Old August 16th, 2023, 09:52 AM   #1
kal
Oil Leak - Damaged Thread
Hey everyone, I hope this finds you well. I found an oil leak coming from the plug near the oil filter (see attached). The bolt did not tighten so I thought the bolt thread was damaged. When I removed the bolt, I saw that it isn't the bolt thread, but the hole thread that is damaged (see attached). Any ideas on how to fix this? I opened the service manual to find out what this plug is for but it seems like its just a secondary drain plug?
kal is offline   Reply With Quote
Old August 16th, 2023, 10:02 AM   #2
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
I recommend contacting a machine shop, and taking bike there to have a threaded insert installed.
Old August 16th, 2023, 12:09 PM   #3
Yes, that's drain plug. Other big bolt removes oil-filtre. But can get very messy if used for draining as well.
One way to fix is drill & tap for next size up and use larger drain bolt. I'd recommend having machine shop do this. You can remove oil-pan from engine to bring to them. Easier than trying to flip bike upside down under drill-press.
Other way is use solid-metal insert like EZ-lok or Time-sert. Helicoils will unwind out after 4-5 oil-changes. You want stronger more durable solid insert. Again, machine shop can do this as well.
Last futzed with by DannoXYZ; August 16th, 2023 at 08:21 PM.
Old August 16th, 2023, 12:43 PM   #4
There are plugs made to seal a stripped drain hole. I have no experience with any of them. Maybe someone else here has used one and can tell us how well it worked.
As an example:
https://www.agscompany.com/products/...nged-universal
Oil leak Soundtrackzz 1986 - 2007 Ninja 250R Tech Talk 8 May 11th, 2017 11:14 AM
Still got this oil leak!! xXecuterXx2 1986 - 2007 Ninja 250R Tech Talk 11 August 11th, 2015 11:56 PM
Oil leak.... skilletmo 2008 - 2012 Ninja 250R Tech Talk 13 October 24th, 2014 09:31 PM
Oil Leak? Fakker 1986 - 2007 Ninja 250R Tech Talk 5 September 6th, 2013 06:38 AM
Oil Leak Help sjc88 1986 - 2007 Ninja 250R Tech Talk 7 December 29th, 2011 04:13 PM
