Old April 17th, 2011, 12:56 AM   #1
h0yitsdom
newbie newbie
h0yitsdom's Avatar
Motorcycle(s): 2006 Ninja ex250
Starts fine 1st time but won't start after
i have an 06 250 with around 6k miles
it starts up fine when its cold, like first ride of the day
but if i shut it off and try to start it again 5 minutes later it won't and takes a lot of attempts
what should i check out first?
i have seen carb cleaning mentioned a lot but more for a bike not starting at all, when it does start it runs great.
also when it does start the 2nd time if i push the gas it stutters/stumbles and dies if i let the choke off
h0yitsdom is offline   Reply With Quote
Old April 17th, 2011, 01:55 AM   #2
does it run at all without the choke being on?
Old April 17th, 2011, 10:12 AM   #3
h0yitsdom
newbie newbie
h0yitsdom's Avatar
yeah like when i drove it home
i turned the choke up and let it idle for like a minute or 2
then turned it off and rode it home just fine
when to start it again once i got home like 5 minutes later to show someone and it wouldn't start, cranked for like 3 minutes then it finally started
Old April 17th, 2011, 10:47 AM   #4
are you using the choke to start it when it's warm or are you trying to start it w/o any choke?
Old April 17th, 2011, 10:57 AM   #5
h0yitsdom
newbie newbie
h0yitsdom's Avatar
after its warm normally i don't use choke, but i've tried with choke and it does the same thing.
it turns on EVENTUALLY but it takes longer then it should :\
Old April 17th, 2011, 11:03 AM   #6
once you do get it started, does it idle nice and even or is it an erratic type of idle? what is you idle rpm set to once it's warmed up?
some bike history... has it always done this... is the bike new to you... how long has the gas been in the tank... anything you think would help would be appreciated.
Old April 17th, 2011, 11:51 AM   #7
h0yitsdom
newbie newbie
h0yitsdom's Avatar
bike is new to me
it has been dropped by original owner
not sure how long the gas has been in the tank
previous owner told me that sometimes you have to start it from reserve
when i rode it home after getting it to start it idled and ran perfectly. at stop signs and red lights it idled with no problems with the choke off. i believe the RPMs were at 2k but i'll have to check again
haven't had another chance to actually ride it since i don't have my license yet
Old April 17th, 2011, 12:03 PM   #8
do you know when the valves were last adjusted?
Old April 17th, 2011, 12:56 PM   #9
h0yitsdom
newbie newbie
h0yitsdom's Avatar
she told me a local shop had just adjusted the valves, i know of the shop but didn't call to confirm or anything
my battery tender just got here and i just hooked it up. the light was solid red meaning its charging so i'm going to let it sit on there for a while and check it out later this evening to see if it solves the problem. i'll report back then
thank you for the help so far
Old April 17th, 2011, 01:19 PM   #10
I would recommend that you add some fuel cleaner to the tank. I like Seafoam... it sometimes works wonders in cleaning up gunked up jets w/o having to open the carbs up.
I would also call the shop to confirm that the valves were indeed adjusted. At your mileage, you are due, if it's not been done and there have been cases of improper idling when warm due to out of spec valves. If you can confirm they were done (paper records would be great, if they will give you a copy), then you can cross valves off the possible causes of your problem.
A good, strong, fully charged battery is always a plus when having starting problems. How old is the battery? make sure the battery terminal connections are tight, too.
Old April 17th, 2011, 01:56 PM   #11
h0yitsdom
newbie newbie
h0yitsdom's Avatar
i've used seafoam before on my car but never on a bike
just pour it in the gas tank then run through a tank of gas?
do i need to change the oil afterwards?
i'm going to give the shop a call on monday and see if they can pull anything up
Old April 17th, 2011, 02:01 PM   #12
just add it to the gas according to the mixing directions on the can (1 oz/gal???)... no need to change the oil afterward.
Old April 19th, 2011, 05:25 PM   #13
h0yitsdom
newbie newbie
h0yitsdom's Avatar
well had a chance to actually ride it yesterday. drove it for about 20 minutes then parked it for like 30 minutes while i was watching a game and it started up fine the next time
the idle is at around 2500-3000 right now and drops when i pull the clutch in
Old April 19th, 2011, 05:32 PM   #14
set the idle to about 1500 when the bike is fully warmed and in neutral. kinda weird that it drops when you pull in the clutch lever...
Old April 19th, 2011, 06:57 PM   #15
h0yitsdom
newbie newbie
h0yitsdom's Avatar
i could be saying that completely backwards lol
i'll take it for a spin again tomorrow and change the idle after its warm and report back. going to be getting some seafoam this weekend from work hopefully
Old April 23rd, 2011, 06:39 PM   #16
h0yitsdom
newbie newbie
h0yitsdom's Avatar
well i think i goof'd haha
today i tried to start it without giving it gas aka not touching the accelerator and it started up fine after driving it.
then i thought hmm maybe i'm not supposed to touch the accelerator when first trying to turn it on. kept trying this new found method and the bike starts up every time lol
so i think the only problem was 1st time bike user error
but i did buy from b-12 and sprayed it in the gas tank
adjusted the idle today to 1500 and it runs great
and i bought the battery charger so i guess some good came out of this
where do I start to see if it starts? Finesse 1986 - 2007 Ninja 250R Tech Talk 14 March 16th, 2014 06:29 PM
Ninjette seemed fine, but now won't start. ACL 9000 1986 - 2007 Ninja 250R Tech Talk 27 January 10th, 2014 02:17 PM
bike wont start,clicking, no headlight, battery is fine. zzrguy 1986 - 2007 Ninja 250R Tech Talk 32 August 18th, 2012 03:14 PM
[topix.net] - Sheridan Morais won both Superbike races in fine style. Ninjette Newsbot Motorcycling News 0 June 6th, 2011 06:20 PM
[crash.net - WSBK] - Camier ‘feeling fine' but won't ‘overdo it' Ninjette Newsbot Motorcycling News 0 March 22nd, 2011 03:50 AM
