Old May 15th, 2011, 06:14 PM   #1
2fiddy
2fiddy's Avatar
Motorcycle(s): 2010 Red Ninja 250r
Adjusting the carb to let more fuel in?
Hey guys. I've heard from a couple people by now that say there is a cap on the carb you can drill into and turn it about 2 and a half rotations and the bike will really have some life to it and really increase in get up.
Do you guys know anything about this? And if you've done it, please share your experience.
2fiddy is offline   Reply With Quote
Old May 15th, 2011, 08:17 PM   #2
Cuongism
Cuongism's Avatar
Sounds like your idle mixture screws. It affects the fuel for anything less than 5k to idle.
http://www.ninjette.org/forums/showthread.php?t=10246
Old May 16th, 2011, 10:55 AM   #3
HKr1
IC2(SW)
HKr1's Avatar
5K.... LOL Maybe they shouldnt call it "idle mixture"?
Old May 16th, 2011, 11:20 AM   #4
1994Ninja250F
‘94 Rider
1994Ninja250F's Avatar
Motorcycle(s): 1994 Kawasaki Ninja EX250F
The idle mixture screws, and the needle and main jet for that matter, aren't controlled by RPM. It's only the throttle position that affects which circuit is used (idle, needles, and main jet).
1994Ninja250F is offline   Reply With Quote
FS: Motion Pro Syncpro Carb Tuner (Carb Sync) $60 Shipped menikmati Motorcycle-related 4 April 8th, 2020 12:39 AM
CARB Dropped and Busted Fuel Inlet - Suggestions? Road Dawg1 2008 - 2012 Ninja 250R Tech Talk 9 July 18th, 2014 07:12 PM
Fuel coming out the carb, and bike wont start scorch 2008 - 2012 Ninja 250R Tech Talk 35 February 13th, 2014 11:33 AM
fuel inlet tube on carb cracked or loose? Leaks gas! sherwiner 1986 - 2007 Ninja 250R Tech Talk 5 April 11th, 2012 02:57 PM
