Old October 27th, 2011, 06:47 AM   #1
kevlar250
kevlar250's Avatar
Motorcycle(s): '94 Vulcan 1500, '06 Katana 600, '08 FZ1
Compression gauge
What are you guys using to check compression other than the Kawi factory tool?
kevlar250 is offline   Reply With Quote
Old October 27th, 2011, 07:00 AM   #2
GeorgeRYoung
Motorcycle(s): EX250, C10 Concours
automotive compression gauge
I have a compression gauge with a conical rubber thingie. You push down hard on the gauge, and the rubber thingie seals against the spark plug hole.
Crude, cheap, surprisingly effective.
GeorgeRYoung is offline   Reply With Quote
Old November 1st, 2011, 09:47 PM   #3
kevlar250
kevlar250's Avatar
Got a nice gauge set from Harbor Freight $25. It's got fittings that work with an air compressor so you can use it to pressurize the cylinder to check for leaks. The 10mm adaptor needed the diameter to be ground down a bit to fit tight in the 250 head but that was easy enough.
Old November 2nd, 2011, 12:33 AM   #4
my finger.
Old November 2nd, 2011, 06:15 AM   #5
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
My buddy that builds motors recommended this compession tester. I bought it a few months ago and it works just fine and the plastic case is a nice bonus. My scooter was running slow so it tested the compression and it was down to 80 psi from 115psi so I parked it to rebuild the top end and bought a ninja 250 to take its place.
Craftsman Compression Test Kit
Sold By : *SEARS
Item# 00947089000
What is compression Racer x 2008 - 2012 Ninja 250R Tech Talk 22 March 15th, 2013 02:44 AM
