April 10th, 2011, 08:51 PM | #1 |
Key doesn't work on trunk lock
My bike came with two keys from the dealer. I always used one till I misplaced it and now I'm using the spare. However, I am not able to open the trunk with this key. It works fine for ignition and fuel cap but doesn't budge when I put it into the trunk key hole. This never happened with the first key. Both the keys were new originals with the bike. Is it just a coincident that my trunk lock screwed up the same time I start using the second key? Or is it possible for a key to work one place and not another because of some manufacturing defect?
Would anyone be willing to take a close up shot of the trunk locking mechanism inside the trunk? I'm going to try throwing a string in there and see if I can locate and pull the locking latch manually. |
April 12th, 2011, 06:21 PM | #2 |
Join Date: Dec 2009 Motorcycle(s): Blue 2008 Ninja 250R Posts: 86
Check to make sure the spare key isn't bent -- I had this problem once where pulling my key out of the ignition socket too forcefully had bent the key a little. It still worked in the ignition but wouldn't work in the trunk until I bent the key back.
Mine also try stopping by a locksmith and have them squirt some lubricant in the lock. |
April 13th, 2011, 10:09 AM | #3 |
Join Date: Jul 2009 Motorcycle(s): '09 Ninja 250R SE (Sold) Posts: 41
Try pushing down on the seat before turning the key as well. Sometimes that works pretty well for me.
I started out with nothing & still have most of it left. |
2008 Ignition, Fuel Tank, and Trunk Lock Set | garth285 | Motorcycle-related | 7 | December 17th, 2016 06:40 PM |
How do I get the key lock code for my 2009? | airjordan23 | 2008 - 2012 Ninja 250R Tech Talk | 12 | April 24th, 2015 04:35 AM |
[hell for leather] - Michael Lock on what the motorcycle industry doesn’t need right | Ninjette Newsbot | Motorcycling News | 0 | October 21st, 2010 05:40 PM |
Trunk lock broken? | Kitdog | 2008 - 2012 Ninja 250R Tech Talk | 3 | August 28th, 2010 08:23 PM |
Steering Lock doesn't lock??? | untdavid | 2008 - 2012 Ninja 250R Tech Talk | 16 | September 25th, 2009 05:30 AM |
