Old February 4th, 2011, 10:46 PM   #1
kobachi
kobachi's Avatar
Motorcycle(s): Blue 2008 Ninja 250R
Does my chain slack need adjusting?
I've never adjusted my chain slack and couldn't find a DIY on it in the DIY listing. I don't know anything about what chains should look like, but the fact that mine seems to be 'bouncing' sometimes makes me think maybe it needs to be tightened?
Two videos, the first is when the chain has been WD-40 degreased but before re-lubing it, the second is after applying lube.
kobachi is offline   Reply With Quote
Old February 4th, 2011, 10:49 PM   #2
Chain Adjustment / Wheel Alignment DIY
Basically, push the bottom of the chain (in the middle) up pretty hard, then down pretty hard. If the distance is around 1 1/4 inches (give or take) you're good. Much more, tighten the chain. Much less, loosen the chain.
Old February 4th, 2011, 10:50 PM   #3
kobachi
kobachi's Avatar
I definitely saw that thread, but that seems to be about lateral alignment more than slack adjustment, no?
Any thoughts on the video? Do I have something else wrong? Doesn't feel like it should bounce around like that...
Old February 4th, 2011, 11:58 PM   #4
The way you do lateral alignment is by adjusting the rear wheel forward and back / side to side. At the end, the wheel needs to be straight, and the slack needs to be appropriate. I'll look at the videos now.
Old February 5th, 2011, 12:02 AM   #5
Way, way, way too much chain lube. But the chain doesn't look much too loose or too tight. Hard to tell when it's running like that with no load on it. Stop the engine, check the slack on the bottom chain run, and to make sure rotate the wheel a bit and check the slack at another point as well.
Old February 5th, 2011, 12:06 AM   #6
Cuongism
Cuongism's Avatar
Alex is right, rotate your wheel until you find the tightest spot and measure the distance from all the way up vs down. Service manual says .8-1.2 inches and I recommend erring towards the loose side.
Also, let your lube soak a little or wipe it down before using the bike. It looks like it's flinging.
Old February 5th, 2011, 12:29 AM   #7
kobachi
kobachi's Avatar
Rgr, I had /just/ applied the lube when I took this video so it was still quite wet. But I have probably always over-lubed. Is that dangerous or just messy?
Old February 5th, 2011, 02:50 PM   #8
kobachi
kobachi's Avatar
Ah, I see what you mean now. The splatter you see on the bike was actually from the WD-40, not from the lube.
Old February 5th, 2011, 03:56 PM   #9
I hope you're not cleaning and lubing while the engine is running like that. Too much potential for something to go wrong, IMO.
All cleaning and lubing should be done with the engine off and the tire being rotated by hand.
Old February 6th, 2011, 07:33 PM   #10
headshrink
headshrink's Avatar
Like pulling your fingers into the sprocket.... potentially cutting them off
Old February 8th, 2011, 09:48 AM   #11
demp
Please no one link that disgusting thread where the guy actually does it... lol
Old February 8th, 2011, 12:56 PM   #12
headshrink
headshrink's Avatar
I didn't know that existed.... yuck!
Old February 8th, 2011, 03:46 PM   #13
indr
oh you HAVE to see this ****; http://www.gixxer.com/forums/showthread.php?t=242261
indr is offline   Reply With Quote
Old February 8th, 2011, 06:02 PM   #14
Powerlogix
Powerlogix's Avatar
Motorcycle(s): 2010 ninja 250
Originally Posted by indrish View Post
WOW, that was horrible. But at least now I know never to do that myself.
Powerlogix is offline   Reply With Quote
Old February 8th, 2011, 06:57 PM   #15
headshrink
headshrink's Avatar
I think I'm going to have nightmares.
Old February 8th, 2011, 07:30 PM   #16
wvninja
wvninja's Avatar
Motorcycle(s): 2009 Honda CBR600RR
Yeah I'm not even going to look because I've seen that thread once and thats enough for me.
I use chain wax:
it doesn't fling like some of that other stuff.
Also alex is 100% correct. Since your suspension has no load its not going to show if the chain is properly adjusted.
"Riding a motorcycle is like playing sports, not everyone is cut out for it." - WVNinja
wvninja is offline   Reply With Quote
Old February 8th, 2011, 07:46 PM   #17
Animal78
Motorcycle(s): 08 Ninja 250(sold) 2000 Ninja 250 (sold) 2012 Ninja 250r 2020 Harley Sportster (rarely ridden)
I couldn't help it I looked at it. Wow, that's awful. I hope no one does that. If you do please don't post the pictures LOL.
Animal78 is offline   Reply With Quote
Old February 11th, 2011, 02:56 PM   #18
kobachi
kobachi's Avatar
Originally Posted by wvninja View Post
I use chain wax:
Me too
Old February 11th, 2011, 03:10 PM   #19
MiniCog
MiniCog's Avatar
Motorcycle(s): Past: 2007 250 Ninja 2005 XR650R 2003 KLX400R
The bouncing is fine.
I also have someone else get on my bike (the first time I adjust the chain on a bike, like when I juts get a bike), and jump up and down on it to make sure the shock will bottom out before the chain keeps the swingarm from moving down any further.
He had the time to take pictures of it right after it happened!? HAHAHAHA!
When life throws turns at you, aim for the apex.
MiniCog is offline   Reply With Quote
Old February 11th, 2011, 03:11 PM   #20
MiniCog
MiniCog's Avatar
I use chain wax:
Same, it's great! I use it on my dirtbikes, too. I also have that Tirox 360º chain cleaner with the spiral brush thingy. It works pretty good, and the brush is great since I'm kinda lazy at times...
