Old June 30th, 2018, 10:41 AM   #1
Tefal
Motorcycle(s): Ninja 250r Go 2012
Project/rat bike 1st problem seized rear shock
So I got a 2012 ninja 250r (uk so fi model) last summer as a tempory bike after my superblackbird got written off in a crash
It was weird goin to such a small bike (never had anything below a 600) but at the same time it has been great fun having such an agile thing.
It was in a pretty bad state when I got it from a young lad in work, Chinese fairings (bad ones) dented tank and had been sat for a while so bit neglected.
After nearly 6 thousand miles of horrific abuse through winter including dropping it in the snow (these things are hilarious in the snow) which cracked the fairing and foot peg stay but it kept going and I got those sorted.
It's had a problem with the 32/62 fi error code on the subthrottle replaced that with one from a breaking bike (had to get it from Italy there's pretty much no second hand parts market for the 250 in the uk it seems) when I fitted it I removed the valve plates and cam as when the old one failed it held the bike at 6k rpm (an interesting experience lol).
If it ever fails again I'll just sit up a defeat for the fi light and remove the whole lot.
But the main problem now is its mot has expired but the rear shock is totally seized, it's effectivly a hard tall, but the poor thing did struggle on despite that for a long time.
Now sense says just scrap the bike especially as I'll be getting my new H2sx tourer in the next few weeks, but I've grown attached to this scrappy little bike and it will compliment the tourer and also be good for winter when I dont want a heavy and brand new bike in the uk weather.
Ridden this little beauty 200 miles across the country in a hurricane last year and a few times in horrible winter weather to see my gf, unpleasant especialy with the rear shock but it made it.
So I've decided that if it can be kept running for minimal cost then it gets to live I kinda owe it that.
I'm pretty good with my hands (aircraft electrician by trade) but have very limited space and tooling at home.
As I said second hand or aftermarket parts for ninja 250s are very hard to come by in the uk so I'm thinking the shock is going to need to be replaced with something else.
I've got a paddock stand for the swing arm but not sure if there's a good way to Jack the bike up to get the shock out without damaging anything (wood under the engine a safe bet?)
Also any recommendations on what to replace the shock with ideally minimal extra work, I weigh about 13 an a half stone so a fair bit heavier than the stock shock was intended for anyway. (Abour 190lb).
I'll get some pics up later in the week as I'm away from home atm.
I gave the bike its first wash since 2012 yesterday lol and sprayed some acf50 on everything that will need to come off so that should help with the corroded fasteners.
Thanks for any advice guys I can certainly see why you love these stubborn little bikes
Tefal is offline   Reply With Quote
Old June 30th, 2018, 12:01 PM   #2
Hi and welcome!
Yes, you can jack up with piece of wood under rear of engine. I've also hung rear-end with ratcheting straps from garage beam. Removed seat and wrapped around rear support bracket for seat.
Old June 30th, 2018, 12:47 PM   #3
Tefal
Hi and welcome!
Yeah if I was still back at my folks where they had an exposed steel girder int he garage I'd hang it off that but my little garage has a plasterboarded ceiling and I'm guessing crappy thin joists so won't risk that
I've seen posts on here abour gsxr and sv650 rear shocks which is the least work? I'm not too fussed on performance as the bike is pretty limited anyway.
Seen a yss shock on eBay claims its new from Italy for about 90 quid with shipping but the rest are all 200+ so nott sure i tust it legit.
Seen a whole standard rear shock, and all linkages/bolts for 30 dollars on us eBay but 90 dollars shipping lol
Old June 30th, 2018, 01:25 PM   #4
Plenty of rear shock upgrades using GSXR. These are the various permutations:
https://www.ninjette.org/forums/showthread.php?t=170747
https://www.ninjette.org/forums/showthread.php?t=59486
https://www.ninjette.org/forums/showthread.php?t=312237
https://www.ninjette.org/forums/showthread.php?t=276316
https://www.ninjette.org/forums/showthread.php?t=304178
Results seems to be mixed with many saying it's too stiff. Well considering those bikes are 40-50kg heavier than Ninjette, that makes sense. With your weight, it might work OK.
Last futzed with by DannoXYZ; July 1st, 2018 at 10:39 PM.
Old June 30th, 2018, 01:45 PM   #5
Tefal
Awesome the is mate, in future I suppose could always reaping it but given its done over 1k miles with zero movement (you can stand on the passenger pegs and bounce and nothing) anything will be an improvement
Old June 30th, 2018, 02:06 PM   #6
Tefal
https://www.m.ebay.co.uk/itm/YSS-REA...y=1&quantity=1
Think it's legit? Its a lot cheaper than the other yss shocks and I have heard of fakes
100 quid isnt too bad for a drop in aftermarket upgrade.
Old June 30th, 2018, 02:32 PM   #7
Looks like non-adjustable shock, so worse than stock even. People have reported good results with this shock: https://www.progressivesuspension.co...shock-kawasaki . There was special for $175, but no more.
Maverick showed some shocks coming out of Indonesia that looked very promising. Had preload AND damping adjustments. Then again, GSXR shock has all that for $20-30 from fleabay, but requires some minor mods to fit.
Old June 30th, 2018, 02:33 PM   #8
Old July 1st, 2018, 06:38 AM   #9
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
they have the progressive shock on Amazon. do they have Amazon in uk?i would gladly give my stock rear shock from red or green bike. just pay shipping(might be high though)
"trying not to get old"
Old July 1st, 2018, 06:40 AM   #10
maverick9611
MOTM - Feb '18
member bernawanfr can help on shock deal from indonesia. their prices are way lower
My craigslist special Rat Bike project Anomaly798 1986 - 2007 Ninja 250R Farkles 16 April 6th, 2018 10:19 AM
My ZZR250 RAT BIKE RBN Pictures 17 November 5th, 2016 01:26 AM
[motorcyclistonline] - Hodaka Super Rat: The Little Big Bike Ninjette Newsbot Motorcycling News 0 March 30th, 2016 08:00 PM
Replacing my rear shock with a newgen rear shock... ReDnEcK 2008 - 2012 Ninja 250R Tech Talk 4 September 10th, 2010 12:38 PM
1st Bike / 1st Ninja happening tonight! (7/21) Sloane Ranger New Members 14 August 20th, 2010 05:05 PM
