Old January 16th, 2020, 04:31 PM   #1
06CandyThunder
06CandyThunder's Avatar
Motorcycle(s): 2006 Ninja 250
Wiring Noob Question
Whats up guys I ordered an aftermarket 7 inch headlight because my fairings are shot and am in the process of making it a streetfighter (the stock rectangle headlight looks goofy to me)
How do I go about this- basically the stock headlight is 3 pronged, and basically plug and play to the 3 prong plastic clip.
The aftermarket circular one has wires and not the connector. What’s needed to make it fit? No experience in electrical stuff but this shouldn't be too difficult to figure out one someone explains it.
Added some pics so you can better understand due to my lack of electronics vocabulary—
pic 1 - the prong on stock headlight
pic 2 - the clip that goes to the stock headlight
pic 3 - no clip, just wires.
06CandyThunder is offline   Reply With Quote
Old January 16th, 2020, 05:53 PM   #2
Artruck
Motorcycle(s): 2007 ex250 (black), silver 2005 ex250 scrambler, 2003 ex250 donor bike, 2006 kymco people 250
You need a male h4 plug. Then just test the wires to make sure the right ones match up and the right lights come on, then solder the connections and wrap it up. I would get the kind that comes without being pinned into the connector yet, but 9003/H4 should do.
Artruck is offline   Reply With Quote
Old January 16th, 2020, 06:17 PM   #3
Ceeloo Yello
Motorcycle(s): 250
Here is the standard wiring:
Old January 16th, 2020, 06:34 PM   #4
Ceeloo Yello
Motorcycle(s): 250
Should be: Red/Yellow = Low Beam, Red/Black = High Beam & Black/Yellow = Ground.
If you are never going back you could just cut the wire and crimp on bullet connectors to match your new headlight.
Old January 16th, 2020, 09:15 PM   #5
That is strange light, does it have replaceable bulb? Take off rear cover and you may find H4 bulb that factory plug will connect to directly.
Male H4 connector at back of light is best solution. You can connect snd disconnect just one connector quickly without worrying about which wire goes where. This is high-power connection. You’ll want to solder AND heat-shrink wrap male H4 connector onto that light with butt-splic. This then plugs directly into factory connector. Generally gets you +10-25% more lumens out of bulb and ensures same performance for decades when done this way.
https://www.ebay.com/itm/174013713829
Cut off any connectors from back of light and butt-splice male H4 pigtail from ebay sbove on. Be sure to slide section of heat-shrink tubing on before joining wire-ends. You want joint with:
1. Mechanical strength, hence using lineman splice
2. Highly conductive, requires soldering
3. Durable and long-lasting, thus corrosion resistant heat-shrink tubing over joint.
It’s done this way in pro-motorsports like F1, military and aerospace applicstions for performance, reliability and longevity.
Old January 16th, 2020, 09:53 PM   #6
Even better as Ben mentioned is to use male H4 terminal kit:
https://www.ebay.com/itm/191893482825
Best to crimp, solder AND heat-shrink wrap those terminals onto headlight wiring. Then be sure you have correct wire before inserting terminal into connector. Can be difficult to extract to put into different location without damage.
Even for simple jumper, I’ll do it the NASA way.
Old January 21st, 2020, 05:17 PM   #7
06CandyThunder
Thank you gentlemen. I didn’t even know they sold that type of adapter. I didnt wana chop stock one just incase, which was my original idea. With that being said I’ll end up buying the adapter and get to work.
Hi guys. A noob question knivee14 2008 - 2012 Ninja 250R Tech Talk 6 October 19th, 2016 10:52 AM
Stupid noob question from a non-noob LNasty 2008 - 2012 Ninja 250R Tech Talk 13 March 21st, 2015 10:47 PM
Noob Tire question Harrison89 2008 - 2012 Ninja 250R Tech Talk 7 July 29th, 2012 06:07 PM
Noob Stalling Question ajcadoo Riding Skills 37 March 1st, 2012 03:42 PM
Noob question - regarding jetting Betlog 2008 - 2012 Ninja 250R Tech Talk 5 January 6th, 2010 02:24 PM
