Go Back   ninjette.org > 2013 - 2017 Ninja 300 > 2013 - 2017 Ninja 300 Farkles
Old April 4th, 2014, 05:28 PM   #1
Klondike1020
Intrepid Adventurer
Klondike1020's Avatar
Tank Pad Not sticking!
We put a new tank pad on my GFs 300 and we tried heating it up by putting it in a zip lock and submersing it in hot water to make it more flexible.
We stuck it on the tank and the edges of it seem to be coming loose and sticking up!
We washed the bike. Dried it and buffed it with a microfiber towel before applying the tank pad/
Does anyone know a way to make the glue more adhesive? and do you think using a hair dryer to help it flex and adhere to the tank is a good idea?
thats what it said on a slip the ebay seller included with the stick on pad.!
Its pink and has a ninja chick in it. so my gf really likes it! now we just need it to really adhere!!!
Breath deep, seek peace.
Old April 4th, 2014, 06:33 PM   #2
Yakaru
The Violet Vixen
Yakaru's Avatar
MOTM - Jun '16
this thread: http://www.ninjette.org/forums/showthread.php?t=173109 advises using outdoor adhesive if that helps
Old April 4th, 2014, 07:07 PM   #3
cbinker
cbinker's Avatar
did you wipe the area with rubbing alcohol?
TEAM ALFALFA
www.apexassassins.com
Old April 4th, 2014, 09:51 PM   #4
Klondike1020
Intrepid Adventurer
no I didn't! is that basically to make it cleaner?
I cleaned it very thoroughly but I think I screwed up peeling the paper off of the adhesive side. Also the pad was a little stiff so it didn't want to flex.
I think next time I will heat it with a hair dryer and clean the surface with alcohol !
I will just order another on Ebay.
oh well . live and learn
Old April 5th, 2014, 04:18 PM   #5
cbinker
cbinker's Avatar
when i put on my stomp grip, i used alcohol wipes to remove any soap or grease left from washing the bike it helps.
TEAM ALFALFA
Old April 5th, 2014, 04:22 PM   #6
antiant
antiant
antiant's Avatar
Motorcycle(s): None
MOTM - Oct '14
antiant is offline   Reply With Quote
Old April 6th, 2014, 09:25 AM   #7
Klondike1020
Intrepid Adventurer
Has anyone put a regular tank pad on a ninja 300??
I tried to do my best and the tank pad stuck ok at first but later the edges lifted where it had to bend over the ridges of the tank.
The ninja 300 tanks are shaped funny and really ruined my feeble attempt at adding a tank pad errrg
Old April 6th, 2014, 10:24 AM   #8
Floki
Motorcycle Nurse?
Floki's Avatar
Motorcycle(s): 2010 250R, 1998 Ducati 748L #77/100
Originally Posted by antiant View Post
+1 on this. Alcohols gets the wax off too which keeps it from sticking. Heat from the hair dryer makes the glue a little stickier/adhere better. No problems with my pad following this video.
Floki is offline   Reply With Quote
New Upgrades - Fender Eliminator, Tank Pad, Tank Overlay Stickers bbjminardo 2008 - 2012 Ninja 250R Farkles 7 March 22nd, 2013 03:51 AM
Homemade tank pad? Yakaru 2008 - 2012 Ninja 250R Farkles 1 September 15th, 2012 09:22 PM
tank pad qwkartist2000 2008 - 2012 Ninja 250R Farkles 5 November 28th, 2011 01:39 AM
Tank Pad saxnbass 2008 - 2012 Ninja 250R Farkles 6 November 12th, 2011 09:55 PM
Tank pad suggestions sofo 2008 - 2012 Ninja 250R Farkles 4 July 15th, 2009 08:42 PM
