Old January 16th, 2022, 10:10 AM   #121
shspvr
Motorcycle(s): 07 Kawasaki Ninja 250
Originally Posted by Bob KellyIII View Post
Quote"
1: Yes if you look at your own post 106 with photo which show the coolant level then if you look at your other post 111 photo the coolant level is right at very bottom of the reservoir
unQuote"
Very observant Anthony ! well done!
Yah being accross the pond is a problem with using Ducattiman .... darn it !
I was going to buy one small 6x16mm bolt for my RX4 as it lost one
the bolt was 50 cents the shipping was $20.00 !!!!
i didn't get it ! LOL
Bob....
Yup I hate rip off site
Go to Acer Hardware or Fastenal
shspvr is offline   Reply With Quote
Old January 16th, 2022, 10:34 AM   #122
In a pinch in boonies, you can use 1/4x24 to replace M6x1 bolt.
Yeah, check local hardware stores, most carry metric nowadays. I actually found M7 bolts at hardware store in Morgan Hill on my way to Laguna Seca. Needed some to hold rim-halves on my BBS wheels.
You've got nearby:
Siskiyou Forest Products
Solano's Ace Hardware
Here's my go-to source for stuff: https://www.mcmaster.com/screws/hex-.../length~16-mm/
Old January 17th, 2022, 01:22 PM   #123
SuspectPage3
Motorcycle(s): 2008 Ninja250R
Originally Posted by shspvr View Post
Your message didn't post
2: That is most likely carburetor problem as DannoXYZ posted, But I be more concerned about actually head gasket leak than carburetor right now.
Chinmay here are some options for you in your neck of the woods too look into.
https://www.thecarburetorguy.com/
and
http://finchrestorations.com.au/
I also check your local bike shop and ask about motorcycle carburetor specialist.
Hi Anthony, you were right, the coolant was low causing the radiator to become a Cho Cho train. I bought some coolant and topped up as much it could fit in the radiator and reservoir tank. Ran the engine on idle for about 15 mins, no issue (that I could see) and things seemed okay.
Thank you for taking the efforts to look up carb cleaners for my region. The ones you mentioned, they are more so historic vehicle restoration guys and don't really do modern bike carb cleaning. I called them and they flat out said no
I'm going to look around for someone else more suitable for this job or simply take her to kawi shop near me nd get them do a professional job.
Only a biker knows why a dog sticks his head out of a car window!
Current Ride: 08 Ninja250R
SuspectPage3 is offline   Reply With Quote
Old January 17th, 2022, 01:49 PM   #124
Local Kawi shop most likely will NOT be able to do adequate job of carb restoration. Ask them though, they may know some ancient hermit who can actually do it.
Old January 17th, 2022, 01:56 PM   #125
shspvr
LoL the that so funny I take that it was Finch Restorations ? what about The Carburetor Guy.
Try google search for "australian motorcycle carburettors service" there many more.
Old January 26th, 2022, 10:21 AM   #126
Alright, so, I went and got a connection hose as recommended above. Connected the two remaining things correctly and started the bike. The bike starts, idles perfectly fine for some time (until it's still cold and starting to warm up).
Now there are two issues:
1) I still can't open the throttle, cuz as soon as I do that, the bike dies. If I put the choke on, it will rev up naturally to 5-6k rpm. But any more throttle and it will die.
2) As soon as the bike is hot (left it running on the spot for 7-8mins) the coolant reservoir (white container thing on side) started to bubble up, looks like the hose from the radiator is sending hot air through the hose into the bottom of reservoir.
So I panicked and turned her off and I can't dare to start her up again. I've clearly connected a hose wrongly.
(See the attached for reference please)
Where did I mess up now?
When my bike gets fully hot then turned off the engine heat goes into the tank and forms a vacuum as the tank cools. Perhaps that’s why it won’t start? Takes a lot more time for mine tho’ Still, try opening the fuel door to see if it makes a difference.
Old January 26th, 2022, 10:36 AM   #127
Bob KellyIII
Retired motorcycle Mc.
Bob KellyIII's Avatar
well, first off idling the bike for 10 minutes it is going to over heat it.... don't do that ! limmit the time to 4~5 min. tops so you don't over heat the engine
not taking throttle has got to be plugged jets ... if it is idling good then it's not the pilot jet... it's mainly the main jet now as it won't take any throttle
they either have to be plugged or something is stopping gas from getting to them....
the pilot jets sit above the main jets a little bit so it's not float level because it idles fine and continues to idle fine... so we can eliminate the float aspect .
so we know the main jet is sitting in gas like it should be but it is not getting through that jet for some reason.... either the jet needles are not moving when the throttle is opened or the jet and emulsifier tubes are plugged.
the only other possibility I can think of is a massive air leak one that allows a idle to happen but not opening the throttle... unlikely but I have seen that happen before !
