Old August 21st, 2017, 04:12 PM   #1
Hunsy34
Hunsy34's Avatar
Motorcycle(s): 2009 Ninja 250 2016 Ninja 300 1994 KTM 300 EXC
40 tooth rear sprocket
Just got my Ninja 300 about 2 months ago and I am looking to make the change to a 40 tooth rear sprocket because you will not have to take out links in the chain, however I am having a hard time finding a 40 tooth rear sprocket. I have seen some on amazon that people said fit but when I put in the bike specs it says it doesn't. I found some on ebay that are around $50 some bucks but it seems like at some point they were cheaper. Does anyone know where I can find a good 40 tooth sprocket or am I better going with the $50 sprocket?
Hunsy34 is offline   Reply With Quote
Old August 21st, 2017, 04:44 PM   #2
What are trying to do?
If you are replacing chain, get one with 106-links and that's it. No sprocket swaps or removing links needed.
If you want taller gearing, a 15/42t front swap is easier. Only 1.7% different from 14/40t combo (both about 6% taller than stock). Less chain-wrap angle in front is more efficient with less frictional losses.
https://www.amazon.com/dp/B0068OCPKA
Old August 21st, 2017, 05:04 PM   #3
sparkcycle
sparkcycle's Avatar
Motorcycle(s): Ninja 300 ABS
I have a 40T rear sprocket on my Ninja 300 and didn't replace anything else. it works great. I had the same problem when I bought mine... don't believe the websites. If it has the dimensions and tooth count you need, it will work. I bought mine from ebay. This is the sprocket I bought:
http://www.jtsprockets.com/catalogue/sprocket/JTR1486/
Engineer rocketing through time and space on a Ninja 300 ABS
sparkcycle is offline   Reply With Quote
Old August 22nd, 2017, 06:04 AM   #4
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Sprockets aren't cheap, Vortex has them for a wide variety of sizes and colors in aluminum. the power of the 300 won't kill an aluminum sprocket like other bikes. check sites like www.revzilla.com or www.sportbiketrackgear.com
TEAM ALFALFA
www.apexassassins.com
Old August 22nd, 2017, 06:56 AM   #5
sparkcycle
sparkcycle's Avatar
Here is some on eBay currently for about $25 + shipping.
https://www.ebay.com/p/JT-Sprockets-...-40T/171267970
Old August 22nd, 2017, 07:17 PM   #6
Hunsy34
Hunsy34's Avatar
Thanks for the input I was able to do some more research and found at JT sprocket on ebay that would fit. Just looking for something to extend 1st gear. I wanted the 40 tooth because I have read others that didnt have to take links out of the chain or anything like that.
Old October 26th, 2017, 09:56 AM   #7
john pierson
john pierson's Avatar
Motorcycle(s): '00 SV650,'02 EX250,'15 EX300
Steal of steel
I got that JTR1486.40 for $5 delivered! Sometimes you waste money on ebay but sometimes you score. All ready did a 15 front so this should help even more. Bike is down for steering head brgs, suspension work,& rr tire. Can't wait for Spring!PS there are already Blizzard conditions in NW Minnesota!
GUZZI JOHN
john pierson is offline   Reply With Quote
JT Sprocket 42 tooth Rear Sprocket lolibater Motorcycle-related 36 February 25th, 2013 12:30 PM
