Old November 3rd, 2019, 01:05 PM   #1
juanphatsun
juanphatsun's Avatar
Motorcycle(s): Ninja 250 2007
Starter clutch removal
I made some inquiries about a starting issues, and after some detective work it's clear that my starter clutch needs to be replaced.
I'm just curious if anyone has any tips and tricks for getting around the specialty tools needed to remove the alternator rotor.
juanphatsun is offline   Reply With Quote
Old November 4th, 2019, 08:37 AM   #2
greg737
Motorcycle(s): -
You might be wondering why nobody replied to this question.
It's because pulling off items that are mounted onto the end of a motorcycle's crankshaft isn't easy, and there's a good chance of damage if you attempt to do it with improper tools, which is why there are specialized tools for the job.
Trying to do this work on-the-cheap often ends up in failure: 1. unable to remove the item, 2. damaging the item you're trying to remove, 3. breaking the on-the-cheap tool you're trying to use (in place of a real/proper "puller" that was made specifically for the job), 4. causing damage to other items (such as the Alternator Rotor)
On the EX250 the Starter Motor Clutch is mounted on the backside of the Alternator Rotor. The Alternator Rotor contains magnets. The magnets inside a motorcycle Alternator Rotor are relatively delicate and can be damaged/ruined if you drop the rotor on a hard surface or if you beat on the rotor while trying to remove it from the crankshaft.
There are specific warnings about this printed in the Kawasaki EX250 Motorcycle Service Manual.
Starter removal help! justanotherone1 1986 - 2007 Ninja 250R Tech Talk 1 September 1st, 2019 12:38 AM
Clutch basket removal 59096 1986 - 2007 Ninja 250R Tech Talk 3 June 26th, 2019 11:03 AM
Clutch Basket removal Booton 2013 - 2017 Ninja 300 Tech Talk 4 October 2nd, 2018 05:47 PM
2 more q's. Carb removal and clutch switch peperino 2008 - 2012 Ninja 250R Tech Talk 14 January 31st, 2016 06:49 PM
Starter motor clutch drphils87 2008 - 2012 Ninja 250R Tech Talk 3 June 21st, 2013 04:39 PM
