Old December 7th, 2011, 05:13 PM   #1
Kerberos
Motorcycle(s): Ninja 250 2010 (Sold), 2013 Ninja 300!!
Yes or no on these mods?
Slip on exhaust
http://www.dan-moto.com/zx-250-r-nin...rsrqtaobg5hpi2
$80.00
15 tooth sprocket
http://www.motorcycle-superstore.com...50R-Parts.aspx
$18.95
Rear bike stand
http://www.motorcycle-superstore.com...ear-Stand.aspx
$143.95
Spools
$12.99
Rejet kit
My bike is all stock as of right now. At minimum I want exhaust. Do i have to rejet if i put on a slip on exhaust? I read that i don't have to rejet but i read that it helps a lot. Do i have to remove the snorkel? I was not planning on it.
Yes or no?
Am i missing anything?
The first thing I will be doing is the exhaust and front sprocket.
cant wait till the winter is over. I have not ridden all week
Thousands of candles can be lit from a single candle, and the life of the candle will not be shortened.
-BL2
Kerberos is offline   Reply With Quote
Old December 7th, 2011, 05:19 PM   #2
Skippii
Milkshake Drinker
Skippii's Avatar
Absolutely NO on the rejet kit. The jets can be bought for $5 from a motorcycle shop. Needle shims cost less than 10 cents. Jet kits are a total rip off.
"What a sweetheart."- ninja_sleeper to me
Old December 7th, 2011, 05:24 PM   #3
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
As is a slip on, unless you are only interested in changing the sound of your bike
AFM #676
Supersports are for n00bs
Old December 7th, 2011, 05:25 PM   #4
Skippii
Milkshake Drinker
Skippii's Avatar
Additionally, if you keep the stock airbox and headers, you won't need to change the main jets at all--a simple shim under the needles should be the only change you need.
A slip-on alone just doesn't make enough airflow difference to change the power or intake mixture requirements significantly.
Old December 7th, 2011, 05:25 PM   #5
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Stands for much cheaper
http://t-rex-racing.com/catalog.php?category=45
AFM #676
Old December 7th, 2011, 05:26 PM   #6
Skippii
Milkshake Drinker
Skippii's Avatar
I find that the weight savings of a slip on can be worth the money if you are riding on tracks or really technical roads.
Old December 7th, 2011, 05:53 PM   #7
Kerberos
thats so much better. thanks for pointing that out. saving money is always a good thing
-BL2
Old December 7th, 2011, 05:55 PM   #8
Kerberos
yea its the sound im looking for. i didnt want to do the jet kit but exhaust and sprocket and getting a stand are whats most important right now. thanks for the info
-BL2
Old December 7th, 2011, 07:31 PM   #9
definitely get the stand and spools. The jet kit is up to you, but I see where skippii is coming from on the jet kit. I've just shimmed for a while now, and the bike is fine. I want the jet kit just because I want to see how the needles feel different and I want the hex screws for my bowls, but that's my choice to spend the money. Go with the slip-on for weight loss, ditch the snorkel, and add 2 washers to shim your needles out. That should give you a bit more kick all around. The sprocket swap is up to you
Old December 7th, 2011, 10:32 PM   #10
Skippii
Milkshake Drinker
Skippii's Avatar
I don't think I paid more than $35 for my swingarm stand. Maybe HF? Can't remember exactly where I got it.
Sometime when I've got a lot of free time, I think I'll weld up a copy of it, and see how hard it is. Post plans online or something so everyone else can have plans and make their own, or bring it to a shop and have it done. Still shouldn't cost much at all.
Old December 8th, 2011, 06:46 AM   #11
k-os
Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike
Why not just go to the hardware store and buy the socket head cap screws for the float bowls? I think they're M4's.
k-os is offline   Reply With Quote
Old December 8th, 2011, 10:44 AM   #12
Malicious Logic
hates stupid people
Malicious Logic's Avatar
Motorcycle(s): 2005 ZX6R
Have you checked out the Dan Moto Jisu exhaust? It's pretty cheap like the carbon GP one but to me, it sounds a bit better....I'm a fan of the Akrapovic sound though, and the Jisu sounds similar to that...
Malicious Logic is offline   Reply With Quote
Old December 9th, 2011, 12:39 PM   #13
Kerberos
Mostly that the Dan moto exhaust i picked was 80 bucks lol. Otherwise i would go for a full system but i have no money right now for that.. sad face
-BL2
Old December 9th, 2011, 12:56 PM   #14
Malicious Logic
hates stupid people
Yeah, the Dan moto Jisu is like $86 I think, maybe a few bucks more. Just kinda gives you some variety between the two so you don't think you're stuck with just the sound of the carbon GP.
Old December 9th, 2011, 01:04 PM   #15
true, but I still won't get the needles. But for 2$ or so, I might as well. Are the screws on the top the same size? I'll just get 16 and replace all the screws.
Old December 9th, 2011, 05:05 PM   #16
k-os
I'm pretty sure they are, but if you can, just take out one screw from the top and bottom and get those same size and length screws in Stainless Steel Socket Head Cap Screws.
Old December 9th, 2011, 05:50 PM   #17
Skippii
Milkshake Drinker
Skippii's Avatar
I seriously doubt the DJ needles are any better than the Keihin ones. Any difference in taper that does exist between the two is not going to make any noticable difference.
I haven't examined the two needles side by side, so I can't comment on what differences might exist between the two--though I'd be interested to know. I'm just saying that even if there are differences, it won't matter on a correctly tuned carb.
Old December 10th, 2011, 03:57 PM   #18
MotoED
MotoED's Avatar
Motorcycle(s): 2011 SE Pearl/Ebony Ninja 250R
Originally Posted by leogutierrez17 View Post
I can speak for this exhaust. I have this model installed on my bike. The sound is decent, not too loud, but loud enough to let cager know you're approaching! It could get annoying sometimes though. Good for the price.
[#4]
MotoED is offline   Reply With Quote
Old December 10th, 2011, 04:42 PM   #19
THE BIG SITT
THE BIG SITT's Avatar
I've got a DanMoto Jisu exhaust on my bike. The bike came with it on there so I don't know if its that much louder than other exhausts out there… but it does sound good!
P.S.- I'm hoping to get a full exhaust system within the next month or so, so I may sell DM for ~$20
THE BIG SITT is offline   Reply With Quote
Old December 13th, 2011, 10:33 AM   #20
nezumiamalek
Motorcycle(s): Kawasaki Ninja 250R
I have a 15T sprocket in mine. It does its job so I'm glad I got mine.
nezumiamalek is offline   Reply With Quote
My mods... hpav13 2008 - 2012 Ninja 250R Farkles 9 January 5th, 2014 05:42 PM
Mods Old Lemon 2008 - 2012 Ninja 250R Farkles 20 May 5th, 2012 12:37 AM
First Mods FoxRacerX78X 2008 - 2012 Ninja 250R Farkles 5 April 4th, 2012 03:24 AM
Your First Mods N1nja_N00b 2008 - 2012 Ninja 250R Farkles 32 October 6th, 2011 01:52 PM
What are some MUST have mods? aznboi250r 2008 - 2012 Ninja 250R Farkles 11 June 26th, 2011 09:52 PM
