Old January 6th, 2020, 07:03 PM   #1
06CandyThunder
06CandyThunder's Avatar
Motorcycle(s): 2006 Ninja 250
Lightbulb Ammo can saddlebags
Hi all, I’m thinking about putting some ammo cans I have laying around to use, and mounting them to the 250 as cargobags. I found a picture of how I envisioned it but I’m not sure how to go about mounting it. Any input is always appreciated
File Type: jpg 4B6162C7-2010-4DDF-8FCF-AFDFEC26C374.jpg (161.0 KB, 37 views)
06CandyThunder is offline   Reply With Quote
Old January 6th, 2020, 07:51 PM   #2
Ceeloo Yello
Motorcycle(s): 250
I'm guessing you would bolt them on where the cargo hooks are.
Old January 6th, 2020, 07:55 PM   #3
SibSerge
Are not those heavy ? I have a few used for Win 308 they are small but they are heavy to the point that they will probably maxout the hooks rating on their own. Or yours are plastic ?
Old January 6th, 2020, 08:21 PM   #4
Snake
Snake's Avatar
Take the bolts out that mount the hooks and remove them. Then use some bolts of the same size but a bit longer to mount the cans.
Old January 6th, 2020, 08:36 PM   #5
Artruck
Motorcycle(s): 2007 ex250 (black), silver 2005 ex250 scrambler, 2003 ex250 donor bike, 2006 kymco people 250
The hooks come off and bolts thread into the frame in there place. You would need spacers to keep the cases off the bike. I would make a frame out of flat bar that the bolts pass through and use angle at the bottom to support the case. I would also triangulate the frame to the rear peg mounts. With those three points bolted to the bike, it will support the case.
You should then be able to run three or four bolts through the side of the case into the flat bar frame and use rubber washers and it should be good.
Artruck is offline   Reply With Quote
Old January 6th, 2020, 09:54 PM   #6
06CandyThunder
No, not plastic. steel i think. im guessing 5 lbs each
Old January 6th, 2020, 09:58 PM   #7
06CandyThunder
Probably going to do it this way. Thanks for the detail. Didnt know there were even bolts under the cargo hooks.
Old January 6th, 2020, 09:59 PM   #8
06CandyThunder
Thanks guys I’ll post pics when mounted
Old January 6th, 2020, 10:35 PM   #9
How much weight you plan on carrying will dictate mounting method. I second Artruck’s excellent idea of making metal frame. You’ll want three mounting points to prevent fatigue on brackets. Two top ones and one bottom one connected to lower frame rail. I would then weld or braze boxes to frame to make it all one-piece and simple.
G2 RIP Ammo .45 and 9mm garth285 Miscellaneous 0 December 8th, 2014 07:07 AM
Ninjette keeps changing.... Now an ammo box... peterpayne 1986 - 2007 Ninja 250R Farkles 12 November 9th, 2014 06:08 AM
Hard Saddlebags lowdown112 Cargo Space 8 July 27th, 2013 05:14 PM
Zombie Ammo??? dubojr1 Off-Topic 40 June 18th, 2012 07:15 PM
Saddlebags Yasko Items Wanted 0 December 21st, 2010 09:56 PM
