.
I also have most of the exhaust pipe done. But that is easy.
Old July 22nd, 2013, 06:27 PM   #126
mgentz
Board Member
nice.
Old July 23rd, 2013, 10:38 AM   #127
garth285
KAWASAKI GURU
garth285's Avatar
Looking good! I wont be to far behind you on the turbo build if I pick up this 250 this weekend! The wife would much rather me racing a 250 trying to go 120-130mph than my turbo busa going 220-230mph :-/
Old July 23rd, 2013, 09:34 PM   #128
Racer x
Racer x's Avatar
Wait till she finds out how much work it takes to go 120 on a ninja250. You could go 250 mph on a Bousa.
Old July 24th, 2013, 04:02 AM   #129
Racer x
Racer x's Avatar
Fitting the turbo is getting close. The turbo could hit the fender if I bottomed out the suspension. There are no bumps. But I don't want to take a chance. So I just need to shorten the runners. Just about 3/4 inch. And make the flange as tight as possible.
Old July 24th, 2013, 04:40 AM   #130
mheitman
Motorcycle(s): '04 919 / '08 250r / '95 xr100
Could you get that fender a little closer to the tire? - to give everything more breathing room.
mheitman is offline   Reply With Quote
Old July 24th, 2013, 04:45 AM   #131
Racer x
Racer x's Avatar
Ya
And I can go back to a 16 inch front tire. This is with the fork slid down in the trees. I don't think the fork would even compress this much. Really if this ever happen I would be crashed. This explanes the shape of the 2008 stock exhaust system. It gets tight at the head.
Old July 24th, 2013, 09:55 AM   #132
Racer x
Racer x's Avatar
I got the turbo side flange made up but not welded. Now I need to attach it to the runners.
Old July 24th, 2013, 02:08 PM   #133
FWIW, 16" wheel won't help a thing. The OD of the tire of a 17" and a 16" (assuming you're using stock sizes for the ninjettes) is within 1/4" of each other. The ID (rim size) just throws people off because one is bigger.
looking good eric!
Old July 24th, 2013, 03:18 PM   #134
Racer x
Racer x's Avatar
Ya I need 17 inch wheels for tire selection. I use race take off slicks from a 125 moto GP bikes.
The header is just stumpy now and everything is clear. I still have to squeeze in the two O2 sensors.
Old July 24th, 2013, 04:36 PM   #135
EMSRacer07
EMSRacer07's Avatar
thats going to be really hot for the o2 sensors. Idk if thats going to ruin them being so close
Old July 24th, 2013, 04:38 PM   #136
Racer x
Racer x's Avatar
I wondered about that. They are flush mount and don't stick into the pipe. Do you think I could put them on the outlet side of the turbo.?
Old July 24th, 2013, 04:46 PM   #137
EMSRacer07
EMSRacer07's Avatar
you could do that but the reason there is two to get two different streams pretty close to the head but putting them that close might fry them. I would ask matt. Maybe you can wrap them in header wrap but idk if that would help with the readings..... just keep them from baking.
Just ask Matt, I know he was really specific where he wanted us to mount them. Not to far down the stream where they wouldnt heat up correctly or fast enough. Too close would probably ruin them.
Old July 24th, 2013, 04:47 PM   #138
EMSRacer07
EMSRacer07's Avatar
you got a picture where u wanted to put them after the turbo?
Old July 24th, 2013, 04:50 PM   #139
Racer x
Racer x's Avatar
I just have about nine inch of exhaust coming out of the turbo.
Old July 24th, 2013, 04:58 PM   #140
garth285
KAWASAKI GURU
garth285's Avatar
I would run a single o2 sensor right out of the turbo... you will not get a measurement per cylinder but most all turbo systems and exhaust systems measure o2 downstream in the exhaust.
Only problem with your turbo outlet pipe is it it a little short and you may get a not so accurate reading with low load as you can have some air flow back in and throw off your air fuel reading.
If you cannot change the length of your turbo outlet pipe I would just place it about 4-6" away from the turbo exit so its close but not to close.
O2's can handle a bit of heat but you dont want to be to close and in your case you dont want to be to far.
Old July 24th, 2013, 04:58 PM   #141
Racer x
Racer x's Avatar
I sent Matt an E mail.
This is the location. 3.25 inch from the head.
Old July 24th, 2013, 05:03 PM   #142
Racer x
Racer x's Avatar
I can do a lot with the outlet pipe. But I don't want it to stick out. If the bike falls over . I don't want it to break the turbo off or bend the turbo. The FI system uses a seperate o2 sensor for each cylinder. I really would like to keep them seperate. The nitrous bike runs 1200 deg EGT.
Old July 24th, 2013, 05:04 PM   #143
EMSRacer07
EMSRacer07's Avatar
he said that would be ok? or u are waiting for what he says?
And down stream would have to be the option if it would be too hot that close to the head. But you need both o2 sensors in the stream otherwise it wont run right.
Old July 24th, 2013, 05:05 PM   #144
garth285
KAWASAKI GURU
garth285's Avatar
When I spoke to ecotrons I believe he said you can wire it or set it to only use one o2 sensor. you may have to just split the one o2 sensor plug to send the same signal to both cylinders ya know.
Old July 24th, 2013, 05:06 PM   #145
Racer x
Racer x's Avatar
I will try the head. I can easy add to the pipe. Or run with no sensor on pre written map.