I remember leaving the vacuum tube covers off the intake manifold one time on the XS650 it started fine but would not take throttle at all ... started checking and found both plugs for those tubes on the work bench !
I put them on and then the bike revved like it should....
Bob....
Old January 26th, 2022, 11:52 AM   #128
shspvr
Bob....
Did you forget that have electric fans not I would recommend this with an air engine
Old January 26th, 2022, 12:00 PM   #129
Bob KellyIII
no i did not Anthony !
even with the electric fan on it will still over heat ! HONNEST
let your bike idle and see how long it will idle before it starts pushing out fluid from the over flow ! that's not that long
the bike needs air going through the radiator to keep it cool setting still and even with the fan on it will over heat as the fan only covers about half the radiator !
...and that is assuming the fan even works on his bike which I doubt !
Bob......
Old January 26th, 2022, 12:10 PM   #130
shspvr
Bob......
I done many time on both Car and Motorcycle even ATV and UTV and I general don't let run just long enough to ensure the fan temp switch is working and holding.
But I start seeing overflow with air bubble then I know there something wrong
Last futzed with by shspvr; January 26th, 2022 at 01:59 PM.
Old January 26th, 2022, 01:36 PM   #131
Bob KellyIII
Ok granted a car is different they have bigger radiators ! and a larger cooling capacity... a motorcycle has the absolute bare minimum of cooling capacity
when you get air bubbles in the line that means your boiling the coolant !
you know that already.... that means your overheating that engine !
and that is something you do not want to do !
I bought a Subaru with a EA82 turbo charged engine that the gal drove home without coolant in it.... it split both heads ! the damage wasn't just isolated to just the heads... but I didn't know that at the time... so I said no problem I'll just replace them, but at $586.00 each I decided to weld the cracks myself ! ... that didn't work and once I did get it running the oil pressure was really low so I scrapped it, it cost more to repair it than it was worth !
( it was cheap so I bought it on the chance I could fix it)
that gal swore up and down she only drove it 5 miles without coolant in it
and that was about 3 minutes on that road.... but she cooked it real good !
aluminum engines do not like to be over heated !
Bob....
Old January 26th, 2022, 03:00 PM   #132
My 250 will idle in the driveway all day without overheating. The fan cycles on and off as needed. I tried it once in warm weather just to know if it could do it without a problem and it did.
Old January 26th, 2022, 03:42 PM   #133
Bob KellyIII
Ok .... that is good to know ! I was wrong !
.... but I wouldn't do that ! LOL
Bob.......
Old January 26th, 2022, 04:05 PM   #134
Fan-circuit is also connected full-time to battery. So if thermoswitch triggers fan ON, it will stay on until temps drop. Even if you pull key and walk away.
Old February 12th, 2022, 02:41 AM   #135
SuspectPage3
Hello Fellow Riders,
I know it's been a while and I haven't updated you guys on the issue with my bike. This is going to be a longer one...
So after a long time of waiting, going through two mechanics, pain& suffering(of seeing the bike sit in garage), unsuccessful attempt to post on Sydney FB Ninja group and so much more, I made the decision.
I read through all your comments, your posts, your encouragements and instructions. I made the decision to do the carb cleaning myself. I would certainly like to thank Bob Kelly, Shspvr, Danno, Triple Jim, and everyone else who helped in any shape or form. Your inputs were definitely helpful. I went to local bike shop, got a $6 carb cleaner spray can, rags, newspaper, gloves, and bunch of tools with me (not professional ones, I got them from KMart for $20 kit). I opened up the carbs and gave them a thorough clean (cleaned them once, didn't have time to put them on bike, next day cleaned once again just to be sure) and then put the bike back together finally.
Put the key in, flick the kill switch, and hit the starter button.... She started right up at first go! I was over the moon, I was extremely happy and delighted. Someone with zero knowledge about bikes and engine/carbs, I got her to start. (Note that the second mechanic's attempt to fix her, had made the issue even worse and she wasn't even firing up at all). So I clearly had done a decent job at this stage. Now, after about 30 secs of idling, I opened the throttle and she didn't die on me (like what the issue was in first place). I did it! I fixed the issue and successfully cleaned the carbs in first attempt (given from your comments that some people had to re-clean them 4-5 times). The bike idles perfectly, revs up, coolant is well, and no issues so far. So put the fairings back on and she's ready to test, I was nervous, I rolled down the driveway, and started her up, clutch in, first gear, slowly release the clutch and reving up at the same time... And she picked up, no bogging, no spluttering, none at all. I did a small test ride, successful. I went for a bigger one, and bigger one and then for an hour long ride (through the laneways, roads, main roads and highways) and a sure success. I have been riding her to work for 2 days now, no issues, I am a happy puppy.
