Go Back   ninjette.org > 2013 - 2017 Ninja 300 > 2013 - 2017 Ninja 300 Farkles
Old February 12th, 2013, 09:14 AM   #1
JBinSD
Motorcycle(s): '13 Ninja 300, '99 SV650 tracked
Front Stand for 300?
Whats the preference? I the fork-end pitbull that I interchange with my SV, but thinking I need two separate sets, does anyone use the triple-pin model? Not sure if its cross-compatible, or if they even make one for the 300 yet, but thought I'd check to see what you guyz are using?
Cheers,
Joel
JBinSD is offline   Reply With Quote
Old February 12th, 2013, 09:33 AM   #2
cuong-nutz
cuong-nutz's Avatar
any forkstands will do. No specifics other than having the right pin size for the triple mount.
People have used Pit Bull, T-Rex, and Lockhart-Philips with no problems. I personally have an old LP triple stand, and use a 12mm socket for the pin.
HalfFast Racing Team
Old February 12th, 2013, 09:59 AM   #3
There was a slight change to the EX250J lower fork holder in 2011 when 44037-0088-18R became 44037-0112-21. That's the same part used on the EX300A, so the same pin fits and the same triple tree/head stands should fit unless the fairing or horn interfere.
Old February 12th, 2013, 12:53 PM   #4
JBinSD
OK cool, thanx guyz. the fork-perch model doesn't always seem that stable, but the ninjette is such a light bike it shouldn't really matter, but may try the triple stand anyway.
Old February 12th, 2013, 01:32 PM   #5
Pit-bull triple-tree pin front stand FTW.
I think I'm using the #2 pin, which works fine.
Old February 12th, 2013, 01:36 PM   #6
The main problem with a fork stand is that it only helps when servicing the wheel. It doesn't help at all if you need to doing anything with the forks or triple, which often includes seemingly unrelated service, like clip-ons or lowering the bike.
Last futzed with by CZroe; February 12th, 2013 at 04:27 PM.
Old February 12th, 2013, 02:15 PM   #7
Originally Posted by CZroe View Post
...blah blah blah...
Block of wood and a car jack work in a pinch
I totally agree with you though. Triple stands are the best option. I'm getting a set of Trex stands for the pregen this spring. I hate having to use a car jack. I already re-located my horn a bit so I have space for the stand.
Old February 12th, 2013, 02:16 PM   #8
geeker
geeker's Avatar
Motorcycle(s): 2022 Honda CRF300L Rally, 2015 Ninja ZX6R 636, 2014 Ninja 1000, 2013 Ninja 300 (sold), 2011 Ninja 250R (sold)
Christie at Pit Bull told me I had to have a #20. Not sure what's different, but it works.
geeker is offline   Reply With Quote
Old February 12th, 2013, 04:41 PM   #9
You're right. Why buy any stand then? I actually had both kinds of stands before I had a real car jack (that thing included with the spare doesn't count). The F-bike's center stand and easily-removed 1-piece lower definitely help. I hear that the L-bike and 300's lowers are a pain due to all the extra pieces, so I guess a stand can come in handy.
I noticed that my J-bike horn would flex out of the way and spring right back, so I never bothered on that one, but Kawi seems to have mounted it to purposely block access for a headstand on the F-bike.
Old February 12th, 2013, 04:42 PM   #10
I rotated the mount to the right just far enough to clear the hole. I looks like it will work, but we'll see once I actually get a stand.
Old February 12th, 2013, 05:23 PM   #11
tooblekain
tooblekain's Avatar
Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike)
I have a Lockhart Phillips front stand that came with various pin sizes that I used for my D675. When the D675 got totalled out and I got my NInja 250 I just had to switch pins.
Got it for less than $100 and does the job well.
http://www.lockhartphillipsusa.com/T...AND-HEAD-LIFT/
*CVMA #312*SoCal Trackdays*BigHeadz Racing*Motion Pro*Factory Effex*Leatt Brace* Racetech *Bell * Woodcraft CFM*Vortex*Hotbodies*Surface Sun Systems*Braking*LiveWire Energy*Freegun Underwear
tooblekain is offline   Reply With Quote
Old February 12th, 2013, 06:25 PM   #12
Makes sense - I'm sure the #20 pin is slightly wider. The #2 fits in very loosely. It is the one that fits well in my ZX-10R, and I hate changing those pins each time I lift either bike, so I just leave the one in there.
Old March 4th, 2013, 09:13 AM   #13
Rekognize
Rekognize's Avatar
Motorcycle(s): Ninja 300
I got these el cheapo stands from Amazon for $60 (pair). They're stable and does the job
http://www.amazon.com/Venom-Motorcyc...dp/B0036QZ8VQ/
My Ninja 300 Build Photoblog
Greater Toronto Area 250/300 Riding Group
Rekognize is offline   Reply With Quote
Old May 29th, 2013, 11:34 AM   #14
Alim.N
Motorcycle(s): 2013 Kawasaki Ninja 300 SE
Wow.. another good find J. Ordering these stands off of Amazon today. Thanks for the heads up!
Alim.N is offline   Reply With Quote
Old November 23rd, 2014, 09:16 PM   #15
Hero Danny
Inline 4!!!
