Old November 9th, 2019, 08:34 PM   #1
RiderDonnie
Motorcycle(s): 2005 Kawasaki Ninja 250r
Fuel filter
I have a 2005 ninja 250 and I need help finding a fuel filter
RiderDonnie is offline   Reply With Quote
Old November 9th, 2019, 09:50 PM   #2
How about one of these?
https://www.amazon.com/dp/B00GJQDRVI
Old November 9th, 2019, 10:52 PM   #3
RiderDonnie
Would that be an aftermarket filter? It looks different from the one that was on the bike before. I found the oem part number actually.. 49019 - 1092 . Should i just go that route since it is factory?
Thanks
Old November 11th, 2019, 04:05 AM   #4
Factory filter goes INSIDE fuel hose and has limited capacity. It has been implicated in many cases of limiting fuel-flow due to being clogged. It can’t be easily inspected without removing fuel-hose.
https://www.partzilla.com/product/kawasaki/49019-1092
Old November 11th, 2019, 07:25 AM   #5
greg737
Motorcycle(s): -
https://faq.ninja250.org/wiki/How_do...fuel_filter%3F
Old November 12th, 2019, 09:32 AM   #6
LR44
LR44's Avatar
Motorcycle(s): 2003 Ninja 250R
Get an in-line, external filter. That way, you can see your fuel flow and whether you need to replace it.
I got mine from Advance Auto. I believe it was intended to be installed in a Ford of some kind but it was small and that's what I wanted (most in-line filters can be a little on the long side, so they don't fit well in the cramped space between the petcock and carb). I haven't had any issues with it.
LR44 is offline   Reply With Quote
Old November 17th, 2019, 10:09 PM   #7
RiderDonnie
Thank you everyone! I appreciate it
SUGGESTION use your fuel rail filter ducatiman 1986 - 2007 Ninja 250R Tech Talk 0 May 5th, 2019 08:49 AM
Fuel leaking from pod filter UFOmoplata 1986 - 2007 Ninja 250R Tech Talk 17 March 21st, 2016 01:40 PM
fuel filter ninjablk08 General Motorcycling Discussion 35 December 22nd, 2011 01:53 PM
petcock fuel filter won't stay in? CynicalC 1986 - 2007 Ninja 250R Tech Talk 5 April 7th, 2011 02:01 AM
Fuel Filter indr 2008 - 2012 Ninja 250R Tech Talk 1 February 12th, 2011 07:11 PM