During this whole process, I had a concern that I hope I don't do something wrong somewhere and cause more harm than good, but I didn't. The one thing I'm noticing though is that she's burning a little too much fuel than I think she should. I guess some adjustments weren't perfect when putting the needle screws together. So I could use some further help here please.
Once again, thank you all for your help, guidance and encouragement along the journey. I surely agree with Danno "First, you have to recognize there are NO mechanics, zip, nada, zilch, none that can work on carbs properly!". I feel confident to do any further maintenance on her myself. It's not that difficult once you dive in and have correct tools.
Regards,
Chinmay
Old February 12th, 2022, 02:53 AM   #136
shspvr
Regards,
Chinmay
Usually, it depends sometimes they can come clean right way sometimes it can take many times to get all gunk out for it work any way good Job
Old February 12th, 2022, 05:52 AM   #137
I'm glad you're now riding! What makes you say it's burning a little too much fuel? Have you calculated miles per gallon, or equivalent? How far do you get before needing "reserve"?
Old February 12th, 2022, 10:02 AM   #138
Bob KellyIII
now, if you don't have a paper fuel filter in line after the petcock and before the carbs you need one ! get one on there before your carbs get plugged up again.
the Ninja does use more fuel than the 250cc singles that is normal and you have to pull the spark plugs in order to do a color check to determine if it is running too rich or not personally, i doubt it is. but it could be. it's more likely that the chokes are not being turned off completely check the slack in the cable and you may have to re-route the choke cable to get the slack you need in the cable to get them to open and close properly .
that would be the first place I check for a rich running Ninja 250....
do yourself a favor and never put gas into the bike from a can or gas container, as that is a good way to get junk into the gas tank... fill up at a gas station only !
congratulations on your achievement ! that is nothing to sneeze at ! it is a big accomplishment and you can be proud you did it.
the knowledge you learned in doing it, DO NOT FORGET ! as you will need it in the future !
Well Done !
Bob....
Old February 12th, 2022, 01:08 PM   #139
Ninja does use more fuel than the 250cc singles that is normal...
Mine certainly does not. Its MPG averages in the mid to upper 60s.
Old February 12th, 2022, 06:35 PM   #140
Bob KellyIII
boy mine don't ! it's in the mid to low 40's LOL
..... maybe I should sync the carbs ! HA!
Old February 12th, 2022, 07:38 PM   #141
That's not carb sync... something is wrong.
Old February 13th, 2022, 12:03 AM   #142
Bob KellyIII
Humm... could be too large of Main Jets the previous owner did "Modify" the thing.... I haven't done a Plug color check sense I got it running so that might be a good idea....
.....oh... darn I just thought of what it might be.... oil level is high too...
and I know the pet cock leaks and when it is on it's side stand it leans a LONG way over now with the shortened side stand... i bet it's leaking gas into the bottom end.... I better check into that before I ride it again....
.... I hate vacuum petcocks might be time to buy one I can actually turn on and off !...( and change the oil again!)
.... last color check on the plugs looked great, I couldn't ask for anything better
which means it's not burning all that gas it's just dripping into the bottom end
... wonder why I haven't had a hydro lock then??? slow leak perhaps ?
.... Darn you Jim !!! now I gott'a work on the Ninja again ! HAHAHAHA
but thank you anyway !!!! you may well have saved me a bunch of trouble coming up in the future !
Bob...
Old February 13th, 2022, 07:16 AM   #143
shspvr
The fuel mileage can vary from low as 45 to as high 60 there a lot of things you have factor in.
86-87 Fuel capacity: 3.33 gal
You be luck get about 130 miles tops before need to switch to reserve it was more of a city bike, I know I rode one from Nampa, ID to Twin Falls, ID one summer in early 90's.
88-12 Fuel capacity: 4.8 gal
You should get at lease 200 miles before hitting reserve with non-fuel gauge model.
An option is to download the mobile app like fuelly to keep of this.
Old February 13th, 2022, 06:13 PM   #144
Woohoo!!! Awesome job getting those carbs cleaned up!!!
Old February 14th, 2022, 12:55 PM   #145
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Glad you're back on the road! Nice work!
Camshaft change issue - won't start Tony Ambrose 1986 - 2007 Ninja 250R Tech Talk 4 August 15th, 2020 04:45 AM
Start Up / Idle Issue After Driven Block Off Plate Install 1PaulSilva 2013 - 2017 Ninja 300 Tech Talk 13 September 5th, 2018 01:34 AM
Start Issue BrianATX 2008 - 2012 Ninja 250R Tech Talk 12 August 5th, 2015 05:41 PM
weird voltage/no start issue thedrewski86 2008 - 2012 Ninja 250R Tech Talk 8 April 16th, 2014 09:47 PM
Cold Start issue SpYd3r05 1986 - 2007 Ninja 250R Tech Talk 19 May 5th, 2010 12:24 PM