Old July 24th, 2013, 05:07 PM   #146
EMSRacer07
EMSRacer07's Avatar
you could do that and just run the rich/race mode. It just wont have feedback from the o2 sensors but it will still self adjust to whatever fuel parameters you give it.
Old July 24th, 2013, 05:08 PM   #147
Racer x
Racer x's Avatar
Guys I Reallly appreciate your feedback on this. I know what to do. And what is needed. But getting it all to work and figuring it all out is challenging. Thanks.
Old July 24th, 2013, 05:08 PM   #148
EMSRacer07
EMSRacer07's Avatar
news to me.
Old July 24th, 2013, 05:15 PM   #149
garth285
KAWASAKI GURU
garth285's Avatar
Racer X. I would for sure figure out the o2 placement before running on boost, turbos are not kind when they dont get their fuel lol.
I need to convince you to buy a wideband at some point in time and wire that up to and get a more accurate reading! The narrow bands will do the job but not as well as a wideband.
Yes you do not need to run 2 seperate o2's since your exhaust will mix the 2 cylinders exhaust's together.... unless you have a odd issue, both cylinders should be putting out the same air/fuel its just like tuning a normal 4 cylinder bike where they only run 1 o2 sensor in the exhaust and all 4 cylinders are tuned as one pretty much.
Old July 24th, 2013, 05:18 PM   #150
Racer x
Racer x's Avatar
I will start fat that is always the best thing. E85 is also an option.
Old July 24th, 2013, 05:21 PM   #151
Racer x
Racer x's Avatar
I will also be tuning at Bikes built better in Horsham PA. They are very good with turbo bikes. They built the fastest 500 cc turbobike. It went 181 mph last week. I will definitely rely on then for tuning.
Old July 24th, 2013, 05:22 PM   #152
garth285
KAWASAKI GURU
garth285's Avatar
Good deal!
I dont know if the injectors will handle E85 but we will just have to find out! Gotta watch that duty cycle ya know. E85 will be a hot ticket to making the motors keep happy. I dont even run an intercooler on my 290hp busa and the temps all stay down with the E85 but I have a beef cake fuel system.
With low boost I think you can forget about an intercooler especially if your going to spray on top of it to keep temps down.
Good to hear they will be helping!!!
Project is looking great so far man, I'm jealoud your way ahead of me, I may have to wait til next year but I really want to get into some 250 fun lol.....
Old July 24th, 2013, 05:25 PM   #153
Racer x
Racer x's Avatar
Yes its all fun. I am just trying to get it running at this point. I will refine it, blow it up and make it better. That is how it works. Then if I acctually go fast. I have to start over and go faster.
Old July 24th, 2013, 07:55 PM   #154
lgk
I didnt do it but there was an option for connecting a single wideband and having it self tune.
Maybe there is a similar option for narrow band
Old July 24th, 2013, 08:24 PM   #155
Racer x
Racer x's Avatar
I just got an e mail from Matt about just that. Since I am still in the build phase. I will put sensor bungs everywhere.
Old July 25th, 2013, 02:24 AM   #156
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Eric, this all looks very good and I really hope you'll have the success you're looking for.
Maybe you think about using the o2 sensors only for setup the engine and while racing install the bungs instead.
And just only for information, since you also always think about camshafts. I found in the Kawasaki Performance Parts Catalog from 2008 that they'd use a camshaft for the intake with 310 degree duration for the ZX-10R (04-07, what does not mean that this high value must work with a twin also, but...).
Old July 25th, 2013, 03:40 AM   #157
Racer x
Racer x's Avatar
Thank you Roland .
For mile racing I can use a pre written map. But for Bonneville I really need the bike to adapt to unknown conditions at 5000 feet.
I will try both. The fun is in the testing.
The engine that is in my nitrous bike will go into this bike with just a change in compression.
Then I will have a real engine built for Bonneville. The builder will decide all the cam profiles and have then made. Land Speed racing is very specific. I just don't know enough about the salt to build an engine for it.
Old July 25th, 2013, 08:17 AM   #158
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Daaaaang you are handling the buisness!!! Me= drooling waiting to see numbers
Old July 25th, 2013, 08:54 AM   #159
Racer x
Racer x's Avatar
Me to. I am looking for three digit numbers.
This is the final header. Three tryes and I still have to add the sensor bungs. But the turbo is mounted.
Old July 25th, 2013, 09:29 AM   #160
garth285
KAWASAKI GURU
garth285's Avatar
Nice, hey what metal are you using for the headers? Stock manifolds cut or is that all new steel?
Turbo250.com - My Turbo Build Blog garth285 2008 - 2012 Ninja 250R Tech Talk 319 June 19th, 2015 08:04 AM
My 07 250 cafe racer build elephantman78 1986 - 2007 Ninja 250R Farkles 12 December 25th, 2014 07:09 AM
My Cafe Racer Build girlracer 1986 - 2007 Ninja 250R Farkles 17 December 2nd, 2014 08:14 AM
Racer X engine build thread Racer x 2008 - 2012 Ninja 250R Tech Talk 189 June 12th, 2013 07:34 AM
I want to buy or build an 08+ 250R racer. Seanslides Ninjettes At Speed 20 March 1st, 2010 07:34 AM
