Old September 27th, 2012, 11:11 AM   #1
SemperFudge
SemperFudge's Avatar
Motorcycle(s): 2001 Ninja 250R
Bike won't idle! Halp plox!
Alright so after finally dealing with the DMV and getting the title transfered, renewing the registration, and getting my license I decided it was time for my first real ride.
So I get geared up and started the bike. This is what keeps happening:
As soon as I start the bike, the RPMs drop if I don't feather the throttle and then engine stalls out if I let go.
I've tried everything! Full choke, half choke, quarter choke, no choke. I fiddled with the idle adjustment. Doesn't matter. If I don't feather the throttle the RPMs drop and the engine dies. If I hold the throttle for more than a couple of minutes I think the engine gets flooded so it dies out. I then have to wait a good 30 minutes before the bike will start again.
I don't know what's going on. I've tried holding the clutch, not holding the clutch, kick stand up, kick stand down. There's plenty of fuel in the tank.
The bike runs, so its not the carbs. It starts and cranks fine, so its not the battery. Before I bought it though the owner said it'll need a valve adjustment soon, but I hear it might not be that either.
I didn't let it run for only one day. But the day before it started up just fine.
What's going on?!?!?
SemperFudge is offline   Reply With Quote
Old September 27th, 2012, 11:18 AM   #2
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Its the carbs
AFM #676
Supersports are for n00bs
Old September 27th, 2012, 11:23 AM   #3
lgk
how many miles on the bike?
Old September 27th, 2012, 11:24 AM   #4
SemperFudge
Originally Posted by Jiggles View Post
Its the carbs
Previous owner said he had just had it serviced, including the carbs, about 2-3 weeks before I bought it. Guessing he lied then? :/
Anything I can do about it? Strong noob here though...
6,350
Old September 27th, 2012, 11:29 AM   #5
lgk
which idle screw did you mess with?
the plastic knob?
Old September 27th, 2012, 11:32 AM   #6
SemperFudge
which idle crew did you mess with?
the plastic knob?
This one:
During one of the adjustments the engine revved at 5k and I kinda freaked out and turned the knob back down a little and then the same thing happened. RPMs dropped, engine died.
Turning the knob doesn't seem to do anything anymore after that happened.
Old September 27th, 2012, 11:35 AM   #7
lgk
how many times did you try to start it?
Old September 27th, 2012, 11:40 AM   #8
If it was serviced 3 weeks before you bought it, and it's sat since then, they potentially could be gummed up. Run some carb cleaner through it and see if you can loosen up whatever's in there.
At least it starts and runs. When my carbs were massively plugged, the bike wasn't even able to start.
Old September 27th, 2012, 11:42 AM   #9
SemperFudge
A crap load of times and then eventually it wouldn't start (crank but no fire), then I realized I was flooding the engine. So I wait 30-45min then I try again. The bike will usually start fine then but the original symptoms come up again.
I'm trying to hold of trying anymore until I try something new because I'm gonna kill the batter if I keep doing what I'm doing which clearly isn't working.
He'd rode it to my house about a good hour away and it seemed fine then. I also rode it around my neighborhood for 2 days (nothing hard though, and only for about 10 minutes). However after letting it sit for a day it just wouldn't work anymore.
Really think its the carbs? How do I go about and do what you suggested?
Old September 27th, 2012, 11:50 AM   #10
Either way, adding a little carb cleaner to the gas can't hurt anything. If it helps, great; if not, oh well.
Buy some carb cleaner, add it in the right concentration to your gas, and then go out and ride.
Old September 27th, 2012, 11:52 AM   #11
SemperFudge
Okay I'll buy some later and try it out. This is a huge bummer. I really want to ride
Old September 27th, 2012, 11:55 AM   #12
I'm still betting on carbs.
Old September 27th, 2012, 11:55 AM   #13
SemperFudge
You'll get a prize if you're right haha.
Old September 27th, 2012, 12:06 PM   #14
lgk
i'm betting chone's right, or i'll buy him beer.
unless he's under 21
Old September 27th, 2012, 12:09 PM   #15
he's under 21
Old September 27th, 2012, 12:11 PM   #16
lgk
he's under 21
can't break the law so i hope you're right!!!
