Old September 25th, 2012, 12:59 PM   #1
fierostetz
Motorcycle(s): klr 650, fz1, nighthawk 750, dr650, ex250
POD filter, rejet, carb sync... lots of vibration now?
I've had a tough time googling this; basically I rejetted after installing K&N pod filter; bike runs great, front end gets light when I whack the throttle open in the midrange (didn't used to do that!!) and I gained a few mph on the top end... anyways, I've noticed that I can feel the intake howl through the handlebars. I compared to my other bikes (kz1000, klr650) and I don't get a similar feeling, but it's a different bike. The carbs are perfectly synchronized and I'm getting the wacky additional vibration. It doesn't feel "bad", but I just want to run it past the collective here. Not super familiar with the ex250 yet... Thoughts?
fierostetz is offline   Reply With Quote
Old September 25th, 2012, 02:43 PM   #2
flynjay
flynjay's Avatar
The hard mounting of the engine to the frame makes the bike a little buzzy, pods make it a little worse.
What jets did you use and how many washers / needle position?
Old September 25th, 2012, 02:54 PM   #3
fierostetz
Thanks for the feedback; I suspected as much. Lost some low end torque (to be expected).
I used a factory pro jet kit, needle in the third position, 112 main jet, 40 pilot jet. Still need to do some tuning on the idle mixture (i dropped my shorty screwdriver at some point - argh!) but it starts with 20% choke, can turn the choke off immediately, and the bike can get rolling without me touching the throttle, or with a handful of full throttle; nice and responsive.
Old September 25th, 2012, 02:55 PM   #4
fierostetz
I'm going to re-balance, but I think this time I'll use alcohol instead of oil for the greater sensitivity. Oil got me into the neighborhood of correct, alcohol for fine-tuning.
FS: Motion Pro Syncpro Carb Tuner (Carb Sync) $60 Shipped menikmati Motorcycle-related 4 April 8th, 2020 12:39 AM
Valve adjustment, carb clean, carb sync? amad1972 1986 - 2007 Ninja 250R Tech Talk 2 July 29th, 2014 09:42 PM
rejet with open filter vmax 2008 - 2012 Ninja 250R Tech Talk 1 February 9th, 2014 02:40 PM
carb sync WELLS 1986 - 2007 Ninja 250R Tech Talk 4 September 19th, 2013 08:30 PM
Help please - carb sync? nixthewiz 2008 - 2012 Ninja 250R Tech Talk 4 September 7th, 2011 06:37 PM
