Old July 5th, 2009, 05:17 PM   #1
almost40
ninjette.org Monkey Spank
almost40's Avatar
pre-gen tach on an 08??
Has anyone pulled the pre-gen dash and taken it apart??
Can you pull the tach and mount it in a custom made plate??
Will the pre-gen tach work on an 08???
The reason I ask is I would like to pull the dash on my 08 and install a custom aluminum plate to hold a tach and a temp gauge. (thats all I need for the track) I was just curious if this is even workable??
Black 250R
Full Area P QC
Old July 5th, 2009, 05:50 PM   #2
Snake
Snake's Avatar
I don't see why it would not work since the engines are almost identical.
Old August 26th, 2009, 03:59 PM   #3
ASecretNinja
ATGATT Squid Killer
ASecretNinja's Avatar
Motorcycle(s): '06 CBR600
Car = dash(board)
Motorcycle = instrument cluster.
ASecretNinja is offline   Reply With Quote
Old September 16th, 2009, 06:09 PM   #4
g21-30
g21-30's Avatar
I think the '88-94 will work, since the '88-94 CDI works!
New-gen engine in Pre-gen frame. Oil leak under exhaust ports. AFazakerley 2008 - 2012 Ninja 250R Tech Talk 11 June 5th, 2016 02:03 PM
Fitting a new gen front wheel on a pre gen? thumper64 1986 - 2007 Ninja 250R Tech Talk 13 November 6th, 2013 02:44 PM
Bike size, new gen vs pre gen(zzr) bowerbird100 General Motorcycling Discussion 6 August 1st, 2013 05:49 PM
Pre-gen (2007 and older) and "new pre-gen" (2008-2012) frames kjohng General Motorcycling Discussion 5 February 27th, 2013 10:03 AM
FS/ part out new gen and pre gen 250r ninja carlos Motorcycle-related 3 May 14th, 2012 10:25 PM
