Old May 4th, 2014, 08:12 PM   #1
NinjaNoob23
Motorcycle(s): 2011 Ninja 250
Tach/RPM won't light up
I took my new (to me) 2011 ninja out tonight for a ride, problem is the tach and rpm does not light up. Only thing that was illuminated was the gas gauge (which is off by a lot, it has a full tank and the gauge says half a tank).I know this question is answered somewhere on this forum already, I just can't find it.
Any advice or links to point me in the right direction would be very very very much appreciated. I do a lot of night riding and would really like to have those. Getting the gas gauge correct would just be a bonus, not a necessity.
Only electrical done to the bike (that I know of) is a fender eliminator kit, which I don't think anything was really done because the brake and signals appear to be stock.
Thanks for your time,
Nick
NinjaNoob23 is offline   Reply With Quote
Old May 4th, 2014, 08:39 PM   #2
Originally Posted by NinjaNoob23 View Post
..........Any advice or links to point me in the right direction would be very very very much appreciated...........
This article is for the pre-gen, but may be helpful to you:
http://faq.ninja250.org/wiki/Replaci..._cluster_bulbs
Old May 4th, 2014, 09:00 PM   #3
NinjaNoob23
Thanks, I'll have to give it a try. It couldn't have been a fuse that's blown, could it? I hate to take the whole front apart if I don't have too.
Old May 4th, 2014, 09:28 PM   #4
NinjaNoob23
If anyone see's this thread and is looking to replace their bulbs, this may help. Also has some links to replacement bulbs.
https://www.ninjette.org/forums/showthread.php?t=64261
Old May 5th, 2014, 04:36 AM   #5
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
The Taillight fuse powers pretty much every light on the bike, including all the dash illumination bulbs. There's no fuse that would cause one of the dash lights to be out.
If they're that much of a pain to get to, I suggest switching to LED bulbs, so you should never have to touch them again.
Old May 5th, 2014, 04:00 PM   #6
NinjaNoob23
I just purchased some red LED's to go in the dash. I think I got the right ones, guess we'll find out. :roll eyes:
I'll probably do a "how to" thread when I do it. I can't seem to find a step by step tutorial on it. There are some people telling you how to do it, and threads of pics after it's done, but I haven't found one that was a step by step.
Old May 6th, 2014, 06:53 AM   #7
kennetht
kennetht's Avatar
Why did you get red LEDs?
Its really pretty simple, you just have to take the whole front end of the bike off (if you want to pull the gauge out). Otherwise, you just have to take enough of the front off to be able to get your hand up there to switch out the bulbs. I recommend just taking the whole thing apart, as is it much less of a pain to change the bulbs if you have the instrument cluster completely out of the bike. My bike looked like this when I did it.
Also, when you put the LEDs in, make sure you put them in the correct way. They can only go in one way. If you put it in, and it does not light, then flip the bulb around the other way, it should light.
This thread will help you out if you run into this problem:
https://www.ninjette.org/forums/showthread.php?t=172686
In regards to what bulbs to get, refer to this thread:
https://www.ninjette.org/forums/showthread.php?t=169472
In the end, your bike will look great once changed to LEDs like mine does:
kennetht is offline   Reply With Quote
Loss of Power, Won't go past 7k RPM denshidereku 1986 - 2007 Ninja 250R Tech Talk 38 March 17th, 2015 08:18 PM
Bike won't run above 5K rpm edward2014 1986 - 2007 Ninja 250R Tech Talk 12 October 30th, 2014 08:51 AM
Just cleaned carbs - now stuttering at low RPM, fine at high RPM Ohio 2008 - 2012 Ninja 250R Tech Talk 20 August 5th, 2014 10:30 PM
Tach/RPM gauge needle wobble spooph 2008 - 2012 Ninja 250R Tech Talk 4 July 2nd, 2014 09:34 AM
Won't run over 1k rpm bowerbird100 1986 - 2007 Ninja 250R Tech Talk 21 June 27th, 2014 07:00 PM