Old September 27th, 2012, 01:43 PM   #17
seafoam
Old September 27th, 2012, 11:57 PM   #18
SemperFudge
seafoam
Yup that's the plan. Tomorrow I'll grab some seafoam and probably dump the fuel (which the previous owner added. I have no clue how long its been there) and add fresh fuel.
How exactly do I go about it though? Once I add it to the tank, do I just start it and hold the throttle for a few minutes? Let it sit overnight?
Old September 28th, 2012, 09:47 PM   #19
SemperFudge
Resolved!
So this morning before I wanted to head out to grab the seafoam, I tried starting my bike just to see if it'd work at all.
This time around, the bike would crank but no fire. Eventually after a number of tries, the battery was clearly about to die, so I decided it was game over. I thought I was SOL until I wondered if the mechanic across the street from me, who I usually see for my cars, worked on motorcycles. Lucky for me, the mechanic that day was a huge bike junky. So I grabbed my bike, took it the edge of the street, waited for traffic to clear, and with all of my dad's strength, he pushed the bike as i steered and balanced and gunned it to the other side looking like complete fools lol.
So what was the problem? Battery was dead (obviously my fault) and the bike apparently needed transmission fluid. That was the last thing I would have thought of and no one here or my google search's hinted to that.
The final damage? $95...Was it worth it? Probably not, but since I've yet to give my bike a REAL ride since I just got my license, I'd pay anything to get to ride it now. I'm picking it up tomorrow morning and will update again then
Old September 28th, 2012, 09:50 PM   #20
lgk
lol wut
whats the transmisson fluid for?
Old September 28th, 2012, 09:53 PM   #21
SemperFudge
lol wut
I honestly have no clue. That's what the mechanic told my dad. I'll be sure to get the full story tomorrow because right now this isn't making any sense. I was 99% sure it was the carbs. But hey if it runs, I don't really care what the problem was lol.
Old September 28th, 2012, 10:00 PM   #22
lgk
just make sure he did NOT put transmisson fluid(atf, dexron, etc) into the crankcase.
if you were running low on oil and he filled it, hold the bike level and make sure he did not over fill it.
Old September 28th, 2012, 10:02 PM   #23
SemperFudge
just make sure he did NOT put transmisson fluid into the crankcase.
Yeah I'm actually pretty worried this guy didn't do anything at all besides charge the battery. I'm not sure if he actually resolved my idle problem. I guess I'll find out soon but for now I'm less excited. I'm gonna lower my expectations a little.
Old September 29th, 2012, 08:30 AM   #24
Your mechanic just separated you from $95.
For the record, a batter tender is ~$30 and will be perfect for all your battery charging needs.
Old September 29th, 2012, 09:09 AM   #25
DaBlue1
DaBlue1's Avatar
Originally Posted by SemperFudge View Post
....I've tried everything! Full choke, half choke, quarter choke, no choke. I fiddled with the idle adjustment. Doesn't matter. If I don't feather the throttle the RPMs drop and the engine dies.
What's your fuel level / condition like? If the carbs are dirty or the fuel is bad, try Star Tron Fuel Treatment along with some fresh fuel. It's real good stuff.
Wahhhh!!! My Bike Won't Start/Run/Idle... Can Someone Help!!??? kkim 2008 - 2012 Ninja 250R Tech Talk 71 February 3rd, 2023 08:19 PM
Bike Won't Idle below ~2500rpm wsrussell7 2008 - 2012 Ninja 250R Tech Talk 15 May 14th, 2013 06:05 PM
Valve adjustment and now bike won't stay idle har0ld 2008 - 2012 Ninja 250R Tech Talk 13 December 16th, 2012 06:16 PM
Changed plugs, bike won't idle.. pixelpete 1986 - 2007 Ninja 250R Tech Talk 9 April 20th, 2010 11:22 AM
Help! Dewinterizing But Bike Won't Idle Without Choke azia 2008 - 2012 Ninja 250R Tech Talk 46 March 8th, 2010 01:28 PM