Hero Danny's Avatar
Thread Revival, I just ordered a Pitbull front stand with the 20 pin, I'll update this when I get it if it fits correctly.... According to this chart, it should be 20..
http://www.pit-bull.com/fitting_chart_pins.pdf
In case anyone is wondering, I ordered from Revzilla.com It ran me $169.99 I didn't get the removable handle. Free ship, tax included.
Be careful. Remember you are
invisible
Old November 23rd, 2014, 09:44 PM   #16
c-dog
c-dog's Avatar
Motorcycle(s): -
I just got another front and rear set for my 300 last week. I like the new hybrid front stand, it has changed a little since I got my last set. It is convertible with the fork lift converters. I also got the fork lift converters, but not sure how often I will use the stand like that.
Both my 300 and 6R are hovering above the ground on Pitbull stands. I really like them even though they are so expensive. They are heavy and overbuilt, which is why I really like them.
c-dog is offline   Reply With Quote
Old November 23rd, 2014, 10:05 PM   #17
Hero Danny
Inline 4!!!
Hero Danny's Avatar
I thought about the hybrid stands but decided against it. I heard the original felt more sturdy.
I have the rear pit bull stand with the extended removeable handle... kinda not worth the extra $ imo (for the handle).
I love the rear stand, I justify the cost because in the long run it'll save me money only having to buy the one stand (per bike). Opposed to having to get a new stand every 5 years. Also, they look badass.
invisible
Old November 23rd, 2014, 10:22 PM   #18
c-dog
c-dog's Avatar
Motorcycle(s): -
I got the front stand that you got as well (I think?). It's called the Hybrid Headlift for $170. The other one is the Hybrid Dual Lift for $210.
With the ones we have you can convert and remove the whole head lift part and attach the swivels. They call them Hybrid Swivels for $45.
Here's a link - http://www.pit-bull.com/mm5/merchant...e=front_stands
Old November 24th, 2014, 03:03 PM   #19
Hero Danny
Inline 4!!!
Hero Danny's Avatar
Ah, I guess you're right... Here's the one I got.
http://www.revzilla.com/motorcycle/p...headlift-stand
Thanks for the link, I'll probably pick up the swivels another time though
invisible
Old November 25th, 2014, 06:05 AM   #20
c-dog
c-dog's Avatar
Motorcycle(s): -
It's a great front stand. They really are a joy to use. Before and after every ride you interact with them. It's like having a nicer set of tools that feel higher quality. Going to try the swivels out next year. I'll let you know what I think about them. Never used a stand with the fork lifter type swivels, so it should be fun to try out.
The swivels are gorgeous, the pull pins and welding is on another level. Such nice stuff. I wish I could show you them in person.
Old November 25th, 2014, 08:39 AM   #21
Hero Danny
Inline 4!!!
Hero Danny's Avatar
"wisconsin" yeah, probably never see you in person lol
As for the stands, I completely agree that the stands are a great investment. When I spent close to $500 in mods on newgen and then realized once I sold her that it was just wasted money it kinda sucked. But now it doesn't matter what happens with my ninjette, i'll always have these stands. + the peace of mind knowing that my bike is safe and sturdy on them helps.
Once I get my front stand I'll be all ready for winterizing my bike. I'll clean her up, add sta-bil, put her on the stands, pull the battery, throw the cover over her and call it a day.
front stand will be in tomorrow and i'll snap some photos and give you my .02
invisible
Old November 25th, 2014, 04:31 PM   #22
c-dog
c-dog's Avatar
Motorcycle(s): -
They are a really nice investment. It does kind of sting to spend a touch over $300 on stands. Some might say we are crazy. But over the years the extra money spent per day difference is not a big deal.
I also have to fully winterize my bikes. I keep them in a heated storage unit. Both need oil changes, new filters, stabil added and batteries removed. It's kind of a pain. At least I got them both to the storage unit before all the snow hit.
Let me know what you think of the front stand when you get it. Did you go with the standard version or did you add removable handle or longer handle? I just went with the standard one.
Old November 26th, 2014, 10:02 PM   #23
Hero Danny
Inline 4!!!
Hero Danny's Avatar
Overall happy, here's my video review on it. My only gripe about it is thinking back I should of just gotten the removable handle... no biggie though... also, it arrived with a couple scratches on it, but they're tools... it's going to get scratched eventually!
invisible
Old November 26th, 2014, 11:05 PM   #24
c-dog
c-dog's Avatar
Motorcycle(s): -
Nice video. I noticed the horn problem also. I don't think it's a big deal, but I'm going to relocate it slightly at some point.
Old November 27th, 2014, 06:56 AM   #25
Hero Danny
Inline 4!!!
Hero Danny's Avatar
Yeah, horn still works but the stand was literally pushing the horn back. Not too worried if it breaks since I kinda wanted to upgrade the horn anyway.
invisible
SV Racing Parts, Black Front Stem Stand and SS Style Rear Stand Combination SV Racing Parts Motorcycle-related 0 January 15th, 2015 06:45 PM
Venom triple tree front stand not compatible with the 300? cadd 2013 - 2017 Ninja 300 General Discussion 8 January 5th, 2015 07:10 PM
Squeaky Front Axle and No Front Stand Brother Michigan 2013 - 2017 Ninja 300 Tech Talk 4 September 27th, 2014 04:00 PM
Who needs a front stand when you can ... EthioKnight Pictures 16 August 1st, 2012 12:04 PM
WTB: Pitbull Front Stand or Rear Spool Stand Mr_Pete Items Wanted 8 October 30th, 2009 02:02 AM
