Old January 5th, 2019, 03:10 PM   #1
Darksik
Darksik's Avatar
weird noise in 4k rpm
I changed the air filter to the motorcycle, when I opened the air box in the snorkel I had a kleenex, I took it off and cleaned it with compressed air, I installed the new air filter to the motorcycle, when I turn on the motorcycle start without problems, at the time of leaving, the motorcycle at 4000 - 4500 revolutions does not pass until it opens 3/4 the accelerator feels a "boost" and passes the revolutions again, yesterday i let it 5 minutes warm up, i accelerate the motorcycle and it was strange sound from the exhaust, as if it lacked gasoline or had a lot of air, here I attached video to tell me what could be, if I need to open more the carburetor or if you need something else, i put the old air filter and the bike still got that problem.
https://streamable.com/ig8fn
https://streamable.com/p9gmv
Old January 6th, 2019, 06:22 AM   #2
Originally Posted by Darksik View Post
I changed the air filter to the motorcycle, when I opened the air box in the snorkel I had a kleenex...
What do you mean?
It sounds like it's not getting enough fuel in the midrange, but that's sort of a guess.
Old January 6th, 2019, 12:49 PM   #3
Darksik
Darksik's Avatar
What do you mean?
i guess the kleenex was from outside, like dust
Old January 6th, 2019, 02:21 PM   #4
Check for loose connections at carbs:
- rubber tubes fully pushed onto engine
- carbs fully pushed into rubber tubes
- hose clamps tight
One troubleshooting technique is to restore everything back to previous condition when things were working. Put the Kleenex back .
Old January 9th, 2019, 12:47 PM   #5
Darksik
Darksik's Avatar
- hose clamps tight
I restore everything with the old air filter and the bike still have that problem, the "klenex" i was meaning was a piece of bath paper, i don't know if maybe y move the hose that go from the air to the carb, because before open the air filter box the screw from down i can't remove because the frame block to remove the screw :/ I already move the "idle speed screw" and the bike is stil have that problem
Weird chain noise. cmbeebe 2008 - 2012 Ninja 250R Tech Talk 4 April 22nd, 2014 10:19 AM
Weird knocking noise... blink 2008 - 2012 Ninja 250R Tech Talk 6 July 3rd, 2012 12:24 PM
Weird noise while driving 7days 2008 - 2012 Ninja 250R Tech Talk 9 August 18th, 2010 07:05 PM
weird sound around 8500-9000 rpm rsamtani 2008 - 2012 Ninja 250R Tech Talk 26 June 12th, 2010 10:09 PM
Rattling Noise from 8-9k RPM 250fan 2008 - 2012 Ninja 250R Tech Talk 20 August 1st, 2009 10:52 PM
