Old May 6th, 2020, 12:19 AM   #1
kwakka
Motorcycle(s): Kawasaki & Suzuki
gpx 2002
thanks for having me, I am in West Australia/Perth, I have a GPX2002 Aus model and have recently stripped carbies and cleaned and re-fitted. Forgot to take pics of fuel tank hoses. Just finishing hooking up hoses and trying to follow my manual which appears to me to be different in subtle ways ? My questions are ; does my Fuel overflow hose run to ground ? my manual is saying it goes to a emission control cannister ?? I don't think I have such a cannister. And why does my radiator have a hose that runs to carby, what purpose does radiator fluid have in the carburettor ?? And should I retrofit a fuel in-line filter prior to the main fuel line entering carburettor? thanks to anyone who can help, great family of brother Ninjettes. regards
kwakka
kwakka is offline   Reply With Quote
Old May 7th, 2020, 05:46 AM   #2
59096
59096's Avatar
Motorcycle(s): GPX250 1989 model and 1990 model
kwakka
I have an Australian delivered 1990 GPX250 and my fuel tank overflow goes straight to the ground as there is no canister. There is no hose from the radiator to the carb. Wondering if it’s actually the pipe to the cooling system expansion/overflow tank you have somehow connected to the carb? An in-line filter isn’t a bad idea. I put one on mine.
Perpetua Culpa Alterna Vagus
59096 is offline   Reply With Quote
Old May 7th, 2020, 09:12 AM   #3
I think you got lots of hoses mixed up. How many ports/hoses comes off your tank? As far as I can tell, only CA models have 3 hoses coming from tank with an EVAP canister.
1. Small radiator hose beneath cap goes to bottom of coolant reservoir
2. Overflow, actually vent hose, from between carbs curves towards back and exits out next to shock next to drain hose from airbox.
3. Two tank hose goes to purge-valve which then connects to evaporative canister. I think in your case, these do not exist.
4. Third, or single tank hose in your case, connects to vent under gas cap goes down past shock and exits near airbox drain hose
On carbs, one vaccum port goes to petcock (orange). Larger hose from petcock goes to petrol-inlet on carbs (purple). Install inline filter on this purple hose.
Old May 7th, 2020, 04:30 PM   #4
kwakka
thanks guys, yeah I worked it out , my GPX250 does not have an evap cannister as my manual indicates and only has 1 hose fitting on the tank which is the vapour breather. The only other hoses from tank , run via the petcock. And worked out that the radiator fluid runs through the throttle housing to prevent freezing. And yes I will add a fuel filter, seems crazy they didn't come standard. Thanks to all who helped me on this thread.
gpx 2002 kwakka New Members 6 May 3rd, 2020 09:54 AM
GPX datalogger Yow Ling Ninjettes At Speed 4 March 29th, 2016 04:54 PM
91 gpx streetfighter tri501 1986 - 2007 Ninja 250R Farkles 9 December 10th, 2015 01:42 PM
GPX Pro TGRIFF Ninjettes At Speed 18 May 13th, 2014 03:28 AM
XT GPX Pro DCMoney 2008 - 2012 Ninja 250R Farkles 16 September 25th, 2013 05:40 AM