Old February 11th, 2011, 03:18 PM   #21
Maxima Chain Wax is great product, but lately I've been using this on the bikes (street and dirt) with even better results... less fling than I was getting with Chain Wax.
Old February 11th, 2011, 09:59 PM   #22
headshrink
headshrink's Avatar
I knew I wasn't crazy! Well, not too much. I could have sworn I was getting better results as well, but thought it is one of those things that was just too good to be true, or to easy.... defenately too cheap. This is the only stuff I buy now.
Old February 12th, 2011, 03:05 PM   #23
MiniCog
MiniCog's Avatar
I'm going to have to try that out after my bottle of Chain Wax is gone. (It's almost new...)
Old February 12th, 2011, 04:01 PM   #24
headshrink
headshrink's Avatar
Why don't you get it now ($cheap$), and compare the two...
If you feel motivated enough, you can even do a DIY "scientific" video study of the two, and post it. I love all the nerdy things we grown-ups do here.
Old February 12th, 2011, 04:46 PM   #25
MiniCog
MiniCog's Avatar
Looks like I'm going to Lowe's/Home Depot this weekend.
I know that Maxima Chain Wax burns, like WD-40, but you can spray it on stuff, let it sit, and burn that stuff.
Old June 5th, 2011, 06:48 AM   #26
EddieNewYork
"Hey, That's My Bike"
EddieNewYork's Avatar
Motorcycle(s): 88 Honda ZB50, 01 Honda Monkey, 07 CRF50, Honda CBR 600RR Phoenix Edition
Hey guys, quick question... when measuring the "between distance" up and down... is that while...
1. the bike is on the rear stand?
2. the bike is on the rear stand with rider?
3. the bike is not on the rear stand (level)?
4. the bike is not on the rear stand with rider?
EddieNewYork is offline   Reply With Quote
Old June 5th, 2011, 07:19 AM   #27
rockNroll
rockNroll's Avatar
Motorcycle(s): black
1 or 3. 3 is easier. Don't worry about the rear being up a little.
Old June 5th, 2011, 07:39 AM   #28
EddieNewYork
thx man, wouldn't 1 be easier though if no rider weight is needed?
Old June 5th, 2011, 09:27 AM   #29
rockNroll
rockNroll's Avatar
Ouch, I kinda messed that up. Lemmie fix
#3 would be easier if all we are doing is checking, which is what you asked. Hold the bike upright, kneel and check. #1 is easier when making adjustments. When doing #1 don't worry about the rear end being up a bit on the stand.
Old June 5th, 2011, 10:13 AM   #30
EddieNewYork
Oh okay.
Old June 5th, 2011, 12:08 PM   #31
maxwellca21
maxwellca21's Avatar
Motorcycle(s): 09 ninja 250
use this and clean your bike man! its freaking dirty!
ride it like you stole it!
maxwellca21 is offline   Reply With Quote
Old June 6th, 2011, 10:16 PM   #32
Cedilla
Cedilla's Avatar
Motorcycle(s): 2009 Ninja 250 (sold)
I think everyone should see those pictures from the gixxer forum. Just one look at that is a healthy reminder to never ever ever ever ever ever ever try to clean your chain with bike running. Much better than learning the hard way like that guy did.
The Ninjette is not a disposable bike. You are not ever supposed to get rid of it. It is like a [friendly] herpes virus.... once you got it, you get keep it forever. Originally posted by-Headshrink
Cedilla is offline   Reply With Quote
Old July 15th, 2011, 02:59 PM   #33
the big mike
the big mike's Avatar
Motorcycle(s): 2008 Ninja 250r, Fazer8
chain question here: about 400 miles ago I had my chain tightened by the dealer. There was actually almost no slack. But right now, my chain is this loose that it even hits the swingarm when bouncing. How is this possible?
Has it something to do with the fact that I ride 70 miles on highway twice a week?
the big mike is offline   Reply With Quote
Old July 16th, 2011, 02:47 AM   #34
NathanUc
B-Town Ninja
NathanUc's Avatar
Motorcycle(s): Black 2013 Ninja ZX6R ABS
I had similar issues after my first service maint (500miles). Turned out the dealership didn't torque the axle (I think that's what it's called..) enough. Check the torque and see if it's what the manual says (I don't have my manual with me or I'd tell you)
Downgraded to a 2013 636. Previous owner of a 2010 250r
My moto-vlog YouTube channel http://www.youtube.com/bloomingtonninja
NathanUc is offline   Reply With Quote
Old July 16th, 2011, 07:07 AM   #35
the big mike
So i had my chain tightened today. They said there was so much slack on it in only 400 miles because I didn't lube it enough, considering I only use my bike for 100 km rides twice a week. So from now on I'll lube it once a week and see where it gets me.
Chain Slack jeffb502 2008 - 2012 Ninja 250R Tech Talk 11 December 3rd, 2013 10:02 AM
chain slack eddiekay 2008 - 2012 Ninja 250R Tech Talk 8 October 18th, 2011 05:40 PM
Chain Slack for two up riding? Buffalony 2008 - 2012 Ninja 250R Tech Talk 1 June 4th, 2011 12:13 PM
Chain Slack Tool? ScorpionNinja 2008 - 2012 Ninja 250R Tech Talk 11 October 24th, 2010 11:53 PM
Chain Slack? Xuracing 2008 - 2012 Ninja 250R Tech Talk 2 June 9th, 2009 09:21 AM
