Old November 8th, 2009, 07:49 AM   #1
Mr Quality
Motorcycle(s): 2006 Ninja 250
Home made wind screen
I've been meaning to show this for awhile now. This originally started off as a pilot project figuring I would have to make some or many modifications to get it where I wanted it. After miles and months and no other mods I decided to tint it and leave it alone. I like it much more than the original and am proud of my results. It's based from one of Mike's designs with dimensional changes added in to suit me.
Mr Quality is offline   Reply With Quote
Old November 8th, 2009, 07:52 AM   #2
bob706
bob706's Avatar
How did you make it? It looks very nice.
Old November 8th, 2009, 09:24 AM   #3
I would also like to know the process. Can it be used to make an angular fighter jet cockpit-style one for a newgen? If possible, that's what I aim to do. Do a Google Image Search for "Blue Falcon" and click the pictures of a futuristic hovercraft to see what I'm looking for.
Old November 9th, 2009, 07:24 AM   #4
Mr Quality
The Process
First I made a drawing of the rough shape I was trying to achieve on graph paper. Once I was satisfied with this I transfered it to a full size template on cardboard. I then used that template to assure that the screen would approximate what I was trying to achieve on the bike, clearances with the bars, etc. I then used the template to transfer the pattern to the .125" Acrylic with the protective plastic coating in place. Note: The prefered material would be Polycarbonate but since I thought this was a pilot I opted for the the less expensive material. I cut the shape using a jig saw with a fine tooth plastic cutting blade on slow speed. I also had a thin piece of plywood behind the acrylic to reduce chipping. It is important to keep firm pressure on the saw. Once the rough shape was cut the work begins. Sanding, sanding and more sanding. Begin smoothing the edges and radiusing them slightly. Once they are mostly smooth use a very fine grit and wet sand to finish. As the last touch I used plastic polish and scratch remover to really bring the edges to the high polished finish. Why I would do this on a pilot project I have no idea.....
Then I had to wait for my wife to leave the house....It was time to radius or bend the screen to fit the fairing. I had figured out that the diameter was roughly 21 inches so I needed something to form the screen around once it was heated. I was lucky to have a smooth barrel that fit the bill just perfectly. So once the little lady left I fired the oven up to 240f. Once up to temp I placed the screen on a deep cookie sheet (see why she had to go?) and in the oven it went for approximately 7 minutes. Once I saw the center of the screen start to sag I knew it was getting ready to form. Wouldn't you know about that time I was distracted by a phone call and it was in about a minute too long. The result was a little out gassing, several small bubbles at the botton edge of the screen which are hardly noticable now that it is tinted. Anyway, out of the oven it came and, with gloves on, around the barrel it went. I carefully formed it to the radius of the barell and held it in place till it cooled for several minutes. It wasn't perfect...but pretty darn close.
Anyway all that was left was to remove the original screen, drill the mounting holes and fit it in position. A test ride proved that no flexing or any other problems existed. Protection to body was good and some to the hands is provided as well. Later I did the tint job.
And that is how it was done. Give it a shot, it's a fun project and cheap too.
Old November 9th, 2009, 07:44 AM   #5
bob706
bob706's Avatar
LMFAO! Classic
Old November 9th, 2009, 09:47 AM   #6
Snake
Snake's Avatar
Very proffesional looking. I like the wind protection for the hands.
Home made stand made from 1" black pipe Motofool General Motorcycling Discussion 11 September 4th, 2014 12:28 PM
2009 Stock Wind Screen Mjj Free stuff! 5 December 23rd, 2013 01:08 PM
Rear Hugger and Wind Screen akima General Motorcycling Discussion 17 June 24th, 2012 08:08 AM
Wind screen bolts? play2pwn 2008 - 2012 Ninja 250R Farkles 4 May 20th, 2011 12:40 PM
WTB: OEM Wind Screen 00v_Lucky Items Wanted 3 June 25th, 2009 10:05 PM
