Old January 26th, 2012, 10:31 AM   #1
ryanG19
ryanG19's Avatar
Motorcycle(s): 2012 Ninja 250r Candy Apple Lime
What do you think of this Clock/Thermometer Display?
Since I have already wired in my LED lights and socket (Here: http://www.ninjette.org/forums/showthread.php?t=94836), I wanted to get a LCD display with a backlight on in. My plan is to get this and wire the back light to the switch so that when I turn my lights on the backlight will light up. I think this will work. The display is on batteries and I was going to put it in the dash above the speedometer after chopping off the outlet and direct wiring it. The line is already 12v for everything else, so no worries there.
http://www.ebay.com/itm/3-1-In-Out-D...item4ab2563b10
What do you guys think? I just don't want to have to try and hit a backlight button on a clock to see what time it is at night.
Edit: Or this one http://www.ebay.com/itm/New-LCD-Scre...-/110795306346
Last futzed with by ryanG19; January 26th, 2012 at 11:05 AM. Reason: Add a URL
ryanG19 is offline   Reply With Quote
Old January 26th, 2012, 10:42 AM   #2
Slono
Slono's Avatar
Motorcycle(s): 2011 Kawasaki Ninja 250R (sold), 2007 SV650s (deer wrecked), 2010 Suzuki SV650S
That thing looks like it takes batteries too. Why would you need a 12V connection?
Slono is offline   Reply With Quote
Old January 26th, 2012, 10:44 AM   #3
ryanG19
ryanG19's Avatar
The backlight is powered by the DC adapter. So if I wanted it to light up at night, I'd need to hard wire it in.
Old January 26th, 2012, 10:50 AM   #4
Slono
Slono's Avatar
Oops I missed that, but I get it now
It should work, as long as you don't overload anything. Seeing as how you said you've got everything set up I think it would be an awesome addition to a clock-less dash / old skool dash. You'd probably want to waterproof it in case you get stuck in rain.
Old January 26th, 2012, 10:56 AM   #5
ryanG19
ryanG19's Avatar
Waterproofing was the only thing I am kinda worried about. Any idea how to do it?
Old January 26th, 2012, 11:06 AM   #6
Slono
Slono's Avatar
You could use rubber cement and coat the external interface and battery door with it. A more durable option would be to take the clock apart and coat it with Plasti-Dip. I used to own several RC cars and to make the electronic speed control completely waterproof I would take off the casing, coat the insides, put the casing back on and trim the excess. This works really well, but when I got into bigger cars I could only coat the outside because the internals would get too hot, and melt the coating.
But seeing that its only a small device this should work. You also could just coat the outside and cover everything except the display. It just means once the battery dies you'd have to take the Plasti-Dip off and re-apply.
[motorcyclistonline] - Riders Passion: Sport Bike Clock and Sport Bike Thermometer Ninjette Newsbot Motorcycling News 0 October 26th, 2010 01:31 AM
$15 clock/compass/thermometer subiegy2010 2008 - 2012 Ninja 250R Farkles 30 August 14th, 2010 06:55 PM
[tilted horizons] - Teltek Informer II Thermometer review Ninjette Newsbot Motorcycling News 0 January 30th, 2010 12:20 AM
Moto-fizz clock/thermometer & GPS Alex 1986 - 2007 Ninja 250R Farkles 9 July 16th, 2009 08:23 PM
Motofizz Clock/Thermometer Alex 2008 - 2012 Ninja 250R Farkles 6 January 20th, 2009 01:30 PM
