Old July 20th, 2012, 06:36 AM   #1
Pretzel
Bike won't rev
Alright guys, my '07 is finally running, but when i go to rev it, it gets to about 2k and boggs out and dies. I had to adjust the needles because it was getting too much gas and wouldn't rev at all, but now I can gas it slightly before it dies. Taken the carbs apart n cleaned them MANY times, jets n all, replaced spark plugs, and just put a new regulator on it. HELP PLEASE!!!
Pretzel is offline   Reply With Quote
Old July 20th, 2012, 07:05 AM   #2
Mix is lean.
Have the valves been adjusted recently?
Old July 20th, 2012, 03:08 PM   #3
Pretzel
No I haven't messed with them. What do I need to do with em?
Old July 20th, 2012, 03:10 PM   #4
The valves need to be adjusted every 6K miles.
Learn how to do it yourself:
http://faq.ninja250.org/wiki/How_do_..._the_valves%3F
Old July 20th, 2012, 03:59 PM   #5
jcgss77
Its not a 250,its a Ninja
jcgss77's Avatar
Motorcycle(s): '11 CBR250R, '22 CFMOTO 300NK
^^^this. The valves are not hard to do, and definitely follow the ninja250 wiki. I only had to remove the coil on the right side of the bike because the cam chain took out too much room for me to work on the valves on that side. It says that opening up the valve clearances will increase noise, but in the case of the '04 bike I just got, it made a very noticeable DECREASE in noise. Also, most bike mechanics I have heard of will charge you a lot (read: too much) to adjust them.
jcgss77 is offline   Reply With Quote
Old December 24th, 2012, 09:01 PM   #6
AlfredoGonzalez
Freyho
Motorcycle(s): CBR600 f4i, 2007 Kawasaki Ninja 250 (sold)
Gas engines need fuel (fuel/air), spark, and compression... If the spark and compression are fine, go to fuel/air. Look at things that may restrict gas flow. Since you've already taken care of the carbs I'd suggest looking at other parts of the fuel system. The petcock if rusted out can restrict gas flow or cut it off completely, a severely dirty fuel filter can also restrict gas flow. The gas itself if old can also cause problems.
If the petcock, fuel filter, gas lines, and the gas itself is fine, then i'd say it's on the lean mixture side. If not that, then dirty air filter restricting air flow.
The valves will also play a large part as if they're severely out of adjustment it will cause running problems.
AlfredoGonzalez is offline   Reply With Quote
Bike wouldn't rev past 6k, then died 1994Ninja250F 1986 - 2007 Ninja 250R Tech Talk 9 May 9th, 2014 04:17 PM
Bike not wanting to rev past ~5k while driving FvnnyL3tt3r1ng 1986 - 2007 Ninja 250R Tech Talk 336 December 26th, 2012 06:51 PM
Won't rev past 5k :( hoodadooda 2008 - 2012 Ninja 250R Tech Talk 7 December 24th, 2012 08:56 PM
Engine Won't Rev Past 12k fujimumu 2008 - 2012 Ninja 250R Tech Talk 8 May 19th, 2010 03:35 PM
